Vx220 Snap Oversteer Advice Needed
#61
Posted 01 November 2013 - 02:31 PM
#62
Posted 01 November 2013 - 02:50 PM
can you get them with left hand threads?
#63
Posted 01 November 2013 - 03:26 PM
I've had to change three ends on my EP kit. I've had to replace them so often i hold stock of right and left hand thread joints. They seem to get a bit of play very quickly especially after jimmy rode the curbs at anglesey , That resulted in two of them.
It is most certainly not a fit and forger kit.
However, i've not heard of many failures.
#64
Posted 02 November 2013 - 12:22 PM
Just a type of washer, split to keep pressure on the nut to stop vibration from loosening it , so not handed, I used them in the past on stuff in work, the graph looks slightly biasedcan you get them with left hand threads?
Edited by ghand, 02 November 2013 - 12:32 PM.
#65
Posted 03 November 2013 - 07:29 AM
#66
Posted 03 November 2013 - 11:18 PM
If and it's a big if they ever needed re adjusting, just crack and free off, re apply stud lock, adjust and re tighten. As stated earlier some VXs have done 100 k on originals with no problems, and with sticky tyre track use. Mine had an inner get noisy at 65 k now on 72 k with the other three originals still ok, so I will replace all the lot soon with standards and a dab of stud lockYes, I was thinking some kind of stud lock - but how do you adjust in future then? Spring loaded washer with an extra nut sounds like a good idea.. So the spring presses the threads together, and if the original nut starts to undo then the spring presses even harder on the extra nut, increasing the forces on the threads for a stronger lock.. Would that be an idea worth trying?
#67
Posted 04 November 2013 - 11:55 AM
Nordlocks ARE handed as they have cams in the teeth to stop light loads from releasing them. No springs involved.
#68
Posted 05 November 2013 - 08:54 AM
#69
Posted 02 December 2013 - 06:55 PM
I went on track after recent fitting of Spitfire toe links by a specialist we all know, was the same track day that SteveA killed a toe link on a uprated kit, (vid of it happening to him somewhere), which turned out to be the wrong stub end for his hub.
Anyway I noticed my car starting to feel a little light at the rear under power going through the second half of the chicane, followed by big oversteer at the hairpin on applying power. Having seen what happened to SteveA I pulled off to check it out, sure enough one lock nut had come loose. I re did all of them but I have had one come loose since, I think threadlock is not such a bad idea.
Is it possible that because there are 3 or 4 different materials in close proximity or in contact that heating and cooling could loosen them enough to turn.
#70
Posted 03 December 2013 - 08:44 AM
Has anyone fitted an aftermarket kit that has not caused additional problems?
#71
Posted 03 December 2013 - 08:49 AM
I've got the EP kit on the race car, no problems all season, not replaced any ends, not come loose and no failures
#72
Posted 03 December 2013 - 08:51 AM
#73
Posted 03 December 2013 - 09:02 AM
Olly at Phoenix Motorsport does a very nice kit with brace bar, although if you want it before next winter you'll need him to for it. I've been running it for 3 years and JJJ on his old VXRHas anyone fitted an aftermarket kit that has not caused additional problems?
#74
Posted 03 December 2013 - 09:09 AM
And that came almost totally undone at a Snetterton trackday under TonyVXR56's stewardsip.
#75
Posted 03 December 2013 - 05:38 PM
The lock nut coming loose caused excessive wear in the threads so I now need a new rod end and the hard point that screws in the end of the tube.
Edited by Crabash, 03 December 2013 - 05:38 PM.
Also tagged with one or more of these keywords: oversteer, handling, spin, crash
General Discussion →
VX220 Discussion →
Vague/woolly Steering Feel When CorneringStarted by kmidderigh , 25 Jul 2015 ![]() |
VX220 Discussion →
Part Of Sills Required Where Rear Clam AttachesStarted by dylan390 , 18 Mar 2015 ![]() |
Track Day Forum →
How Not To Drive Around DoningtonStarted by peteslag , 05 Feb 2015 ![]() |
VX220 Discussion →
Sc Motorway Spin Into A Tree And Roll.Started by jasesaint , 27 Jan 2014 ![]() |
