I've spent a bit of time looking at the numbers for this and the first thing that struck me is how far off the map everyone is running from the boost pressures from in the b207 thread people are running pressure ratios 2.4 not including the loss of the CC, meaning the efficiency will be well below 60% and that SC power consumption will be something like 80bhp meaning people are already at a crank power of 400bhp! Therefore the amount of heat your going to need to shift will be more like that for a 500 bhp turbo car.
![Posted Image](http://www.eaton.com/ecm/groups/public/@pub/@eaton/@per/documents/content/ct_127898.gif)
This gives two problems you actually need a lot of heat exchanger to cool that on the engine side and the quantity of cores would cost more than most people have put they would pay before you even get to the cost of a casting for the main manifold. Also from the work I did with Chris on the Europa the ProAlloy pre rad will struggle with that quantity of heat, and really need the front end cooling redesigning as well.
if the charger was raised upwards (and levelled off) then possibly another core or two could be installed ?
Yep that's what I am going for pro alloy will be making me one like this
![Posted Image](http://i474.photobucket.com/albums/rr102/leevx220/null-79.jpg)
This is what Jamie's and other super charged Honda conversions use instead of lominovers but I will be running both .;-)
Same pump as CC or seperate
Same pump just y it into the cc system
Not really sure it's worth comparing the SC Honda's are only 300bhp on an engine that can make 230 in NA so will be running low boost and at a much more efficient part of the compressor map.
There are also a couple of flaws in what you are doing firstly the flow doesn't exit straight so close coupling a core is going to mean not all of it will be used and will restrict the flow from the SC. You shouldn't split the cooling flow as you'll have no control over the flow split and will also drop the flow speed that controls the heat transfer. You should run the coolant flow through the laminovas first and then the new CC core.
