![Photo](http://www.vx220.org.uk/forums/uploads/av-3792.jpg?_r=0)
High Flow Sc Inlet Manifold
#121
Posted 01 February 2014 - 06:07 PM
#122
Posted 01 February 2014 - 06:40 PM
#123
Posted 01 February 2014 - 07:06 PM
#124
Posted 01 February 2014 - 07:24 PM
![:lol:](http://www.vx220.org.uk/forums/public/style_emoticons/default/laugh.png)
#125
Posted 01 February 2014 - 07:50 PM
Bit like your mount
You wasn't supposed to tell him. Nicked that aswell lol
Well, I'd rather you did just tell me... At least Joe brought it back - I didn't even know what it was!
Well everyone knows you're tight, so shouldnt brake the bank.
Just don't tell Helen how much it costs. Or Naomi for that matter. Joe nearly dropped it today when he suggested he thought I was doing my whole project with the cash from the sale of my Tubby, including buying the SC VX in the first place
#126
Posted 03 February 2014 - 12:37 AM
#127
Posted 06 February 2014 - 05:53 PM
![Posted Image](http://i474.photobucket.com/albums/rr102/leevx220/BB51CFCA-24C5-4163-9EAD-B4E0E44B0A83.jpg)
![Posted Image](http://i474.photobucket.com/albums/rr102/leevx220/8A0269E7-0A8F-4590-B58A-2BC2E5401BDB.jpg)
![Posted Image](http://i474.photobucket.com/albums/rr102/leevx220/7340F533-AA28-402A-A535-18CAFA801818.jpg)
![Posted Image](http://i474.photobucket.com/albums/rr102/leevx220/5F3C23CA-0E49-4D15-BBA3-14FDF7E0A0E9.jpg)
#128
Posted 06 February 2014 - 06:29 PM
#129
Posted 06 February 2014 - 07:03 PM
Run car on dyno with it on and with it of and compare inlet temps ;-)How do you plan to test how effective it is?
#130
Posted 06 February 2014 - 07:16 PM
#131
Posted 06 February 2014 - 07:36 PM
I would need to get hold of a muncher raised boot to see if it would work I think it would :-).How much does it stick out the engine bay? Would a muncher raised boot (like Kieran's) do the job or would it need the hinged area to be adapted?
#132
Posted 06 February 2014 - 07:39 PM
#133
Posted 06 February 2014 - 07:48 PM
#134
Posted 06 February 2014 - 08:15 PM
How are you going to plumb it in dude? 2nd cc system?
wouldn't bother with that, increase in CC temp is minimal so just plumb in series.
#135
Posted 06 February 2014 - 08:20 PM
#136
Posted 06 February 2014 - 09:06 PM
Looks good Mr Lee, hope you just left it attached to that car?
G
#137
Posted 06 February 2014 - 10:46 PM
#138
Posted 07 February 2014 - 08:45 AM
Open to suggestions I was going to Y Split it from the existing cc system .
I personally would not do that. Flowing fluids and gasses, like most things in nature, tend to want to take the path of least resistance, so unless both directions have equal resistance then the one with the higher resistance will likely be starved of flow. That is, unless the pump is pushing around so much flow that even the 'low resistance' path is still a significant enough restriction (resulting in a pressure rise) that the other path gets a good flow.
Coolers in series is guaranteed to get full flow through both of them. Some (K-thermocouple) temperature probes in the CC circuit path at various locations and in the air path at some spots should give a nice data gathering option on how much heat transfer is happening and where.
Edited by Arno, 07 February 2014 - 08:46 AM.
#139
Posted 07 February 2014 - 09:56 AM
#140
Posted 07 February 2014 - 10:01 AM
got to be a better way to package the boost charge to part of the engine bay with more space to work with. So the actual SC manifold adaptor would just a Z chamber to split the SC flow and the return. Probably with pipework on the gearbox side, or a coupe roof intercooler.
