B207 Saab Conversions
b207 engine swap conversion
960 replies to this topic
#901 CHILL Gone DUTCH
Posted 17 May 2016 - 07:59 PM
yes. That fixed it for me on my 5k rpm issue, but never heared of the rattle thing you're having.
will have to do some swapping around tomoz but i was getting a slight miss on the old coil pack at around 7000 rpms
which was solved by the new one three weeks ago
lets just hope its the springs and caused a vibration on to the metal cover
bloody cars
has anyone looked at individual coils for the b207 z22se combo ?
#902 smiley
Posted 17 May 2016 - 08:15 PM
Not sure our ecu would like a non ion sensing setup. could mean custom loom, lsj ecu and hp tuners. Mayby a bit much to tackle a coilpack issue.
#903 Exmantaa
Posted 17 May 2016 - 10:13 PM
Clearly all your problems are due to the inferior Z22SE engine design... I would not do spent any more effort on this and a.s.a.p. swap over to a B207. MartinS can advice you in this. :D
You can switch over to coil on packs, but if you don't find a solution for the ions sensing cam signal it will no longer do a sequential injection and go batch fire. Made some serious M62 power on Carlos' engine though.
#904 siztenboots
Posted 18 May 2016 - 07:29 AM
Plug gap?
#905 CHILL Gone DUTCH
Posted 18 May 2016 - 07:53 AM
Ok I've been over all of my thoughts with this through the night And after some measuring this morning It is possible that the springs were not touching the plug When I took them out they were significantly more compressed than what they were when they went in, but it's hard to tell the exact length required as they move once locating them in then boot I've not tried it yet as its still quite early But as soon as 9 am comes I will try it And fingers crossed it was the issue I also think it would help if we could put somthing under the GM ally plate we use to keep the coil pack down as there potentially a bit of play with that after fastening down
#906 CHILL Gone DUTCH
Posted 18 May 2016 - 07:54 AM
@ sizeten gaps are fine
#907 vocky
Posted 18 May 2016 - 12:41 PM
I have some 10mm foam under the alloy coil pack cover, just to stop any vibration
#908 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 18 May 2016 - 04:26 PM
You can drill 2 holes in coil pack to pick up holes to clamp it down
#909 CHILL Gone DUTCH
Posted 18 May 2016 - 05:10 PM
What type of foam did you use vocky ? And Lee got a pick before I go it
#910 vocky
Posted 18 May 2016 - 05:16 PM
it was some 10mm neoprene
something like this https://www.amazon.c...R/dp/B00I46TLSY
#911 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 18 May 2016 - 05:32 PM
I done Bargie's as the ratel was bugging me quite easy to see with b207 cover of I think it was middle right back and front left
#912 Bargi
Bargi
  • 4,483 posts
Posted 18 May 2016 - 06:17 PM
Used a bit of servo hose cut in half lengthways stuck underneath. Also one of the plugs weren't held down enough and sounded like a Scooby :)
#913 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 20 May 2016 - 12:23 PM
I added extra rubber under cover to force the coil pack down better.
Also -
Would these be of any use.
http://www.rksport.c...ct-p/rk-483.htm
Martin S
doh! Too late
Edited by MartinS, 20 May 2016 - 12:24 PM.
#914 CHILL Gone DUTCH
Posted 21 May 2016 - 09:13 AM
Cheers all will pack it out
#915 CHILL Gone DUTCH
Posted 21 May 2016 - 09:14 AM
I added extra rubber under cover to force the coil pack down better.   Also - Would these be of any use.   http://www.rksport.c...ct-p/rk-483.htm   Martin S   doh! Too late
Did you get these Martin and do you know the length of them ?
#916 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 23 May 2016 - 06:43 AM
I didn't get them, but they were found for me and recommended by Vocky as a possible solution to a problem at one time. I didn't get them in the end but with all you've done, thought they might be worth a look by you.
Martin
#917 Exmantaa
Posted 16 October 2016 - 01:19 AM
Quick result of todays MAHA dyno rolling road session and will scan the complete graphs + details later.
Had some major grip problems on the rollers and first part of the graph was not full throttle, but not too shabby for a meazle 2.0.
(dyno rpm/rollers is a bit off; max logged limit was 7781rpm. :happy:)
Edited by Exmantaa, 16 October 2016 - 01:24 AM.
#918 CHILL Gone DUTCH
Posted 16 October 2016 - 07:50 AM
Love a good power grapg to wake up to on a Sunday morning Good stuff frank
#919 Exmantaa
Posted 16 October 2016 - 11:04 AM
Was a bit of a quick test to see what a full 3" system would improve over my 2.5" system. (Besides the extra noise...)
PS; Airfilter temp in the RR booth reached 31*C and my IAT topped at 73*C there. :unsure:
#920 CHILL Gone DUTCH
Posted 16 October 2016 - 11:08 AM
What did it get on the 2.5 inch exhaust Can you overlay the graphs
Also tagged with one or more of these keywords: b207, engine swap, conversion
