B207 Saab Conversions
#941
Posted 03 March 2017 - 09:51 PM
#942
Posted 03 March 2017 - 09:59 PM
Can you start your runs earlier, so well below 4K? Just to see how the behavior is at lower revs
#943
Posted 03 March 2017 - 10:03 PM
#944
Posted 05 March 2017 - 09:17 PM
#945
Posted 05 March 2017 - 10:12 PM
#946
Posted 08 February 2018 - 04:51 PM
#947
Posted 08 February 2018 - 04:53 PM
400 is the limit for the B207 block
#948
Posted 08 February 2018 - 04:56 PM
Thought you would say that400 is the limit for the B207 block
#949
Posted 08 February 2018 - 05:02 PM
#950
Posted 08 February 2018 - 05:08 PM
Darton sleeves or a GEN 3 block if you want more
#951
Posted 08 February 2018 - 05:10 PM
Maybe somthing I should think about when I have the chains done over the next 3-4 yearsDarton sleeves or a GEN 3 block if you want more
#952
Posted 08 February 2018 - 05:31 PM
This person seems to have found the limit of his @ 480 bhp...
https://www.ebay.co....8.c100675.m4236
#953
Posted 08 February 2018 - 05:57 PM
cracked where the dowels have been fitted, not good
#954
#955
Posted 08 February 2018 - 06:26 PM
I could be totally wrong on this, but I think you may have to do some mods to either the gasket or the head, as I think the coolant channels from the Gen 3 may be slightly different (read somewhere..)I guess I'm on the look out for a cheap astra vxr 2.0 block ( Gen 3 )
#956
Posted 08 February 2018 - 06:27 PM
the main difference is the vvt, the block has two lugs to block off the oilways
so you can fit a non vvt head to a vvt block, but trying to fit a vvt head to a non vvt block might have issues
#957
Posted 08 February 2018 - 06:30 PM
#958
Posted 08 February 2018 - 07:21 PM
so shouldent be a issue using my crank and head in a A20nft (gen 3 block ) from a astra vxr which should equal up to 400 + hp
and my next question will my pistons and rods be ok ( will i need new rings head bolts gaskets etc etc ) and is it worth opening out my exhaust ports while im there to match the exhaust primarys ??
Edited by CHILL Gone DUTCH, 08 February 2018 - 07:22 PM.
#959
Posted 08 February 2018 - 07:44 PM
Careful, you sound perilously close to installing a full turbo engine (and joining the dark side!).
#960
Posted 08 February 2018 - 10:20 PM
Also tagged with one or more of these keywords: b207, engine swap, conversion
General Discussion →
VX220 Discussion →
Opel Speedster Turbo Z20LehStarted by mementaurum , 15 May 2017 ![]() |
VX220 Discussion →
Headlight Question - Beam PatternStarted by JDS , 03 Apr 2017 ![]() |
The Market Place →
Group Buy Room →
Baffled Sump - Guaging InterestStarted by Matthew Bentley Racing Ltd , 14 Dec 2016 ![]() |
The Market Place →
Car Parts For Sale →
B207 Lightweight FlywheelsStarted by Matthew Bentley Racing Ltd , 09 Dec 2014 ![]() |
The Market Place →
Group Buy Room →
Flywheels - B207 And Z22 - InterestStarted by Matthew Bentley Racing Ltd , 04 Feb 2014 ![]() |
