B207 Saab Conversions
b207 engine swap conversion
960 replies to this topic
#801 smiley
Posted 07 March 2016 - 10:00 PM
send me your file stefan
In the mail.
#802 CHILL Gone DUTCH
Posted 07 March 2016 - 10:08 PM
Cheers stefan ,
see you still haven't got a wideband working ?
and have you got a CAT just wondered as your lambda readings
#803 smiley
Posted 07 March 2016 - 10:14 PM
cat = yes
wideband = not yet
#804 Exmantaa
Posted 07 March 2016 - 10:31 PM
After a long journey of cracked manifold, software problems and issues with my basemap, it's drivable.
Stil long road ahead on mapping, but at least this is what i expected from my 3.1" pully on basemap in the cold.
Cut off should be at 7500 rpm. No idea why and what it's doing that at 7100.
That is a pretty flat torque plateau... Not too shabby for our home brew 2,5" + cat exhaust system. :happy:
ps; max out the OBD rev limiter please
#805 smiley
Posted 07 March 2016 - 10:41 PM
I did. It's set to 7500, but starts to go down at 7100.
Will try again at 7800 (which is the max obdtuner allows) when the tarmac surface allows.
#806 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 08 March 2016 - 08:57 AM
Many of the saab engines seem to just hit a sort of limiter at around 7000.
Martin S
#807 smiley
Posted 08 March 2016 - 09:23 AM
We think it's obdtuner Martin, as Chill has the exact same in his run.
#808 ufods
ufods
  • 235 posts
Posted 08 March 2016 - 09:24 AM
Did you already tune the ignition? Looks great for the moment!
#809 smiley
Posted 08 March 2016 - 09:30 AM
No, basemap. (actually the basemap that was created for the M62) The cold weather is also currently helping it being very generous with the numbers.
In spring/summer at around 20 degrees and optimised ignition should give a more fair real number for seasonal usage. In theory these 2 will create a usable 330 in summer.
Then of course i will need water injection, as the harrop is known to hit 95 degrees inlet on peak usage.
#810 siztenboots
  • 26,613 posts
Posted 08 March 2016 - 10:09 AM
how many rpm does the ignition table go up to , can you change the axis to extend it
#811 smiley
Posted 08 March 2016 - 10:13 AM
Ignition table goes to 7800, same as the limiter.
No extend option. That would require Peter to make an updated version i think.
Edited by smiley, 08 March 2016 - 10:15 AM.
#812 siztenboots
  • 26,613 posts
Posted 08 March 2016 - 10:33 AM
axis data is just another table in the ecu, not the client s/w
#813 smiley
Posted 10 March 2016 - 09:19 AM
Last night put the limiter on 7800, and now the graph goes down at 6800.
I could feel the limiter kicking in way past 7k, (really felt like 7800), yet the output says something else.
Really weird.
#814 CHILL Gone DUTCH
Posted 10 March 2016 - 09:23 AM
Try reading and resetting the codes even if nothing comes up and do a power run straight away May not be a link but worth trying
#815 fezzasus
Posted 10 March 2016 - 09:26 AM
Does increasing the RPM actually do anything or could it just transpose the adjusted map across a fixed RPM range?
#816 CHILL Gone DUTCH
Posted 10 March 2016 - 10:07 AM
smiley has no wideband so unsure how he has fuel map up there , especially during WOT normally you would have to a few runs with a wideband and you apply the fuel changes and smooth it of
#817 TFD
TFD
  • 607 posts
Posted 10 March 2016 - 10:51 AM
@Smiley: I would advise not push the engine without a wideband. You said you run a m62 map on a Harrop now with more boost (correct?). More boost normally results in a lean mixture.
If all the above is correct, this means you have no sight on the actual AFR during WOT/Boost. You can potentially grenade your engine now without knowing.
The AFR is also an influence on horsepower. The different drop-off points from where power drops is certainly a strange thing (I also want to know why), but keep in mind you can also run very lean up top right now (=losing hp).
Not want to be a ****, just some well ment advise.
#818 CHILL Gone DUTCH
Posted 28 March 2016 - 09:57 PM
Any updates happening There has been quite a bit of work going on behind the scenes
#819 CHILL Gone DUTCH
Posted 28 March 2016 - 10:02 PM
I've had quite a good result after some minor issues I've had
Think the dip is traction issues
#820 Bargi
Bargi
  • 4,483 posts
Posted 28 March 2016 - 10:16 PM
Have you tried doing the power run in 3rd gear instead?
Also tagged with one or more of these keywords: b207, engine swap, conversion
