B207 Saab Conversions
b207 engine swap conversion
960 replies to this topic
#441 ufods
ufods
  • 235 posts
Posted 30 July 2014 - 07:42 AM
๐Ÿ˜ƒ thank you frank!
#442 CHILL Gone DUTCH
Posted 30 July 2014 - 08:50 AM
My 1270 goes on easy without phenolic spacer
#443 smiley
Posted 05 October 2014 - 03:19 PM
Can't find the original topic on pcv, but prommised to check my system some time ago.
My pcv is open, with a catchtank in between.
It has now done at least 1000 miles of which most spent on track.
The catchtank is empty.
The air inlet has a minimum of oil smear visible.
Engine has no oil consumption.
So mine is staying open.
:tt:
Edited by smiley, 05 October 2014 - 03:23 PM.
#444 CHILL Gone DUTCH
Posted 05 October 2014 - 03:21 PM
http://www.vx220.org...-options/page-7
#445 smiley
Posted 05 October 2014 - 03:25 PM
Thanks chinky chinky
#446 CHILL Gone DUTCH
Posted 27 November 2014 - 12:33 PM
Just had a thought to the 2.0 brigade would you be able to use the trigger wheel in the B207 and program a aftermarket ecu to interoperate the z22se trigger pattern ??
#447 Kieran McC
Kieran McC
  • 3,416 posts
Posted 27 November 2014 - 01:02 PM
You might beable to with the Dutch software.After my proplems with the CS soft ware and external trigger wheel on 2.0 Good luck ๐Ÿ˜‚
#448 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 27 November 2014 - 01:15 PM
Aftermarket ECU will accept whatever trigger wheel pattern is available
#449 Exmantaa
Posted 27 November 2014 - 02:20 PM
Not sure what you mean here? Use a seperate circuit to transform the B207 signal into the Z22SE signal??
#450 CHILL Gone DUTCH
Posted 27 November 2014 - 03:05 PM
Yes sort of translator
#451 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 27 November 2014 - 03:39 PM
Chris is confusing me as well... If you're using standard 2.0 with internal trigger wheel and standalone ecu then it all works fine
#452 Exmantaa
Posted 27 November 2014 - 03:59 PM
He wants a "black box" that he can connect between B207 standard engine's trigger sensor and the Z22SE ecu connector....
And off course foolproof, 20yrs lifetime and costs a fiver... :happy:
(But yes, we also thought about a circuit that translates 58-2 into a 6-1 patterns with the right trigger timing. Should be doable for a steady state condition, but when you think about misfire detection with the engine's acceleration & decelleration behaviour this becomes pretty complicated...  :wacko:  (experts feel free to chime in here.)
Much easier to install a mechanical translator. (aka as external triggerwheel) Or fit a suitable 58-2 management (aka LSJ ecu)
We looked into the Saab Trionic ecu, but Trionic T8 suite for the B207 is not yet so far developed/cracked as the earlier T5 & T7 stuff that is fully open
#453 CHILL Gone DUTCH
Posted 27 November 2014 - 04:04 PM
Exmantaa, on 27 Nov 2014 - 3:59 PM, said:
He wants a "black box" that he can connect between B207 standard engine's trigger sensor and the Z22SE ecu connector.... And off course foolproof, 20yrs lifetime and costs a fiver... :happy:   (But yes, we also thought about a circuit that translates 58-2 into a 6-1 patterns with the right trigger timing. Should be doable for a steady state condition, but when you think about misfire detection with the engine's acceleration & decelleration behaviour this becomes pretty complicated...  :wacko:  (experts feel free to chime in here.)   Much easier to install a mechanical translator. (aka as external triggerwheel) Or fit a suitable 58-2 management (aka LSJ ecu) We looked into the Saab Trionic ecu, but Trionic T8 suite for the B207 is not yet so far developed/cracked as the earlier T5 & T7 stuff that is fully open
๐Ÿ‘
#454 smiley
Posted 27 November 2014 - 04:23 PM
Engine open, and trigger wheel swap is the cleanest option.
One of the germans posted this yesterday, bought from a tuner.
Somebody just needs to bite the bullet and get one made (with option for multiples in the future).
The costs would then be custom trigger wheel, new studs, gasket and depending on skill; labor.
Edited by smiley, 27 November 2014 - 04:26 PM.
#455 slindborg
Posted 27 November 2014 - 04:29 PM
thats actually quite a task for steady state too... sure a couple of cycles in and you can sort it but I reckon its still a huge job to sort and wouldnt be ideal.
Cant mr Peter offer tweaked software? or has he not got that far into it
#456 techieboy
Posted 27 November 2014 - 04:34 PM
I've had a couple of quotes. Not cheap, certainly as a one off due to the programming costs. Need to speak to Geary's machine shop man and see what he can do.
Are Hitec selling that internal trigger wheel now? Any costs? The only reason why my B207 is sat in black plastic wrapper is due to me not wanting an external trigger wheel but not being able to make my mind up about what ECU to invest in to keep it all internal.
#457 slindborg
Posted 27 November 2014 - 04:36 PM
Megasquirt :lol: whats wrong with a D-sub 25 way connector for automotive engine control? :lol:
#458 techieboy
Posted 27 November 2014 - 04:40 PM
Funnily enough, that's the only one I haven't looked at. Though I did read there's now a version with CAN and an OBD port of some form but anything that isn't certified waterproof and able to withstand an engine bay gets seriously marked down. :wacko:
#459 slindborg
Posted 27 November 2014 - 04:43 PM
CAN has been on the table for a while, but its sh*t CAN being CANOPEN, which is a virus like VBA :lol:
#460 techieboy
Posted 27 November 2014 - 04:49 PM
No DBW support still though, I assume? Is CANOPEN bad then? I'm sure it doesn't compare to an OEM implementation but it's got to be better than not having a multiplexing option and I guess any of the posh aftermarkets all run a cobbled together option anyway. Seems to be mostly Ford based from what I briefly read a few weeks back.
Also tagged with one or more of these keywords: b207, engine swap, conversion
