B207 Saab Conversions
b207 engine swap conversion
960 replies to this topic
#261 Rosssco
Rosssco
  • 4,183 posts
Posted 04 December 2013 - 12:57 PM
Well i'm up for a lightened flywheel if people are setting up a group buy.
G
Graeme in Group Buy Shocker! ;)
#262 Rosssco
Rosssco
  • 4,183 posts
Posted 04 December 2013 - 12:59 PM
B207 = C20XE/LET pattern. :sleep:
I got one of these as I already had the ring gear from a standard C20XE flywheel. Local engineering place swapped the ring gear across for £10.
So this one is definatley the 'Pot' type requried, not the 'flat' style?
#263 techieboy
Posted 04 December 2013 - 01:04 PM
Yerrrp.
ETA: Though the one I bought from them didn't come with that black coating on. :unsure:
Edited by techieboy, 04 December 2013 - 01:05 PM.
#264 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 04 December 2013 - 01:48 PM
G
Well with so many of us using these engines, it makes sense to take advantage of economy of scale.
Plus, WTF else am I meant to do with my time. Makes a change from me starting one anyway.
G
#265 CHILL Gone DUTCH
Posted 04 December 2013 - 01:50 PM
Don't forget to ask about 6 bolt version for the 2.2 crank
#266 Exmantaa
Posted 04 December 2013 - 01:52 PM
Errhhh, yes, you will need the C20XE/LET - pot type flywheel and that is this one:
http://www.ebay.co.u...=item35ceda9993
Needs the same ring gear shrinked on and fine balancing afterwards...
#267 Rosssco
Rosssco
  • 4,183 posts
Posted 04 December 2013 - 02:38 PM
G
G
I'm only jesting mate :) As you say, what else has a homebound man to do when suffering from a spiritual and existential funk (and a broken neck) - buy more parts!
#268 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 04 December 2013 - 02:48 PM
G
G
Well it's only money.
Until Naomi finds out. Then it's my neck on the line... :D
#269 CHILL Gone DUTCH
Posted 22 December 2013 - 07:19 PM
1. Chill. 2.2 crank, forged pistons and rods stage 2 LSJ cams,lightened flywheel and balancer delete, home build with vocky input on Dutch ECU software M62 charger ported head. Hoping for 300+  maximum rev 7500 due to M62 charger 2. Graeme. 2.0 Saab B207 with standard pistons and crank, Comp cams, chenge of flywheel (Vectra V6?) which may as well be lightened and balancer delete, plus whatever else Vock recommends (within reason) using M62 and dutch software (or standalone) and I'll be happy with 280-300bhp 3. Westkenbrit. Vocky fettled B207 (ported etc..), 2.2 crank, forged internals, siemens injectors, stage 2 cams (unless advised otherwise by Vocky) uprated clutch, dutch software, harrop, Pro alloy chargecooler, and baffled fuel tank, uprated fuel pump. 350+ But Neil and Joe would know better as they are doing it all 4. Chris. Leave it sat in my back garden until i can be bothered to pull it to bits. 5. Tony. Ornament. Going to collect all the adaptations and that while I decide what to do. 6. Smiley. 2.0 with head exhaust part ported, zzp or comps cams, lightened flywheel, external crank, water injection, harrop and obdtuner. 7. ufods B207r with standard internals,lightened flywheel and balancer delete, extrrnal trigger, Sachs clutch, 3" full Tullet, Siemens 630 injektors, Dutch ECU software Harrop charger Reaching 330 PS without water injektion Still searching for cams            8.Stig_1911    Vocky fettled B207,fully balaced bottom end, eagle rods,Wiseco pisteons,stage 2 zzp stage 2 turbo comps cams,supertec valvespirngs, balancer delete,arp bolts,TMS lighten flywheel, competiton clutch,2 intercoolers(side and roof) Using the 300 bhp dilbert kit as a base, probably dutch software.... goal 350+ bhp
#270 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 22 December 2013 - 07:40 PM
1. Chill. 2.2 crank, forged pistons and rods stage 2 LSJ cams,lightened flywheel and balancer delete, home build with vocky input on Dutch ECU software M62 charger ported head. Hoping for 300+  maximum rev 7500 due to M62 charger 2. Graeme. 2.0 Saab B207 with standard pistons and crank, Comp cams, lightened flywheel, supertech valve springs, balancer delete, ported head, M62 charger, standalone ECU. Yet to decide on exhaust. Hoping for a solid 280bhp.
#271 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 22 December 2013 - 10:26 PM
What's this ecu you're getting then Graeme?
#272 CHILL Gone DUTCH
Posted 28 December 2013 - 07:46 AM
1. Chill. 2.2 crank, forged pistons and rods stage 2 LSJ cams,lightened flywheel and balancer delete, home build with vocky input on Dutch ECU software M62 charger ported head. Hoping for 300+  maximum rev 7500 due to M62 charger, now also putting dbilas springs in 2. Graeme. 2.0 Saab B207 with standard pistons and crank, Comp cams, lightened flywheel, supertech valve springs, balancer delete, ported head, M62 charger, standalone ECU. Yet to decide on exhaust. Hoping for a solid 280bhp.
Uprated spec from chill
Edited by CHILL Gone DUTCH, 28 December 2013 - 07:47 AM.
#273 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 28 December 2013 - 03:43 PM
Hi Tony,
It's coming from Matt Bentley - same as what Lee is having.
G
#274 robin
robin
  • 3,810 posts
Posted 28 December 2013 - 06:55 PM
any further thoughts on flywheel group buy
#275 CHILL Gone DUTCH
Would be nice
#276 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 28 December 2013 - 07:05 PM
Hi Tony,
G
Well done for giving that a punt. Hope it turns out good. I will watch with interest.
#277 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 28 December 2013 - 07:11 PM
Would be nice
+1
#278 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 28 December 2013 - 11:47 PM
I don't want to speak too soon but I believe matt b may be sorting a flywheel if there are enough people interested?
#279 CHILL Gone DUTCH
Posted 29 December 2013 - 07:33 AM
Keep me informed graham
#280 Dominique
Dominique
  • 138 posts
Posted 10 January 2014 - 10:37 PM
Chill, my project is halfway and most ingredients for the power upgrade have been delivered. guess you can add me to the list.
Would be happy if I end up between 280 - 300. But above all it needs to be reliable for track-hollidays across Europe. This is the reason not to go extreme.
9. Dominique,  2.0 Saab B207R with standard pistons/rods, homemade internal trigger wheel, ZZP stage1 cams, TTV flywheel, DBilas valve springs, standard balancer, ported head, M62 with 3.1 pully, 2,5" Tullett system, ProAlloy cooler and fuel tank, Dutch Engine magagement.
Still to decide LSJ/NFS/B207 crank, injectors and clutch.
Also tagged with one or more of these keywords: b207, engine swap, conversion
