B207 Saab Conversions
b207 engine swap conversion
960 replies to this topic
#661 Exmantaa
Posted 19 October 2015 - 02:07 PM
And the HPT log of the same MAHA run; Peaked at 7623rpm in 5th gear... (logger flatlined above 255)
Not sure how those MAHA rollers measure power/torque applied onto the rollers and if you should/can correct the measured power if the calculated engine rpm is a bit off...
Edited by Exmantaa, 19 October 2015 - 02:09 PM.
#662 CHILL Gone DUTCH
Posted 19 October 2015 - 02:52 PM
1. Chill. 2.2 crank, forged pistons and rods stage 2 LSJ cams,lightened flywheel and balancer delete, home build with vocky input on Dutch ECU software Harrop charger ported head. now also putting dbilas springs in, 630cc injectors 3" exhaust & 450lph fuel pump
3.1 pulley LS4 TB
2. Graeme. 2.0 Saab B207 with standard pistons and crank, Comp cams, lightened flywheel, supertech valve springs, balancer delete, ported head, M62 charger, standalone ECU. Yet to decide on exhaust. Hoping for a solid 280bhp.
spec changed considerably
3. Bill SC. Vocky fettled B207 (ported etc..), 2.2 crank, forged internals, siemens injectors, stage 2 cams (unless advised otherwise by Vocky) uprated clutch, dutch software, harrop, Pro alloy chargecooler, and baffled fuel tank, uprated fuel pump. 350+
But Neil and Joe would know better as they are doing it all,
398 HP RR
4. Chris. Leave it sat in my back garden until i can be bothered to pull it to bits.
5. Tony. Ornament. Going to collect all the adaptations and that while I decide what to do.
6. Smiley. 2.0 with head ported, stage 1 comps cams, lightened flywheel, external crank, M62 with 3.05", 2.5" tullett with oem turdo cat welded in and obdtuner (no ignition timing done yet).
7. ufods
B207r with standard internals, TTV lightened flywheel and balancer delete, external trigger, Sachs clutch, 3" full Tullet, Siemens 630 injektors, Dbilas valve springs, ZZP Stage 1 cams, Dutch ECU software
Harrop charger
Aiming 330 PS without water injektion
8.Stig_1911
 Vocky fettled B207,fully balaced bottom end, eagle rods,Wiseco pisteons,stage 2 zzp stage 2 turbo comps cams,supertec valvespirngs, balancer delete,arp bolts,TMS lighten flywheel, competiton clutch,2 intercoolers(side and roof) Using the 300 bhp dilbert kit as a base, probably dutch software.... goal 350+
9. Dominique, 2.0 Saab B207R with standard pistons/rods, homemade internal trigger wheel, ZZP stage1 cams, TTV flywheel, DBilas valve springs, standard balancer, ported head, M62 with 3.1 pully, 2,5" Tullett system, ProAlloy cooler and fuel tank, Dutch Engine magagement.
Still to decide LSJ/NFS/B207 crank, injectors and clutch.
10. Martin S
2.0 , Trigger wheel, new flywheel, stage 2 cams, new clutch, uorated fule pump dutch software. Its just when can it/should it be done?
11. Kieran
B207 2.0 L Conversion all done by CS  map Klassen / CS, M62 charger 2.9" pulley, TTV Fly wheel ,6 speed gear box with a Mocul oil cooler and scavenger system, External trigger wheel
I've just updated my spec due to maxing out the 470 CC VXR injectors
12. Bargi Saab head and Sump... is that enopugh to be called a conversion?
13. Ultimate complete saab with oem internals, dbilas springs, balancer delete, fast road cams, harrop+70mm pulley, water injection. Revlimit 7700, runningk this since January 2013, 10k km, but engine uses much oil now.
Never measured HP in the last Evolution but car runs 11.1 on the quarter mile and 7s 100-200km/h GPS
14.Artic monkey: Saab B207 with OEM internals, diblas springs, balancer delete, LSJ stage 2 cams, harrop+ 3.05" pulley (harrop group buy). Rev limit 7k.
15. exmantaa
[color=rgb(40,40,40);][font="helvetica;"]- Stock 2.0 LSJ/Saab bottom end (incl.balancers). Lightened 5.8kg cast flywheel.[/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]Exhaust ported head, Stock valves + DBilas springs. ZZP LSJ stage 2 cams, dialed in to spec.  [/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]- Harrop SC + 80mm pulley. 68mm LSJ TB and a closed cone filter intake tract[/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]- manifold + dual pass conversion. Mounted with a Courtenay thermal gasket.[/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]- Stock LSJ pcv system with the valve cover hose routed back to intake tract.[/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]- Tullett 2,5" manifold, 2,5" downpipe with 300cpi cat welded in, 2,5"Tullett muffler, modified for single tip exit.[/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]- LSJ ecu, tuned with HPTuners. Only AFR adjusted to ~11.8AFR on wideband. Still no ignition optimised for max power. (It's enough...  :rolleyes: )[/color][/font]
16.[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]Speedster4fun's[/color]
Another 2.0 + Harrop 80mm on the same MAHA  rollers => Speedster4fun's Z20NET (=B207) engine with HPTuners.
Will look for his engine specs at that time, but the rpm reading was a bit off and so was the power. Basically he had the same specs as my engine, minus the cams and minus balancers, but he had a decat 2,5" downpipe and maybe water injection there.
(run in 5th gear; doing 270Km/h on the rollers    :D ):
Edited by CHILL Gone DUTCH, 19 October 2015 - 02:55 PM.
#663 Rosssco
Rosssco
  • 4,183 posts
Posted 19 October 2015 - 03:08 PM
This thread needs 'cleaned'... :lol:
#664 CHILL Gone DUTCH
Posted 19 October 2015 - 03:17 PM
Should you not be on here ?
#665 techieboy
Posted 19 October 2015 - 03:20 PM
I know. It makes me ill whenever I look at it. :D
#666 siztenboots
Posted 19 October 2015 - 03:29 PM
hpt logs look good, although WB sensor not working?
#667 Rosssco
Rosssco
  • 4,183 posts
Posted 19 October 2015 - 03:32 PM
I don't have a B207 conversion.. ;) (well, technically the head is..)
#668 CHILL Gone DUTCH
Posted 19 October 2015 - 03:37 PM
3.1 pulley LS4 TB
398 HP RR
7. ufods
Harrop charger
8.Stig_1911
10. Martin S
Documented issues in other thread
11. Kieran
15. exmantaa
16.[color=rgb(40,40,40);][font="helvetica;"]Speedster4fun's[/color][/font]
Another 2.0 + Harrop 80mm on the same MAHA  rollers => Speedster4fun's Z20NET (=B207) engine with HPTuners.[/color][/font][color=rgb(40,40,40);][font="helvetica;"]
Will look for his engine specs at that time, but the rpm reading was a bit off and so was the power. Basically he had the same specs as my engine, minus the cams and minus balancers, but he had a decat 2,5" downpipe and maybe water injection there.[/color][/font][color=rgb(40,40,40);][font="helvetica;"]
(run in 5th gear; doing 270Km/h on the rollers    :D ):[/color][/font]
Edited by CHILL Gone DUTCH, 19 October 2015 - 03:38 PM.
#669 Exmantaa
Posted 19 October 2015 - 04:20 PM
WB not connected during that run, but the dyno AFR sensor indicates that his (road tuned) mixture was spot on 0.8 Lambda. :happy:
Hope I have some engine data of my run tonight.
PS; we really should think of another format/section to document these engine conversions and powerplots, as this becomes too much info for 1 posting. A special tune/power section where each conversion has it's own "topic"? But best is then maybe some sort of prescribed format to keep the postings comparable..  :unsure:
#670 CHILL Gone DUTCH
Posted 19 October 2015 - 04:36 PM
Agreed I'm of work tomoz So will have s go at uploading them That way it should be easier to overlay them and compare
Edited by CHILL Gone DUTCH, 19 October 2015 - 04:37 PM.
#671 CHILL Gone DUTCH
Posted 19 October 2015 - 04:40 PM
Ive posted mine here http://www.dyno-plot...Vx220/index.htm
Edited by CHILL Gone DUTCH, 19 October 2015 - 04:42 PM.
#672 siztenboots
Posted 19 October 2015 - 04:59 PM
simple excel tabular format
#673 Exmantaa
Posted 19 October 2015 - 10:09 PM
Just cluttering this thread a bit more with the dyno plot and 2 HPT log plots of that run, White line marks the  engine data points on the left. (And know I see why my AFR was a bit strange in the lower rpms, as he only gave it full throttle above 3.5K where I get my full power enrichment of11.8AFR):
Logplot @ max rpm:
and the same logplot showing data @ 6100rpm where some knock started:
Edited by Exmantaa, 19 October 2015 - 10:15 PM.
#674 ufods
ufods
  • 235 posts
Posted 20 October 2015 - 02:41 AM
@ Frank
You reached a high number hp regarding the big 80mm pulley
but i am suprised that high power is reached at 6900 RPM
My Harrop makes full Power at 7300 RPM and still rises ( my limiter is normally on 7000 )
#675 Exmantaa
Posted 20 October 2015 - 01:04 PM
@ Frank
As you see I had knock @6100rpm, which retarded my ignition a bit and therefore lowered the power output up top. But that knock was right after my max torque peak, so I probably cannot make anymore torque/power at that point. (Without different fuel and/or water injection. But the AFR mixture does have a small effect on the burn rate...)
Ignition was 15.5° advance at max torque and after the 2 x knock retard it climbed back up again to 12.5°. I can set a bit less advance and lower the torque peak there, which then shifts the power peak to the right, but that's only because less power is made before that rpm... :unsure:
My MAP value is still flatlined around peak torque @ 219KPa, what indicates that exhaust back pressure is still not very restrictive there. But above that rpm, MAP starts to slowly climb up, probably due to my 'small-ish' 2,5" system + 300cpi cat.
Both together makes that it peakes a bit earlier than expected and right after that peak the run was stopped. And I assume that the type of Dyno measurement and drag calculations also make a difference in the curve shape. This was a double roller MAHA testrig.
PS; the torque curve should also be fatter left of that knick @4K rpm, as at that point I finally got full throttle. B)
#676 CHILL Gone DUTCH
Posted 20 October 2015 - 02:43 PM
Have you got your ignition table available Interesting that we are finding peak torque with higher ignition
#677 Exmantaa
Posted 20 October 2015 - 03:54 PM
I will move these graphs over to my yellow project thread, as it becomes a bit too specific. Will make a plot of my current ignition, but the HPTuners table will be a slightly different format than OBDTuner.
#678 CHILL Gone DUTCH
Posted 20 October 2015 - 04:09 PM
#679 CHILL Gone DUTCH
Posted 20 October 2015 - 06:24 PM
Exmantaa (red) V Chill (blue)
Edited by CHILL Gone DUTCH, 20 October 2015 - 06:26 PM.
#680 CHILL Gone DUTCH
Posted 20 October 2015 - 06:47 PM
chill orange
exmantaa blue
smiley red
Also tagged with one or more of these keywords: b207, engine swap, conversion
    Bing (2)
