Best exhaust manifold for an itb'd NA? I currently have a regal manifold.
Best Exhaust Manifold For An Na With Itbs?
Posted 16 September 2013 - 08:41 PM
Posted 16 September 2013 - 08:58 PM
Vocky's.
Posted 16 September 2013 - 09:02 PM
Posted 16 September 2013 - 09:50 PM
Edited by oakmere, 16 September 2013 - 09:51 PM.
Posted 16 September 2013 - 10:19 PM
^ that coupled to the rest of his exhaust systemVocky's.
Posted 16 September 2013 - 11:00 PM
At least a decent 4-2-1 manifold, or a long primary 4-1. And probably not too big a bore, as you need the exh gas speed for scavenging effect...
(Only nothing readily available what comes close to this... )
Posted 16 September 2013 - 11:27 PM
Are you wearing slippers?Best for what, mid range, peak, packaging, etc
Posted 17 September 2013 - 09:32 AM
Posted 17 September 2013 - 09:57 AM
TMS or Tullet are the only options available really. Make your own is the best option though, or a custom builder.
This is what I'm thinking. What type of weld should I skill up on?
Posted 17 September 2013 - 09:58 AM
Vocky's.
Is vocky's a 4-1 or a 4-2-1?
Posted 17 September 2013 - 10:35 AM
TIG. Easy enough. The only tip I'd give is not to put too mcuh heat in. Most stainless systems are welded not quite through the full thickness. If you weld through fully you get furring unless you back gas. I learned this the hard way
Posted 17 September 2013 - 11:14 AM
Vockys is a 4-2-1 and it is looped after the manifold to increase the system length by over 1M. This is to improve midrange I think.Is vocky's a 4-1 or a 4-2-1?Vocky's.
Posted 17 September 2013 - 11:16 AM
Posted 17 September 2013 - 01:16 PM
The chap that makes mine back gased the lot. Mine is loud, but it is a true 2.5" system and the primaries are as large as possible, but it is a manifold and downpipe section all in one to save joints and compromising on the design.
Posted 17 September 2013 - 01:18 PM
mandrel bends?
Posted 17 September 2013 - 09:35 PM
mandrel bends?
Yep, some of them are quite complex due to the space. I have a twin silencer single exit pipe exhaust now.
Posted 17 September 2013 - 10:45 PM
mandrel bends?
Was it manufactured from drawings or by expertise and skill? or both
Got a photo?
Posted 19 September 2013 - 07:52 PM
If you are aiming for Hp you need to pulse tune Your hedder. Use the opening time BTDC for the exhaust cam. Determend primary length and use that number to make out the ID for tubing.
Here is my numbers 233 rwhp! 4-1 hedder, 3" Down to the catalyst, and 2,5" the rest. Primary is 2" tubing.
42 mm AT Power TBI.
Posted 19 September 2013 - 07:54 PM
Forgot the hedder pic....
Posted 19 September 2013 - 09:12 PM
Nice! Where did you get the manifold, bends and the collector?
Pulse tuning..... NA tuning is so much more fun than boosting
Also tagged with one or more of these keywords: exhaust manifold, na, itb
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
Welcome to VX220.org.uk →
Introduce Yourself - Newbies & Forum Guide →
Hello From Leamington SpaStarted by Jordang , 22 Aug 2020 ![]() |
The Market Place →
Car Parts Wanted →
Na HeadlightsStarted by jdscott , 02 Aug 2020 ![]() |
General Discussion →
Tuning & Modifications →
Bizarre Acceleration IssueStarted by MattMacc123 , 10 Aug 2019 ![]() |
The Market Place →
Cars For Sale →
Vx220 2001 (Y) 42,000 Miles, 2 OwnersStarted by Andyn999 , 27 Jan 2019 ![]() |
