The standard gearbox - Are there any mods worth doing?
Posted 28 September 2013 - 07:41 PM
Posted 28 September 2013 - 08:15 PM
Put a gearbox breather on if you tend to drive the car in spirit once i a while.
Posted 28 September 2013 - 08:58 PM
Posted 28 September 2013 - 09:08 PM
When driving in spirit (usually on track), the gearbox oil heats up, and can squirt out via the breather nipple.
As that is near the left rear wheel , it's potentially dangerous on track.
It also creates a bit of a mess in the engine compartment.
The mod gives the stock breather nipple some extra room.
Posted 28 September 2013 - 09:38 PM
Oil cooler. Barb on the level port, barb on the fill port, circulated through a cooler (obviously) but only if heat management becomes an issue. Alternative is to use a thicker oil so it thins less.
Posted 28 September 2013 - 11:28 PM
Anything in relation to gearing? Change ratios? Can I add an extra gear? Two speed reverse anybody?
Posted 28 September 2013 - 11:35 PM
Posted 29 September 2013 - 08:17 AM
Posted 29 September 2013 - 09:03 AM
Posted 29 September 2013 - 11:00 AM
The car already sits high in the rev range on the motorway, increasing this would be irritating in my car.Changing ratios and final drives is an expensive business
I wouldn't agree that a Zaf box would be too noisy though. Could get an LSD?
Posted 29 September 2013 - 11:03 AM
You should try a 4.6FD, now that is irritating!The car already sits high in the rev range on the motorway, increasing this would be irritating in my car.Changing ratios and final drives is an expensive business
Posted 30 September 2013 - 08:37 AM
Posted 30 September 2013 - 09:25 AM
NO!!!!! (well ok may have them but that doesnt mean its the right answer.
Plate diff and do it right if you want to add an LSD, many deem it pointless/not worth the cash.
Also tagged with one or more of these keywords: na, gearbox, modifications
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
Welcome to VX220.org.uk →
Introduce Yourself - Newbies & Forum Guide →
Hello From Leamington SpaStarted by Jordang , 22 Aug 2020 ![]() |
The Market Place →
Car Parts Wanted →
Na HeadlightsStarted by jdscott , 02 Aug 2020 ![]() |
General Discussion →
Tuning & Modifications →
Stage 2 Exhaust (Recommendations / Looking For)Started by dplas , 08 Sep 2019 ![]() |
The Market Place →
New F23 Gearboxes! Old New StockStarted by Vladimir , 05 Sep 2019 ![]() |
