I've had what ever came with the engine all year with no issues Glad I askedAs above, but see how you go. If you get stuttering/misfires then gap them down. Was recommended 7-8mm, went with 7.5 and no more problemsStandard b207 plugs are 1.2 mm gap. This is way to big
B207 Saab Conversions
#481
Posted 27 December 2014 - 02:29 PM
#482
Posted 04 January 2015 - 09:53 AM
#483
Posted 04 January 2015 - 10:02 AM
Edited by ultimate, 04 January 2015 - 10:02 AM.
#484
Posted 04 January 2015 - 10:03 AM
#485
Posted 04 January 2015 - 11:20 AM
#486
Posted 21 March 2015 - 09:38 PM
3.1 pulley
90% mapped still a little more to do
Just updated
2. Graeme. 2.0 Saab B207 with standard pistons and crank, Comp cams, lightened flywheel, supertech valve springs, balancer delete, ported head, M62 charger, standalone ECU. Yet to decide on exhaust. Hoping for a solid 280bhp.
3. Westkenbrit. Vocky fettled B207 (ported etc..), 2.2 crank, forged internals, siemens injectors, stage 2 cams (unless advised otherwise by Vocky) uprated clutch, dutch software, harrop, Pro alloy chargecooler, and baffled fuel tank, uprated fuel pump. 350+
But Neil and Joe would know better as they are doing it all
4. Chris. Leave it sat in my back garden until i can be bothered to pull it to bits.
5. Tony. Ornament. Going to collect all the adaptations and that while I decide what to do.
6. Smiley. 2.0 with head exhaust part ported, zzp or comps cams, lightened flywheel, external crank, water injection, harrop and obdtuner.
7. ufods
B207r with standard internals, TTV lightened flywheel and balancer delete, external trigger, Sachs clutch, 3" full Tullet, Siemens 630 injektors, Dbilas valve springs, ZZP Stage 1 cams, Dutch ECU software
Harrop charger
Aiming 330 PS without water injektion
8.Stig_1911
Vocky fettled B207,fully balaced bottom end, eagle rods,Wiseco pisteons,stage 2 zzp stage 2 turbo comps cams,supertec valvespirngs, balancer delete,arp bolts,TMS lighten flywheel, competiton clutch,2 intercoolers(side and roof) Using the 300 bhp dilbert kit as a base, probably dutch software.... goal 350+
9. Dominique, 2.0 Saab B207R with standard pistons/rods, homemade internal trigger wheel, ZZP stage1 cams, TTV flywheel, DBilas valve springs, standard balancer, ported head, M62 with 3.1 pully, 2,5" Tullett system, ProAlloy cooler and fuel tank, Dutch Engine magagement.
Still to decide LSJ/NFS/B207 crank, injectors and clutch.
10. Martin S
2.0 , Trigger wheel, new flywheel, stage 2 cams, new clutch, uorated fule pump dutch software. Its just when can it/should it be done?
11. Kieran
B207 Conversion all done by CS map Klassen / CS, M62 charger 2.9" pulley, TTV Fly wheel ,6 speed gear box with a Mocul oil cooler and scavenger system, External trigger wheel
I've just updated my spec due to maxing out the 470 CC VXR injectors
12. Bargi Saab head and Sump... is that enopugh to be called a conversion?
13. Ultimate complete saab with oem internals, dbilas springs, balancer delete, fast road cams, harrop+70mm pulley, water injection. Revlimit 7700, runningk this since January 2013, 10k km, but engine uses much oil now.
Never measured HP in the last Evolution but car runs 11.1 on the quarter mile and 7s 100-200km/h GPS[/quote]
#487
Posted 22 March 2015 - 05:13 AM
#488
Posted 29 March 2015 - 09:18 AM
Edited by CHILL Gone DUTCH, 29 March 2015 - 09:23 AM.
#489
Posted 20 April 2015 - 12:53 PM
Hi all I'm after a set of plugs for my B207 Harrop build, what do you guys recommend I'm not getting a misfire or anything but something has changed since changing pump any thoughts on this will be much appreciated The car just dosent seem as keen as it was And data supports what I'm feeling, But the car isn't running lean now Which might the the reason Or I'm getting used to it
Did you decide on plugs in the end Chill?
#491
Posted 20 April 2015 - 01:03 PM
Not ngk BKR8EIX?
G
#492
Posted 20 April 2015 - 01:08 PM
Edited by CHILL Gone DUTCH, 20 April 2015 - 01:08 PM.
#493
Posted 20 April 2015 - 01:17 PM
3.1 pulley
This is after changing my collapsing air filter
( on old map )
Next stage is fitting LS4 TB and new filter and a full remap
7. ufods
Harrop charger
8.Stig_1911
10. Martin S
11. Kieran
#494
Posted 08 May 2015 - 12:47 PM
#495
Posted 08 May 2015 - 01:02 PM
Yes, but on LSJ ecu and a 2.0 Saab lump.
Did you/Vocky dial them in with calipers? (And checked the base circle diameter? Known issue with a batch of ZZP cams, but that affects mostly idle + low end)
#496
Posted 08 May 2015 - 01:12 PM
#497
Posted 16 June 2015 - 09:54 PM
3.1 pulley with LS4 and big air filter
7. ufods
Harrop charger
8.Stig_1911
10. Martin S
11. Kieran
#498
Posted 16 June 2015 - 09:55 PM
7. ufods
Harrop charger
8.Stig_1911
10. Martin S
11. Kieran
#499
Posted 07 July 2015 - 11:05 AM
Okay, time for an update.
My car is now mapped, and running. Still some tweaks to be done, maybe get a few more horses out of it, but I think we've hit an acceptable figure. The proof will come when I can actually drive it on the road, and see what the driveability is like, and down the line when we can add the launch control and TC tweaks.
My spec has changed slightly though, so detailed below
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]1. Chill. 2.2 crank, forged pistons and rods stage 2 LSJ cams,lightened flywheel and balancer delete, home build with vocky input on Dutch ECU software Harrop charger ported head. now also putting dbilas springs in, 630cc injectors 3" exhaust & 450lph fuel pump[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]3.1 pulley with LS4 and big air filter[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]2. Graeme. 2.0 Saab B207 with custom forged pistons but standard crank and rods,[/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;] Comp stg2 cams, lightened flywheel, supertech valve springs, balancer delete, ported head, harrop charger, standalone ECU. 2.5-inch tullet manifold mounted to 3-inch MBR twin silencer exhaust. Was hoping for a solid 280bhp at the fly with previously posted M62 setup, have made a little more than that with the harrop.[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;] [/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]3. Westkenbrit. Vocky fettled B207 (ported etc..), 2.2 crank, forged internals, siemens injectors, stage 2 cams (unless advised otherwise by Vocky) uprated clutch, dutch software, harrop, Pro alloy chargecooler, and baffled fuel tank, uprated fuel pump. 350+[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]But Neil and Joe would know better as they are doing it all[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]4. Chris. Leave it sat in my back garden until i can be bothered to pull it to bits.[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]5. Tony. Ornament. Going to collect all the adaptations and that while I decide what to do.[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]6. Smiley. 2.0 with head exhaust part ported, zzp or comps cams, lightened flywheel, external crank, water injection, harrop and obdtuner.[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]7. ufods[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]B207r with standard internals, TTV lightened flywheel and balancer delete, external trigger, Sachs clutch, 3" full Tullet, Siemens 630 injektors, Dbilas valve springs, ZZP Stage 1 cams, Dutch ECU software[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]Harrop charger[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]Aiming 330 PS without water injektion[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]8.Stig_1911[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;] Vocky fettled B207,fully balaced bottom end, eagle rods,Wiseco pisteons,stage 2 zzp stage 2 turbo comps cams,supertec valvespirngs, balancer delete,arp bolts,TMS lighten flywheel, competiton clutch,2 intercoolers(side and roof) Using the 300 bhp dilbert kit as a base, probably dutch software.... goal 350+[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]9. Dominique, 2.0 Saab B207R with standard pistons/rods, homemade internal trigger wheel, ZZP stage1 cams, TTV flywheel, DBilas valve springs, standard balancer, ported head, M62 with 3.1 pully, 2,5" Tullett system, ProAlloy cooler and fuel tank, Dutch Engine magagement.[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]Still to decide LSJ/NFS/B207 crank, injectors and clutch.[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]10. Martin S[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]2.0 , Trigger wheel, new flywheel, stage 2 cams, new clutch, uorated fule pump dutch software. Its just when can it/should it be done?[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]11. Kieran[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]B207 Conversion all done by CS map Klassen / CS, M62 charger 2.9" pulley, TTV Fly wheel ,6 speed gear box with a Mocul oil cooler and scavenger system, External trigger wheel[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]I've just updated my spec due to maxing out the 470 CC VXR injectors[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]12. Bargi Saab head and Sump... is that enopugh to be called a conversion?[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]13. Ultimate complete saab with oem internals, dbilas springs, balancer delete, fast road cams, harrop+70mm pulley, water injection. Revlimit 7700, runningk this since January 2013, 10k km, but engine uses much oil now. [/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]Never measured HP in the last Evolution but car runs 11.1 on the quarter mile and 7s 100-200km/h GPS[/color]
#500
Posted 21 July 2015 - 06:21 PM
3.1 pulley
Just updated
7. ufods
Harrop charger
8.Stig_1911
10. Martin S
11. Kieran
14.Artic monkey
Also tagged with one or more of these keywords: b207, engine swap, conversion
General Discussion →
VX220 Discussion →
Opel Speedster Turbo Z20LehStarted by mementaurum , 15 May 2017 ![]() |
VX220 Discussion →
Headlight Question - Beam PatternStarted by JDS , 03 Apr 2017 ![]() |
The Market Place →
Group Buy Room →
Baffled Sump - Guaging InterestStarted by Matthew Bentley Racing Ltd , 14 Dec 2016 ![]() |
The Market Place →
Car Parts For Sale →
B207 Lightweight FlywheelsStarted by Matthew Bentley Racing Ltd , 09 Dec 2014 ![]() |
The Market Place →
Group Buy Room →
Flywheels - B207 And Z22 - InterestStarted by Matthew Bentley Racing Ltd , 04 Feb 2014 ![]() |
