What over size valves options are there for the NA? What the best valve configuration when running itbs and wild cams?
Anybody done this work themselves?
Posted 26 September 2013 - 09:33 AM
Posted 26 September 2013 - 09:37 AM
I would only recommend the GM Racing +0.5mm valves or buy direct from SI Valves and purchase their +1mm valves.
My SI Valves did well over 20,000 miles (the head was fitted to three different cars), never had any problems, well until Joe melted the car
GM Racing are the best quality
ps: For SC the OEM Saab valves are the best option
Posted 26 September 2013 - 09:59 AM
Might be worth mentioning that the +0.5mm valves fit in the OEM seats (just). It did concern me as I was just scraping into the alloy when I cut mine in. Any bigger and you'll have to fit new seats.
Posted 26 September 2013 - 10:12 AM
the machine shop I use have a fancy valve seat cutting machine and they can do +1mm, but no more on a z22se / b207 head
That opens up the valve seat insert to maximum, but I have done quite a few +1mm and so far they are still all okay
Posted 26 September 2013 - 10:42 AM
Posted 26 September 2013 - 10:56 AM
Braver than me then! I do tend to err on the side of caution though.
Get the machinist to open up the valve hole (not sure of it name) not just the seat to match.
Valve throat?
Posted 26 September 2013 - 11:03 AM
Posted 26 September 2013 - 12:41 PM
I wonder if mine are +1mm, it was a while ago I ordered them. It'd certainly explain why I felt it was on the edge of the OEM seats. I got the supertech ones BTW.
I cut in mine with three angle seats then opened up the throat. Make sure whoever does it uses a single point cutter not one of those grinder things
Posted 26 September 2013 - 04:20 PM
What work can I do myself? Can I manually grind in +.5mm or +1mm valves?
Posted 26 September 2013 - 05:31 PM
No. You need a valve seat cutter.
Posted 26 September 2013 - 06:55 PM
Posted 26 September 2013 - 08:24 PM
Posted 26 September 2013 - 08:58 PM
I think it only cost me £80-£90 to get the valves cut.
OK, hopefully I can find a decent machine shop that can pressure test, skim and cut
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
Welcome to VX220.org.uk →
Introduce Yourself - Newbies & Forum Guide →
Hello From Leamington SpaStarted by Jordang , 22 Aug 2020 ![]() |
The Market Place →
Car Parts Wanted →
Na HeadlightsStarted by jdscott , 02 Aug 2020 ![]() |
Just Bought A Vx220 , Based In OxfordStarted by Gizza3434 , 07 Oct 2019 ![]() |
General Discussion →
Tuning & Modifications →
Bizarre Acceleration IssueStarted by MattMacc123 , 10 Aug 2019 ![]() |
