Vx220 Snap Oversteer Advice Needed
#21
Posted 15 October 2013 - 11:20 AM
#22
Posted 15 October 2013 - 11:45 AM
#23
Posted 15 October 2013 - 11:51 AM
#24
Posted 15 October 2013 - 10:42 PM
#25
Posted 15 October 2013 - 10:49 PM
#26
Posted 15 October 2013 - 10:50 PM
#27
Posted 16 October 2013 - 07:52 AM
We'll know more once we get a chance to get the clam off. That's the biggest issue, financially, getting a new clam and rear light unit. Funny, several people make front clams and other bits for the vx, but nobody seems to make a rear clam.. No idea why...? So I can either have the damaged one repaired (expensive), or find a decent used one in one piece and have it sprayed (preferred option..)
I believe the rear clams are slightly different on the N/A and Turbo, while the fronts are the same, I should imagine thats the reasoning behind it.
#28
Posted 16 October 2013 - 09:14 AM
Thanks Tony. Went a couple of weeks ago, already asked. Sod's law, would have been so perfect.Might be gone by now but worth asking:
http://www.vx220.org...-clam-vx220-na/
#29
Posted 16 October 2013 - 09:33 AM
Were the Bridgestone's new or old?
If the latter then they have no place as a reference as to how the car was handling on the 17inch wheels.
G
#30
Posted 16 October 2013 - 02:39 PM
I track the NA in general on 17s (not bridgstones I add) and Gaz Gold Pros and find absolutely no issue with snap oversteer. Also the toe links tend to snap mid corner rather than acellerating on the straight. Mike's car (I am an eye and video witness) oversteered on the straight due to sudden loss of traction from one rear wheel having touched the white line on the outside of the track in the wet. All I can think is that the lap before someone potentially hadn't dropped oil but by the time you came round again they had.
IMO any untoward noise on track should always be taken to the pits straight away to check all fixtures and fittings. To me this sounds like an unfortunate incident that just happened and that's that. Take what you can from it and move on. In my experience and from frequenting this forum for many years there is no such thing as "classic VX snap oversteer" unless something breaks, or an area of significant low traction is hit by one or both rear wheels. Hope you manage to get it fixed up and back in action soon
#31
Posted 16 October 2013 - 03:11 PM
Not sure if its o/s or n/s rear light you're after. But there's a new n/s just been listed here:
http://www.ebay.co.u...=item3386794757
#32
Posted 27 October 2013 - 10:07 PM
#33
Posted 27 October 2013 - 10:23 PM
#34
Posted 27 October 2013 - 11:04 PM
#35
Posted 28 October 2013 - 07:55 AM
Before any conclusions are formed, I fitted an EP toe link kit which loosened itself alarmingly between Birmingham and Le Mans. I am not an engineer, but I know what's important and followed the fitting instructions and torque settings to the letter.....
#36
Posted 28 October 2013 - 07:03 PM
#37
Posted 28 October 2013 - 08:01 PM
#38
Posted 29 October 2013 - 08:13 AM
If it really concerns then arrange to send back the part to Yvo (Elise shop), I'm sure he will cover costs and its replacement so the damaged unit can be looked at.
If it was not tightened then the bar would rock across the threads and eventually metal fatigue.
#39
Posted 29 October 2013 - 08:35 AM
I had a set of Elise Shop toe links on my SC VX, fitted correctly, correct torque etc. and the right hand outer bolt snapped. ES told me they'd never had one go before and blamed it on a faulty bolt. It happened on a fast, smooth left hand corner (no kerb riding etc.). JG is still trying to get the stains out of his pants
#40
Posted 29 October 2013 - 08:39 AM
Mine are from Yvo, as I've corresponded with him upon the issue. I overcame the loosening by overtightening. I still have play in three ends, he has sent me some components to change but other priorities have taken over.
It is a fallacy that 'race proven' components are suitable for road use. Race components will be checked far more frequently and crtical components appropriately lifed.
Also tagged with one or more of these keywords: oversteer, handling, spin, crash
General Discussion →
VX220 Discussion →
Vague/woolly Steering Feel When CorneringStarted by kmidderigh , 25 Jul 2015 ![]() |
VX220 Discussion →
Part Of Sills Required Where Rear Clam AttachesStarted by dylan390 , 18 Mar 2015 ![]() |
Track Day Forum →
How Not To Drive Around DoningtonStarted by peteslag , 05 Feb 2015 ![]() |
VX220 Discussion →
Sc Motorway Spin Into A Tree And Roll.Started by jasesaint , 27 Jan 2014 ![]() |
