B207 Saab Conversions
b207 engine swap conversion
960 replies to this topic
#321 CHILL Gone DUTCH
Posted 26 January 2014 - 10:53 PM
I will be running the vacuum pump of the cams from the b207 for brake vacuum pipe Could I use this for cam cover??
#322 techieboy
Posted 26 January 2014 - 11:03 PM
Vented oil cap bypasses all the oil seperation steps in the cover, so not a very smart move...
Agreed. Certainly needs to be plumbed straight into a oil separator. Not sure if Sticky has seen any leakage from his modified oil cap, though he's ITB so may have less of an issue anyway.
Maybe a job for the LSJ vacuum pump. :lol:
#323 techieboy
Posted 26 January 2014 - 11:06 PM
vapours are pulled through the usually blocked pcv port on the manifold, after the laminovas.
And injected back into the inlet manifold before the last laminova through the tube shown in this pic.
#324 Exmantaa
Posted 26 January 2014 - 11:32 PM
"After or before" are getting a bit mixed up here. Can we agree that the pcv valve vents the gasses on the cyl. head side of the manifold, so "after" if we look in air flow direction.  :happy:
#325 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 27 January 2014 - 07:00 AM
Not sure if Sticky has seen any leakage from his modified oil cap, though he's ITB so may have less of an issue anyway.   :
None, all good so far. :)
#326 CHILL Gone DUTCH
Posted 27 January 2014 - 10:47 AM
Cheers for all comments and advice, Going to purchase a oil separator for the cam cover and then check laminovas after a year and see how we are getting on. Hopefully the extra clean air will help the laminovas being clogged up Will also put a filter after the oil separator and see how we get on
#327 smiley
Posted 27 January 2014 - 12:51 PM
IIRC all clogged up laminova´s came from car´s with plugged PCV´s and rocker cover venting into air or catchtank.
All contamination came from poor clean air filtering.
Let´s see what happens now we start using the PCV.
#328 CHILL Gone DUTCH
Posted 15 February 2014 - 05:33 PM
Engine is in the car
#329 smiley
Posted 15 February 2014 - 07:13 PM
What is that?
#330 CHILL Gone DUTCH
Posted 15 February 2014 - 07:22 PM
Pipe clips
#331 oakmere
oakmere
  • 2,143 posts
Posted 16 February 2014 - 01:36 AM
What is the pipe for? Not std. Are you going to tidy up the fuel carbon filter pipes up? Engine looks nice and shiny, good progress.
#332 CHILL Gone DUTCH
Posted 16 February 2014 - 05:30 AM
It's the header tank pipe, I think It's not in the right position yet the engine is mounted with nothing connected yet
#333 vocky
Posted 16 February 2014 - 09:54 AM
it's the fuel tank vent valve breather, I always shorten them by cutting off the end section with 250mm of hose still attached (not sure of exact length) and then fit that to the charcoal filter - so remove the white elbow and original rubber hose from the plastic fitting, which easily unclips from the charcoal filter to make life easier
Edited by vocky, 16 February 2014 - 09:55 AM.
#334 CHILL Gone DUTCH
Posted 16 February 2014 - 02:16 PM
Just been out to check it's the pipe which goes to the header tank
#335 CHILL Gone DUTCH
Posted 16 February 2014 - 02:18 PM
It looks like it's going towards the fuel filler in the pic but it was just tucked up there
#336 oakmere
oakmere
  • 2,143 posts
Posted 16 February 2014 - 11:49 PM
The vent pipe is the one below. As Vocky says shorten it and remove the plastic box (not the large carbon filter). Think I just needed a Y connector but I think it may of been because I broke one. Let me know if you are not sure what to remove.
#337 CHILL Gone DUTCH
Posted 17 February 2014 - 07:15 AM
I'm Of most of this week Martin so I'm hoping to get it running soon please pop in and take a look
#338 CHILL Gone DUTCH
Posted 17 February 2014 - 05:19 PM
The saab oil cooler is a royal pain in the Ar$e
#339 smiley
Posted 17 February 2014 - 07:17 PM
Sorry to hear that, but it's a clear message to the rest of us who have not passed that point yet.
I will be using the oem oil cooler thumbsup
#340 CHILL Gone DUTCH
Posted 17 February 2014 - 07:19 PM
you have to modify all the coolant hoses,
main ones and heater circuit,
Also tagged with one or more of these keywords: b207, engine swap, conversion
