it could be because the ignition is set very safe
as indicated here from peter
http://www.obdtuner....ic.php?f=10&t=9
Posted 22 February 2014 - 09:05 PM
Posted 22 February 2014 - 09:07 PM
Just email Peter to verify that you're on a 2.2.
Posted 22 February 2014 - 09:09 PM
he specifically told me its the first saab with the 2.2 crank as he was giving me the calibration
Posted 22 February 2014 - 10:28 PM
Gonna go bang in the first 50 miles is what i heard. Wanna hold on to my engine crane till you have done 51
Posted 22 February 2014 - 10:51 PM
The dutch heads are FINALLY back from the porter guy.
Especially the exhaust ports needed quite some work, as the flow seems to be designed for turbo.
We can also finally start thinking about putting it back together.
Happy Days.
Posted 22 February 2014 - 11:39 PM
Posted 23 February 2014 - 09:55 AM
I've dropped peter a email just to confirm the map, I'm reluctant to use scan gauge other than reading fault codes I keep getting misfires when it's connected not many but it does happenChis have you got your scan gauge set up to show long term fuel trims? If so it will show large positive increases during the first 50 mile running in. +10 to +25 if the map is lean. See below for scanguage info: https://www.verboom....016/xgauge.html
Posted 23 February 2014 - 03:30 PM
Maybe because of your cams. You can ask peter to make it idle in Alpha-n mode.
You already made a log? gives you a lot of info.
What headgasket did you fit? Wiseco compression is with a 1mm gasket if I remember correctly...
Posted 23 February 2014 - 03:47 PM
Will be strarting the running in process next friday when i tax the car (dont want to lose a month)
after i have done at least 100 miles i will be doing logging sessions and fuel learn sessions
used the standard saab gasket if i remember correctly. Dont know how thick it is
Posted 23 February 2014 - 03:55 PM
Saab gasket is about 1mm, so you're on 8.9CR.
Next time/engine fit a Z22 gasket that is ~0.5mm and raises CR to ~9.3 on the Wiseco's. Better for an SC...
Posted 23 February 2014 - 04:03 PM
i thought it was better to have lower compression on forced induction because of thermal effects, ( only what i have read)
if you can give me a short lesson on compression i would appreciate it.
Posted 23 February 2014 - 04:47 PM
An SC is very bad at delivering higher boost pressure, so the quest with an SC is to make your power with at least boost as possible. There is something mentioned in an SC thread of someone who lost some power after fitting the low CR WSiseco's and had to change pulleys to get that back...
Posted 23 February 2014 - 04:57 PM
Posted 23 February 2014 - 05:10 PM
Posted 23 February 2014 - 05:13 PM
What size pulley are you using Chris ?
Posted 23 February 2014 - 05:14 PM
3.1 for now
Posted 23 February 2014 - 05:26 PM
just had a reply from peter concerning the leaner map,
Hi Chris,
Thanks for the update.
You are right, the new calibration is a little bit leaner. The reason for this is I want to be sure it is not over fueling and washing away the oil film from the cylinder walls which would be very bad for a new engine. The ECU will automaticaly compensate if the calibration is to lean so there is no risk for running lean. Having said this I would advise to do an easy fuel learning as soon as possible, so no full throttle or high revs necessary, just cruising with the ECU in fuel learning mode. Also in this mode the ECU does correct the fuel mixture so no lean running and you will have a decent calibration for further running in your new engine.
I am very interested in how the stage 2 cams are working on your engine if you have some log files or fuel learning files I would be very happy to have a look at them.
[color=#000000;]which sounds ok to me[/color]
Posted 23 February 2014 - 05:30 PM
The larger the pulley the cooler it will run as the SC is making less boost. Not sure where the sweet spot will be regarding compression as the higher the compression the less advance you can run. I guess we will find out with the various builds going on at the minute. May be I should put a SC on my high compression build running low boost to see what happens?
you really want a supercharger dont you martin. bite the bullit
Edited by CHILL Gone DUTCH, 23 February 2014 - 05:31 PM.
Posted 23 February 2014 - 06:45 PM
Posted 23 February 2014 - 06:49 PM
No plans to sell the VX so you never know. I don't like doing things the easy way so will probably end up putting a Rotrex on just to be different!
i have a manifold you can have
General Discussion →
VX220 Discussion →
Opel Speedster Turbo Z20LehStarted by mementaurum , 15 May 2017 ![]() |
VX220 Discussion →
Headlight Question - Beam PatternStarted by JDS , 03 Apr 2017 ![]() |
The Market Place →
Group Buy Room →
Baffled Sump - Guaging InterestStarted by Matthew Bentley Racing Ltd , 14 Dec 2016 ![]() |
The Market Place →
Car Parts For Sale →
B207 Lightweight FlywheelsStarted by Matthew Bentley Racing Ltd , 09 Dec 2014 ![]() |
The Market Place →
Group Buy Room →
Flywheels - B207 And Z22 - InterestStarted by Matthew Bentley Racing Ltd , 04 Feb 2014 ![]() |
