You mean the pcv valve in the sc or turbo manifold?
Well that is indeed a real one-way valve to block the boost pressure, compared to the orifice hole of the Z22SE mani
Edited by Exmantaa, 26 January 2014 - 05:27 PM.
Posted 26 January 2014 - 05:25 PM
Posted 26 January 2014 - 06:02 PM
Posted 26 January 2014 - 06:11 PM
Edited by CHILL Gone DUTCH, 26 January 2014 - 06:12 PM.
Posted 26 January 2014 - 06:46 PM
now that i will be opening up the PCV (way) because the round hole in first pic now lines up with the SC manifold will this clog my laminovas ??
Posted 26 January 2014 - 07:25 PM
Posted 26 January 2014 - 07:39 PM
You're one of the first in the UK with the holes lining up, and software to support a working PCV, so who knows.
Have not heared the germans about it so far though, who have the same setup's running. Then again most of these setup's
date from 2013, so may have not have had the manifold off to check yet.
I would still keep a catch tank in place on the rocker cover breather for a while and evaluate what's going on.
Maybe do close the system, by piping the catch tank return back into the air inlet. (no more smels)
Edited by smiley, 26 January 2014 - 07:40 PM.
Posted 26 January 2014 - 07:59 PM
i have just been venting from the cam cover to the rear of the car no catch tank, with the inlet orifice blocked
what im more worried about is what is going back into the inlet manifold where previously it was blocked causing it to blow through cam cover, it will now opened work the other way round (if im understanding this right ) i will be sucking from cam cover and blowing into manifold.
OR HAVE I GOT THIS ALL WRONG
Posted 26 January 2014 - 08:33 PM
It's a bit of a catch22, as we had excessive blowby because we closed the PCV on the Z22SE. Now that it's doing what it should be doing, the question is how much will still be spit out by the rocker cover vent.
I have not heared about the PCV used as an outlet (and that PCV hole in the manoifold is not that big i believe) for oil.
Maybe exmantaa knows from the US forums.
Posted 26 January 2014 - 08:40 PM
the problem with the z22se is that we took away the ability to get clean air in or reduced the vacuum to pull air in, now we are will there be more bad gasses or less
i think it depends on what loads you are driving at where the clean air comes from
Edited by CHILL Gone DUTCH, 26 January 2014 - 08:42 PM.
Posted 26 January 2014 - 08:41 PM
A lot of the US LSJ boys block up the PCV entirely (like we've had for the last 10 years) and vent through the cam cover.
Posted 26 January 2014 - 08:44 PM
this is not good for your engine, and can cause higher build up of the toxic crank gasses which will eventually push past pistons with higher presure
Posted 26 January 2014 - 08:45 PM
maybe its a compromise from engine health and cleaning laminovas once a year
Posted 26 January 2014 - 08:56 PM
The head/manifold pcv route sucks crankcase gasses after the laminova's, so not much clogging. The other hose blows in front of your TB & SC, so fit a decent oil seperator in that hose. (Don't leave it open now, as the pvc then can suck in unfiltered air.
PCV has been discussed some time ago...
Posted 26 January 2014 - 08:59 PM
It's not killed a UK conversion, yet.
They block up the PCV hole with a squirt of sealant, then either use the standard valve cover vent or better yet, increase the size of it (and/or use a vented oil cap) and run it into a catch tank and either route the exit of that back into the inlet or to atmosphere. Sealed system being better.
Posted 26 January 2014 - 09:03 PM
Would it be sufficient to put a small filter on the cam cover vent rather than in front of TBThe head/manifold pcv route sucks crankcase gasses after the laminova's, so not much clogging. The other hose blows in front of your TB & SC, so fit a decent oil seperator in that hose. (Don't leave it open now, as the pvc then can suck in unfiltered air. PCV has been discussed some time ago...
Posted 26 January 2014 - 10:35 PM
Vented oil cap bypasses all the oil seperation steps in the cover, so not a very smart move...
Posted 26 January 2014 - 10:37 PM
Yes, but it should be good quality as it's a direct path into the crankcase, (but only when you have no MAF like the Z22SE ecu)
Edited by Exmantaa, 26 January 2014 - 10:38 PM.
Posted 26 January 2014 - 10:45 PM
Posted 26 January 2014 - 10:49 PM
Where have you connected the cam cover pipe toI'm running the Dutch software with a working pcv. While there's manifold pressure there shouldn't be any oil entering the laminovas as that is the inlet for fresh air, vapours are pulled through the usually blocked pcv port on the manifold, after the laminovas. No issue with running it so far. No nasty smells, reduced oil consumption.
General Discussion →
VX220 Discussion →
Opel Speedster Turbo Z20LehStarted by mementaurum , 15 May 2017 ![]() |
VX220 Discussion →
Headlight Question - Beam PatternStarted by JDS , 03 Apr 2017 ![]() |
The Market Place →
Group Buy Room →
Baffled Sump - Guaging InterestStarted by Matthew Bentley Racing Ltd , 14 Dec 2016 ![]() |
The Market Place →
Car Parts For Sale →
B207 Lightweight FlywheelsStarted by Matthew Bentley Racing Ltd , 09 Dec 2014 ![]() |
The Market Place →
Group Buy Room →
Flywheels - B207 And Z22 - InterestStarted by Matthew Bentley Racing Ltd , 04 Feb 2014 ![]() |
