Here is a strange one went to start the car the other day, flat battery so charged it after giving it a boost to put some volts into it, thought there must be a drain somewhere. I went to put it on and do a drain check and found the CC pump was running with the ign off I have removed the relay and had a look without the relay pump was off. Put it back in pump was still off however went for a drive and found now the CC doesn't work. Got to strip it down again as I have moved the boot relays to behind the pax wheel well under the tb pipework, b...r.
Anyone else had any strange things like this? also while I am at it I have a strong fuel smell inside the cabin, nothing in the engine bay and I have not removed the in tank pump either
Edited by NickB777, 24 October 2013 - 03:05 PM.
