Mine is a total pile of *%&&, and averaging a litre of oil 'not petrol', every 70 miles. With regards its breathing (more like throwing its guts up) I had the breather pipe fed into the induction and thought the SC must be sucking oil out of the car, so pulled it out and fed it into a water bottle (this caught about a tenth of a litre) so its blowing out of the engine. The engine was carefully run in.
Its slower than the old engine even though it has stage 2 cams, a smaller pulley, bigger better exhaust, better air filter and everything else you can throw at it, and when it got hot, it got even slower. I was hitting about 120 down the straight (125-130 last year on ecotec) but when hot 110 and simply will not go over 7000 revs even though the limiters at 7500.
Then the new pipework of the saab set up that feeds coolant to the header tank broke in half.
Its a marvellous thing the Saab engine conversion.
Martin S
