High Flow Sc Inlet Manifold
162 replies to this topic
Poll: Hi flow SC inlet manifold (21 member(s) have cast votes)
How much would you pay?
  1. £400 (5 votes [23.81%])
    Percentage of vote: 23.81%
  2. £600 (9 votes [42.86%])
    Percentage of vote: 42.86%
  3. £800 (4 votes [19.05%])
    Percentage of vote: 19.05%
  4. £1000 (3 votes [14.29%])
    Percentage of vote: 14.29%
Vote Guests cannot vote
#21 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 19 October 2013 - 11:49 AM
when are you due to get it Lee? also you will be ok with the coupe but wonder on a normal boot setup if there will be enough room
Edited by NickB777, 19 October 2013 - 11:50 AM.
#22 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 19 October 2013 - 11:52 AM
As mine is couped it doesn't matter how much I move charger up but will try and make it work for standered cars aswell . Can somebody measure what room you have between charger and boot lid ? The core and frame will be about 88 mm but I was thinking of making it a wedged shape to level it of
#23 CHILL Gone DUTCH
Posted 19 October 2013 - 12:02 PM
if the charger was raised upwards (and levelled off) then possibly another core or two could be installed ?
Yep that's what I am going for pro alloy will be making me one like this
This is what Jamie's and other super charged Honda conversions use instead of lominovers but I will be running both .;-)
Same pump as CC or seperate
Same pump just y it into the cc system
then straight back to the header
Can't help thinking we need to run the water through a cooler first , I think there is a lot of heat transfere from the engine coolant rad at the front of the car, has anyone measured temp before and after laminovas ??
Edited by CHILL Gone DUTCH, 19 October 2013 - 12:13 PM.
#24 NickB787
NickB787
  • 7,813 posts
will do it tomorrow when I get home unless someone does it first m62 also with checking on height available will it have an allowance for the bolt pattern within the case? if it will fit under the boot lid, I wouldn't mind one also Lee
Edited by NickB777, 19 October 2013 - 12:05 PM.
#25 CHILL Gone DUTCH
Posted 19 October 2013 - 12:11 PM
On the M62 there would be around 60mm clearance to standard boot lid From highest point of charger ( engine side )
Edited by CHILL Gone DUTCH, 19 October 2013 - 12:12 PM.
#26 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 19 October 2013 - 12:14 PM
ASAP as I have a intake and charger so will pop to pro alloy and get one made up I have been quoted about £375 After I have one and proved it works I will sell them on . I think it will work well as it will be stoping heat transferring from charger to intake aswell
#27 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 19 October 2013 - 12:24 PM
Yes it will be the same shape as the gasket so it all bolts up together and will have to make a extension for the waist gate hole aswell
#28 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 19 October 2013 - 12:26 PM
Might be to tight as the core itself is 66mm ,is that dead tight or could you trim boot lid at all ?
#29 CHILL Gone DUTCH
Posted 19 October 2013 - 12:27 PM
With a dremel you should get a other 5mm
#30 CHILL Gone DUTCH
Posted 19 October 2013 - 12:29 PM
Maybe we should have the charger outside the engine cover like the Americans
#31 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 19 October 2013 - 12:36 PM
Or fit a raised boot lid ;-) or even coupe the rear lol
#32 NickB787
NickB787
  • 7,813 posts
doesn't sound good for a Harrop then
#33 CHILL Gone DUTCH
Posted 19 October 2013 - 12:42 PM
Has anyone measured temps before and after laminovas
#34 Rosssco
Rosssco
  • 4,183 posts
Posted 19 October 2013 - 12:53 PM
Not sure if anyone in the UK has, but you could perhaps use a combination of the Dutch firmware upgrade to monitor post laminova temps, and some other form of measurement hooked up to a port in the spacer plate for pre-laminova temps..
Also, use the plate to water injection no?
http://shop.zzperfor...acer-Plate.aspx
#35 CHILL Gone DUTCH
Posted 19 October 2013 - 12:58 PM
How thick is that plate
#36 Rosssco
Rosssco
  • 4,183 posts
Posted 19 October 2013 - 01:08 PM
Says 1/2"..
#37 NickB787
NickB787
  • 7,813 posts
Posted 20 October 2013 - 08:38 AM
maybe Robin can do some of the raised boot lids for us?
#38 alanoo
alanoo
  • 1,324 posts
Posted 20 October 2013 - 08:47 AM
If this can be done on an Honda K20, it can be done on our Ecotecs
Something similar to this I guess
https://www.facebook...58056671&type=1
#39 NickB787
NickB787
  • 7,813 posts
Posted 20 October 2013 - 09:07 AM
That looks good, price is just for the manifold so would we stick with a water cooling or air? anyone dropped him a line to see if he can do one for us? he could just an lsj for a template, wonder where to place the Tmap sensor? also they say the inlet is 2.5 diameter
#40 nicollow
nicollow
  • 3,801 posts
Posted 20 October 2013 - 09:38 AM
Surely it need to be water cooled, not air. Water kicks the sh*t out air in terms of thermal conductivity and heat capacity...
Looks like a nice piece of kit though, and something similar with a decent air to water heat exchanger must surely be possible
