B207 Saab Conversions
#861
Posted 31 March 2016 - 11:34 AM
#862
Posted 31 March 2016 - 11:35 AM
#863
Posted 17 April 2016 - 07:14 PM
#864
Posted 17 April 2016 - 07:24 PM
3.1 pulley LS4 TB
2. Graeme. 2.0 Saab B207 with standard pistons and crank, Comp cams, lightened flywheel, supertech valve springs, balancer delete, ported head, M62 charger, standalone ECU. Yet to decide on exhaust. Hoping for a solid 280bhp.
spec changed considerably
3. Bill SC. Vocky fettled B207 (ported etc..), 2.2 crank, forged internals, siemens injectors, stage 2 cams (unless advised otherwise by Vocky) uprated clutch, dutch software, harrop, Pro alloy chargecooler, and baffled fuel tank, uprated fuel pump. 350+
But Neil and Joe would know better as they are doing it all,
398 HP RR
4. Chris. Leave it sat in my back garden until i can be bothered to pull it to bits.
5. Tony. Ornament. Going to collect all the adaptations and that while I decide what to do.
6. Smiley. 2.0 with head ported, stage 1 comps cams, lightened flywheel, external crank, M62 with 3.05", 2.5" tullett with oem turdo cat welded in and obdtuner (no ignition timing done yet).
7. ufods
B207r with standard internals, TTV lightened flywheel and balancer delete, external trigger, Sachs clutch, 3" full Tullet, Siemens 630 injektors, Dbilas valve springs, ZZP Stage 1 cams, Dutch ECU software
Harrop charger
Aiming 330 PS without water injektion
8.Stig_1911
Vocky fettled B207,fully balaced bottom end, eagle rods,Wiseco pisteons,stage 2 zzp stage 2 turbo comps cams,supertec valvespirngs, balancer delete,arp bolts,TMS lighten flywheel, competiton clutch,2 intercoolers(side and roof) Using the 300 bhp dilbert kit as a base, probably dutch software.... goal 350+
9. Dominique, 2.0 Saab B207R with standard pistons/rods, homemade internal trigger wheel, ZZP stage1 cams, TTV flywheel, DBilas valve springs, standard balancer, ported head, M62 with 3.1 pully, 2,5" Tullett system, ProAlloy cooler and fuel tank, Dutch Engine magagement.
Still to decide LSJ/NFS/B207 crank, injectors and clutch.
10. Martin S
2.0 , Trigger wheel, new flywheel, stage 2 cams, new clutch, uorated fule pump dutch software. Its just when can it/should it be done?
Documented issues in other thread
11. Kieran
B207 2.0 L Conversion all done by CS map Klassen / CS, M62 charger 2.9" pulley, TTV Fly wheel ,6 speed gear box with a Mocul oil cooler and scavenger system, External trigger wheel
I've just updated my spec due to maxing out the 470 CC VXR injectors
12. Bargi Saab head and Sump... is that enopugh to be called a conversion?
13. Ultimate complete saab with oem internals, dbilas springs, balancer delete, fast road cams, harrop+70mm pulley, water injection. Revlimit 7700, runningk this since January 2013, 10k km, but engine uses much oil now.
Never measured HP in the last Evolution but car runs 11.1 on the quarter mile and 7s 100-200km/h GPS
14.Artic monkey: Saab B207 with OEM internals, diblas springs, balancer delete, LSJ stage 2 cams, harrop+ 3.05" pulley (harrop group buy). Rev limit 7k.
NOW A 2.2 and 400+ hp
15. exmantaa
[color=rgb(40,40,40);][font="helvetica;"]- Stock 2.0 LSJ/Saab bottom end (incl.balancers). Lightened 5.8kg cast flywheel.[/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]- Exhaust ported head, Stock valves + DBilas springs. ZZP LSJ stage 2 cams, dialed in to spec. [/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]- Harrop SC + 80mm pulley. 68mm LSJ TB and a closed cone filter intake tract[/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]- manifold + dual pass conversion. Mounted with a Courtenay thermal gasket.[/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]- Stock LSJ pcv system with the valve cover hose routed back to intake tract.[/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]- Tullett 2,5" manifold, 2,5" downpipe with 300cpi cat welded in, 2,5"Tullett muffler, modified for single tip exit.[/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]- LSJ ecu, tuned with HPTuners. Only AFR adjusted to ~11.8AFR on wideband. Still no ignition optimised for max power. (It's enough...
16.[color=rgb(40,40,40);][font="helvetica;"]Speedster4fun's[/color][/font]
Another 2.0 + Harrop 80mm on the same MAHA rollers => Speedster4fun's Z20NET (=B207) engine with HPTuners.[/color][/font][color=rgb(40,40,40);][font="helvetica;"]
Will look for his engine specs at that time, but the rpm reading was a bit off and so was the power. Basically he had the same specs as my engine, minus the cams and minus balancers, but he had a decat 2,5" downpipe and maybe water injection there.[/color][/font][color=rgb(40,40,40);][font="helvetica;"]
(run in 5th gear; doing 270Km/h on the rollers
Edited by CHILL Gone DUTCH, 17 April 2016 - 07:25 PM.
#865
Posted 17 April 2016 - 08:03 PM
1. Chill. 2.2 crank, forged pistons and rods stage 2 LSJ cams,lightened flywheel and balancer delete, home build with vocky input on Dutch ECU software Harrop charger ported head. now also putting dbilas springs in, 630cc injectors 3" exhaust & 450lph fuel pump
3.1 pulley LS4 TB
398 HP RR
6. Smiley. 2.0 with head ported, stage 1 comps cams, lightened flywheel, external crank, Harrop with 3.15", 2.5" tullett with oem turdo cat welded in and obdtuner (no ignition timing done yet).
7. ufods
Harrop charger
8.Stig_1911
10. Martin S
11. Kieran
15. exmantaa
[color=rgb(40,40,40);][font="helvetica;"]- LSJ ecu, tuned with HPTuners. Only AFR adjusted to ~11.8AFR on wideband. Still no ignition optimised for max power. (It's enough...)[/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]Another 2.0 + Harrop 80mm on the same MAHA rollers => Speedster4fun's Z20NET (=B207) engine with HPTuners.[/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]Will look for his engine specs at that time, but the rpm reading was a bit off and so was the power. Basically he had the same specs as my engine, minus the cams and minus balancers, but he had a decat 2,5" downpipe and maybe water injection there.[/color][/font]
[color=rgb(40,40,40);][font="helvetica;"](run in 5th gear; doing 270Km/h on the rollers):[/color][/font]
#866
Posted 17 April 2016 - 08:09 PM
nice cool temps there stefan (smiley )
#867
Posted 17 April 2016 - 08:23 PM
Slightly unfair, as it was 10 degrees Celcius out there during testing.
Things will probably be different during the summer.
#868
Posted 18 April 2016 - 08:47 AM
#869
Posted 18 April 2016 - 12:49 PM
SaturdayWhen did I make 400bhp?
#870
Posted 19 April 2016 - 01:19 PM
Intake temp peaked at 80 yesterday on track (outside temp was about 10 celcius)
So i will be hitting that 95 once summer comes also.
#871
Posted 19 April 2016 - 01:24 PM
#872
Posted 19 April 2016 - 01:27 PM
#873
Posted 19 April 2016 - 01:35 PM
WI is in the planning, but i need to rely on exmantaa or his mate for that.
And i also do not like mid season tinkering, so this may be for next winter.
Plan is to tap off the signal from the injector pulse. Once pro is out (and affordable) i can swap to that, and use actual inlet temp as a trigger)
Will get my map to Peter to change the security dial down from 57 degrees to 80 degrees done though.
I believe that will be a parameter in the pro version, but for now it's a manual change for Peter.
Edited by smiley, 19 April 2016 - 01:37 PM.
#874
Posted 19 April 2016 - 01:44 PM
I might have said this before, but looking at the two dyno printouts from car #15 and #16 , on the maha dyno. But what internal losses are you using?
A completely standard vxt we had on the rollers with my new software made 225 at the wheels, with some more options to improve further.
I think for purposes of clear data, we should only work with at the wheel figures.
#875
Posted 19 April 2016 - 01:58 PM
#876
Posted 19 April 2016 - 02:10 PM
You can plumb in WI based on injector pulse for now, and switch to pro later Chill?
#877
Posted 19 April 2016 - 02:12 PM
#878
Posted 19 April 2016 - 02:15 PM
All my figures are engine power not sure the losses with HArrop I think it take 40 hp to run the charger so could quite high losses on the sc conversionsI might have said this before, but looking at the two dyno printouts from car #15 and #16 , on the maha dyno. But what internal losses are you using? A completely standard vxt we had on the rollers with my new software made 225 at the wheels, with some more options to improve further. I think for purposes of clear data, we should only work with at the wheel figures.
#879
Posted 19 April 2016 - 02:16 PM
As I don't fancy doing it until winter anyway I would rather just use it for now
2 peas in a pot huh.
Edited by smiley, 19 April 2016 - 02:17 PM.
#880
Posted 19 April 2016 - 02:38 PM
Yep 2 bald blokes in a vx/ speedster with a HArrop and not able to go faster2 peas in a pot huh.As I don't fancy doing it until winter anyway I would rather just use it for now
Also tagged with one or more of these keywords: b207, engine swap, conversion
General Discussion →
VX220 Discussion →
Opel Speedster Turbo Z20LehStarted by mementaurum , 15 May 2017 ![]() |
VX220 Discussion →
Headlight Question - Beam PatternStarted by JDS , 03 Apr 2017 ![]() |
The Market Place →
Group Buy Room →
Baffled Sump - Guaging InterestStarted by Matthew Bentley Racing Ltd , 14 Dec 2016 ![]() |
The Market Place →
Car Parts For Sale →
B207 Lightweight FlywheelsStarted by Matthew Bentley Racing Ltd , 09 Dec 2014 ![]() |
The Market Place →
Group Buy Room →
Flywheels - B207 And Z22 - InterestStarted by Matthew Bentley Racing Ltd , 04 Feb 2014 ![]() |
