1. Chill. 2.2 crank, forged pistons and rods stage 2 LSJ cams,lightened flywheel and balancer delete, home build with vocky input on Dutch ECU software Harrop charger ported head. now also putting dbilas springs in, 630cc injectors 3" exhaust & 450lph fuel pump
3.1 pulley
90% mapped still a little more to do
Just updated
2. Graeme. 2.0 Saab B207 with standard pistons and crank, Comp cams, lightened flywheel, supertech valve springs, balancer delete, ported head, M62 charger, standalone ECU. Yet to decide on exhaust. Hoping for a solid 280bhp.
3. Westkenbrit. Vocky fettled B207 (ported etc..), 2.2 crank, forged internals, siemens injectors, stage 2 cams (unless advised otherwise by Vocky) uprated clutch, dutch software, harrop, Pro alloy chargecooler, and baffled fuel tank, uprated fuel pump. 350+
But Neil and Joe would know better as they are doing it all
4. Chris. Leave it sat in my back garden until i can be bothered to pull it to bits.
5. Tony. Ornament. Going to collect all the adaptations and that while I decide what to do.
6. Smiley. 2.0 with head exhaust part ported, zzp or comps cams, lightened flywheel, external crank, water injection, harrop and obdtuner.
7. ufods
B207r with standard internals, TTV lightened flywheel and balancer delete, external trigger, Sachs clutch, 3" full Tullet, Siemens 630 injektors, Dbilas valve springs, ZZP Stage 1 cams, Dutch ECU software
Harrop charger
Aiming 330 PS without water injektion
8.Stig_1911
Vocky fettled B207,fully balaced bottom end, eagle rods,Wiseco pisteons,stage 2 zzp stage 2 turbo comps cams,supertec valvespirngs, balancer delete,arp bolts,TMS lighten flywheel, competiton clutch,2 intercoolers(side and roof) Using the 300 bhp dilbert kit as a base, probably dutch software.... goal 350+
9. Dominique, 2.0 Saab B207R with standard pistons/rods, homemade internal trigger wheel, ZZP stage1 cams, TTV flywheel, DBilas valve springs, standard balancer, ported head, M62 with 3.1 pully, 2,5" Tullett system, ProAlloy cooler and fuel tank, Dutch Engine magagement.
Still to decide LSJ/NFS/B207 crank, injectors and clutch.
10. Martin S
2.0 , Trigger wheel, new flywheel, stage 2 cams, new clutch, uorated fule pump dutch software. Its just when can it/should it be done?
11. Kieran
B207 Conversion all done by CS map Klassen / CS, M62 charger 2.9" pulley, TTV Fly wheel ,6 speed gear box with a Mocul oil cooler and scavenger system, External trigger wheel
I've just updated my spec due to maxing out the 470 CC VXR injectors
12. Bargi Saab head and Sump... is that enopugh to be called a conversion?
13. Ultimate complete saab with oem internals, dbilas springs, balancer delete, fast road cams, harrop+70mm pulley, water injection. Revlimit 7700, runningk this since January 2013, 10k km, but engine uses much oil now.
Never measured HP in the last Evolution but car runs 11.1 on the quarter mile and 7s 100-200km/h GPS
14.Artic monkey: Saab B207 with OEM internals, diblas springs, balancer delete, LSJ stage 2 cams, harrop+2.95" pulley (harrop group buy). Rev limit 7k.
B207 Saab Conversions
#501
Posted 21 July 2015 - 06:52 PM
#502
Posted 21 July 2015 - 06:55 PM
3.1 pulley
Just updated
7. ufods
Harrop charger
8.Stig_1911
10. Martin S
11. Kieran
BASE MAP
Edited by CHILL Gone DUTCH, 21 July 2015 - 06:59 PM.
#503
Posted 20 September 2015 - 07:25 PM
#504
Posted 20 September 2015 - 08:04 PM
#505
Posted 21 September 2015 - 07:27 AM
#506
Posted 21 September 2015 - 07:46 AM
#507
Posted 21 September 2015 - 07:54 AM
I have nearly the same hardware as Stuart. Only Stage 1 cams and 80mm pulley. I had no Problems with dip stick. My PCV works. Head PCV goes to free air. Try checking the oil level?
We did suspect high oil levels in the engine early in the day
so we dropped the oil and replaced it and filled the oil to half way up the markers on the dip stick, we still had the issue with the dip stick blowing out
which dip stick did you use and where do you fill it up to ??
#508
Posted 21 September 2015 - 07:56 AM
we put in 5 litres after the oil change ( would expect there was still a bit of oil left in the car ) so maybe 5.5 litres in the car after oil change
Edited by CHILL Gone DUTCH, 21 September 2015 - 07:56 AM.
#509
Posted 21 September 2015 - 07:57 AM
have you blocked up the inlet manifold pcv orifice ??
#510
Posted 21 September 2015 - 08:01 AM
#511
Posted 21 September 2015 - 08:06 AM
saab dip stick or z22se dip stick ??
thats how we ended up running it but we deffo still have pressure
#512
Posted 21 September 2015 - 08:10 AM
#513
Posted 21 September 2015 - 08:17 AM
What revs do you run and what's your approx power We had to reduce revs which helped with pressureSaab dipstick. Do you checked if the head outlet of the PCV is mayby clogged? I have no other idea why you have pressure?
#514
Posted 21 September 2015 - 08:24 AM
#515
Posted 21 September 2015 - 08:27 AM
#516
Posted 21 September 2015 - 08:32 AM
#517
Posted 21 September 2015 - 08:35 AM
#518
Posted 21 September 2015 - 08:40 AM
#519
Posted 21 September 2015 - 08:47 AM
Edited by CHILL Gone DUTCH, 21 September 2015 - 08:48 AM.
#520
Posted 21 September 2015 - 08:51 AM
Also tagged with one or more of these keywords: b207, engine swap, conversion
General Discussion →
VX220 Discussion →
Opel Speedster Turbo Z20LehStarted by mementaurum , 15 May 2017 ![]() |
VX220 Discussion →
Headlight Question - Beam PatternStarted by JDS , 03 Apr 2017 ![]() |
The Market Place →
Group Buy Room →
Baffled Sump - Guaging InterestStarted by Matthew Bentley Racing Ltd , 14 Dec 2016 ![]() |
The Market Place →
Car Parts For Sale →
B207 Lightweight FlywheelsStarted by Matthew Bentley Racing Ltd , 09 Dec 2014 ![]() |
The Market Place →
Group Buy Room →
Flywheels - B207 And Z22 - InterestStarted by Matthew Bentley Racing Ltd , 04 Feb 2014 ![]() |
