Edited by Kieran McC, 22 September 2015 - 05:36 PM.
B207 Saab Conversions
#561
Posted 22 September 2015 - 05:35 PM
#562
Posted 22 September 2015 - 05:39 PM
Got a answer from Peter Hi Chris, In the OEM software this is set to 35C. For engines with standard internals and the IAT sensor measuring the boost temperature I set this to start at 60C. For engines with stronger internals I nowadays remove this so there will be no ignition retard due to high IAT's. This is also the case with your calibration however this does not mean the ECU will not pull the ignition, there are more systems active which will do this, with the current software version this cannot be disabled. (In ObdTunerPro it will be possible to disable these systems totally) Kind regards, PeterI've asked peter How much retardation is carried out at what temps And also asked about changing them for me Cheers smileyPeter can put in a higher number then 57 to start retarding. (via a map update.) No need to wait for obdtuner pro for that.To keep the car smoother when the temps go up and the ecu starts retarding
#563
Posted 22 September 2015 - 07:02 PM
Edited by ArticMonkey, 22 September 2015 - 07:04 PM.
#565
Posted 22 September 2015 - 08:53 PM
#566
Posted 22 September 2015 - 08:57 PM
Got green seals and think it's the one at the bottoms of the picture.
yep yours had the green seals like the bottom one but the stick stuck down below the end of the tube
#567
Posted 22 September 2015 - 08:59 PM
#568
Posted 22 September 2015 - 09:11 PM
The bottom one is Vx.
when using the saab dipstick, it measured full with 5.5l in it from dry
#569
Posted 22 September 2015 - 09:15 PM
i thought the one with the green seals was the saab
#570
Posted 22 September 2015 - 09:25 PM
Edited by The Batman, 22 September 2015 - 09:27 PM.
#571
Posted 22 September 2015 - 10:37 PM
Dipstick insertion height is different between B207 and Z22SE sump pan, so take note which dipstick (length) you use...
Edited by Exmantaa, 22 September 2015 - 10:38 PM.
#572
Posted 23 September 2015 - 11:12 PM
Hey.
As many i have the ttv underdrive pulley from your groupbuy.
But the belt touches the generator pully.
Zwischenablage01.jpg 204.11KB
10 downloads
I am on 6PK 1300 belt. 1285 i did not get fitting
When i will go for a lower Harrop pulley the belt will totally touches the generator pulley.
Any suggestions?
#573
Posted 24 September 2015 - 06:59 AM
#574
Posted 24 September 2015 - 07:00 AM
#575
Posted 24 September 2015 - 08:54 AM
#576
Posted 24 September 2015 - 09:20 AM
Can you cut the body of the tensioner and weld it back shorter? Or move the locating dowel so it points higher?
#577
Posted 24 September 2015 - 10:40 AM
It is the dipstick TUBE which is a different length
And the earlier Saab dipstick tube is a different length to the later Saab dipstick tube
#578
Posted 24 September 2015 - 10:44 AM
If you use the vx220 dipstick tube the oil level should be kept between minimum and half full on the dipstick.
If you use the later Saab dipstick tube keep the oil level at half full.
If you do a 'z22se' and fill it to max then it will probably burn oil
#579
Posted 24 September 2015 - 01:15 PM
#580
Posted 24 September 2015 - 01:24 PM
When you go smaller pulley you will need a smaller belt So get one small enough to have the tensioner higher upYes, also use a phenolic spacer which moves the Harrop in the wrong direction. The next shorter belt i found was the 1285 which does not fit. The z22se tensioner is the same lenght like the saab. If there was a shorter tensioner i would be the solution
Also tagged with one or more of these keywords: b207, engine swap, conversion
General Discussion →
VX220 Discussion →
Opel Speedster Turbo Z20LehStarted by mementaurum , 15 May 2017 ![]() |
VX220 Discussion →
Headlight Question - Beam PatternStarted by JDS , 03 Apr 2017 ![]() |
The Market Place →
Group Buy Room →
Baffled Sump - Guaging InterestStarted by Matthew Bentley Racing Ltd , 14 Dec 2016 ![]() |
The Market Place →
Car Parts For Sale →
B207 Lightweight FlywheelsStarted by Matthew Bentley Racing Ltd , 09 Dec 2014 ![]() |
The Market Place →
Group Buy Room →
Flywheels - B207 And Z22 - InterestStarted by Matthew Bentley Racing Ltd , 04 Feb 2014 ![]() |
