B207 Saab Conversions
b207 engine swap conversion
960 replies to this topic
#921 TFD
TFD
  • 607 posts
Posted 16 October 2016 - 11:18 AM
Interested in how much power you put on the ground (not the stated 213 whp obviously..).
Should organise another Dutch dyno day  :grouphug:
#922 Exmantaa
Posted 16 October 2016 - 11:25 AM
We should organise that yeah. :happy:
Power to the wheels is always a bit tricky on that MAHA dyno with the twin rollers. Not too bad on a straight solid axle, but the VX/Speedster with quite some toe-in and loaded with 2 people on the back create quite some loss there.
(Chill; 2.5" graph is 1 page back. Need to overlay the graphs and compare the logged MAP pressures.)
#923 smiley
Posted 16 October 2016 - 12:01 PM
Is that usable with the 2.5" run cut off at 6800?
#924 CHILL Gone DUTCH
Posted 16 October 2016 - 12:20 PM
If your map pressures go down you should be able to get more ignition in
#925 CHILL Gone DUTCH
Posted 08 December 2016 - 09:18 PM
Has anyone got and pics of there b207 block from the top please
#926 CHILL Gone DUTCH
Posted 08 December 2016 - 09:20 PM
Im intrested in the walls around the bores
#927 fezzasus
Posted 08 December 2016 - 09:22 PM
Thanks to vocky
http://imgur.com/a/Inh8a
#928 CHILL Gone DUTCH
Posted 08 December 2016 - 10:29 PM
We're all the blocks Gen 1 blocks then ?
#929 CHILL Gone DUTCH
Posted 08 December 2016 - 10:33 PM
The main reason I ask I spotted this pic
Which is possibly Stefan block and appears to be a later Gen 1 or 2
#930 fezzasus
Posted 08 December 2016 - 10:50 PM
Yes.
#931 fezzasus
Posted 08 December 2016 - 10:51 PM
Looks like it's had new sleeves.
#932 CHILL Gone DUTCH
Posted 08 December 2016 - 10:59 PM
LOoks like a later Gen block to me
#933 smiley
Posted 08 December 2016 - 11:21 PM
B207R from saabpartners.com in the Netherlands.
#934 Exmantaa
Posted 09 December 2016 - 12:43 AM
Looks like a bock stock B207 (gen 1) foam cast press-sleeve engine block to me... :happy:
Maybe you are confused because on that pic the headgasket is lying on top of the sleeves??
The B207's do not have the reinforced cast-in sleeves. You need a 2012 sandcast "Gen 3" (actually gen 2.5) for that ands the right versions are all DI-VVT type engines.
#935 CHILL Gone DUTCH
Posted 09 December 2016 - 04:13 AM
Ah Didn't realise the gasket was on there Cheers frank
#936 CHILL Gone DUTCH
Posted 08 January 2017 - 10:42 AM
Yes.
i think the B207 are gen 2
which is not good
and for this reason i am not going to be pushing any further with a smaller pulley
#937 siztenboots
  • 26,613 posts
Posted 08 January 2017 - 12:23 PM
is there a comparison of the piston+rods weight across the ecotec range
#938 CHILL Gone DUTCH
Posted 08 January 2017 - 12:39 PM
[quote name="CHILL Gone DUTCH" post="1899603" timestamp="1483879186"]
The block system seem to be a minefield never mind the internals. 😓
Edited by CHILL Gone DUTCH, 08 January 2017 - 12:40 PM.
#939 CHILL Gone DUTCH
Posted 03 March 2017 - 08:42 PM
Update from me after water injection and pro software without the oem protection
1. Chill. 2.2 crank, forged pistons and rods stage 2 LSJ cams,lightened flywheel and balancer delete, home build with vocky input on Dutch PRO ECU software Harrop charger ported head. now also putting dbilas springs in, 630cc injectors 3" exhaust & 450lph fuel pump
3.1 pulley LS4 TB, 100% water injection
2. Graeme. 2.0 Saab B207 with standard pistons and crank, Comp cams, lightened flywheel, supertech valve springs, balancer delete, ported head, M62 charger, standalone ECU. Yet to decide on exhaust. Hoping for a solid 280bhp.
spec changed considerably
3. Bill SC. Vocky fettled B207 (ported etc..), 2.2 crank, forged internals, siemens injectors, stage 2 cams (unless advised otherwise by Vocky) uprated clutch, dutch software, harrop, Pro alloy chargecooler, and baffled fuel tank, uprated fuel pump. 350+
But Neil and Joe would know better as they are doing it all,
398 HP RR
4. Chris. Leave it sat in my back garden until i can be bothered to pull it to bits.
5. Tony. Ornament. Going to collect all the adaptations and that while I decide what to do.
6. Smiley. 2.0 with head ported, stage 1 comps cams, lightened flywheel, external crank, Harrop with 3.15", 2.5" tullett with oem turdo cat welded in and obdtuner (no ignition timing done yet).
7. ufods
B207r with standard internals, TTV lightened flywheel and balancer delete, external trigger, Sachs clutch, 3" full Tullet, Siemens 630 injektors, Dbilas valve springs, ZZP Stage 1 cams, Dutch ECU software
Harrop charger
Aiming 330 PS without water injektion
8.Stig_1911
 Vocky fettled B207,fully balaced bottom end, eagle rods,Wiseco pisteons,stage 2 zzp stage 2 turbo comps cams,supertec valvespirngs, balancer delete,arp bolts,TMS lighten flywheel, competiton clutch,2 intercoolers(side and roof) Using the 300 bhp dilbert kit as a base, probably dutch software.... goal 350+
9. Dominique, 2.0 Saab B207R with standard pistons/rods, homemade internal trigger wheel, ZZP stage1 cams, TTV flywheel, DBilas valve springs, standard balancer, ported head, M62 with 3.1 pully, 2,5" Tullett system, ProAlloy cooler and fuel tank, Dutch Engine magagement.
Still to decide LSJ/NFS/B207 crank, injectors and clutch.
10. Martin S
2.0 , Trigger wheel, new flywheel, stage 2 cams, new clutch, uorated fule pump dutch software. Its just when can it/should it be done?
Documented issues in other thread
11. Kieran
B207 2.0 L Conversion all done by CS  map Klassen / CS, M62 charger 2.9" pulley, TTV Fly wheel ,6 speed gear box with a Mocul oil cooler and scavenger system, External trigger wheel
I've just updated my spec due to maxing out the 470 CC VXR injectors
12. Bargi Saab head and Sump... is that enopugh to be called a conversion?
13. Ultimate complete saab with oem internals, dbilas springs, balancer delete, fast road cams, harrop+70mm pulley, water injection. Revlimit 7700, runningk this since January 2013, 10k km, but engine uses much oil now.
Never measured HP in the last Evolution but car runs 11.1 on the quarter mile and 7s 100-200km/h GPS
14.Artic monkey: Saab B207 2.2 forged , diblas springs, balancer delete, LSJ stage 2 cams, harrop+ 3.05" pulley (harrop group buy).
15. exmantaa
[color=rgb(40,40,40);][font="helvetica;"]- Stock 2.0 LSJ/Saab bottom end (incl.balancers). Lightened 5.8kg cast flywheel.[/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]Exhaust ported head, Stock valves + DBilas springs. ZZP LSJ stage 2 cams, dialed in to spec.  [/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]- Harrop SC + 80mm pulley. 68mm LSJ TB and a closed cone filter intake tract[/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]- manifold + dual pass conversion. Mounted with a Courtenay thermal gasket.[/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]- Stock LSJ pcv system with the valve cover hose routed back to intake tract.[/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]- Tullett 2,5" manifold, 2,5" downpipe with 300cpi cat welded in, 2,5"Tullett muffler, modified for single tip exit.[/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]- LSJ ecu, tuned with HPTuners. Only AFR adjusted to ~11.8AFR on wideband. Still no ignition optimised for max power. (It's enough...  :rolleyes: )[/color][/font]
16.[color=rgb(40,40,40);][font="helvetica;"]Speedster4fun's[/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]Another 2.0 + Harrop 80mm on the same MAHA  rollers => Speedster4fun's Z20NET (=B207) engine with HPTuners.[/color][/font]
[color=rgb(40,40,40);][font="helvetica;"]Will look for his engine specs at that time, but the rpm reading was a bit off and so was the power. Basically he had the same specs as my engine, minus the cams and minus balancers, but he had a decat 2,5" downpipe and maybe water injection there.[/color][/font]
[color=rgb(40,40,40);][font="helvetica;"](run in 5th gear; doing 270Km/h on the rollers    :D ):[/color][/font]
#940 Exmantaa
Posted 03 March 2017 - 09:47 PM
Water injection working it's magic I see? :happy:
Should update my profile too. This was my MAHA dyno run in october last year (2nd run after 1st had wheel slip and I asked to run it straight into the limiter @8K.)  After this I have worked on ignition timing and it's now closer to 360 with more torque spread, but needs water injection to keep this power on hot track days.
Stock 2.0 B207/SLJ bottom end though :D :
Edited by Exmantaa, 03 March 2017 - 09:49 PM.
Also tagged with one or more of these keywords: b207, engine swap, conversion
