new shims are about £12 + vat each from Lotus
Just Some Info/to Be Aware Of - Rear Subframe
#21
Posted 05 January 2014 - 05:43 PM
#22
Posted 05 January 2014 - 05:51 PM
Mine all 'looks' quite clean around that area.
Is it possible to separate the rear subframe without removing the rear clam?
#23
Posted 05 January 2014 - 06:15 PM
Funnily enough this is one of the things we'll be doing when we remove the old engine in mine. Not looking forward to what I may find, but better to find it and get it sorted out than bury my head in the sand.
#24
Posted 05 January 2014 - 06:20 PM
#25
Posted 05 January 2014 - 07:27 PM
Edited by rizo9, 05 January 2014 - 07:27 PM.
#26
Posted 06 January 2014 - 10:11 AM
#27
Posted 06 January 2014 - 05:29 PM
#28
Posted 06 January 2014 - 07:29 PM
Lotus as usual are much cheaper http://www.deroure.c...&SMO=0&ST=&SC=0
#29
Posted 06 January 2014 - 07:32 PM
Anyone?
#30
Posted 06 January 2014 - 07:33 PM
clam off job for sure
#31
Posted 06 January 2014 - 08:01 PM
Anyone?
not really, it would be far easier to simply remove the rear clam and gain access to everything you need to reach.
If you think the rear clam is hard work then don't bother with the subframe, it really is a big job.
#32
Posted 06 January 2014 - 08:16 PM
Ah ok, I wasn't sure if you could remove the boot lid, hoist the engine and separate the two, I was hoping as you don't need to pull the chassis/subframe miles apart to clean and protect it might have been possible.
I'm not all that clued up on the layout of the rear of a VX..........yet
#33
Posted 06 January 2014 - 08:42 PM
Is it difficult fitting everything straight again or does it sort itself out?
#34
Posted 07 January 2014 - 08:50 AM
the subframe bolts to the chassis okay, but the diagonal arms should only be tightened when the car is on it's wheels - not on axle stands.
Otherwise the roof doesn't fit any more, but if you loosen the bars and retighten them all is well again.
Edited by vocky, 07 January 2014 - 08:51 AM.
#35
Posted 07 January 2014 - 08:52 AM
you could cheat and do one side at a time, not sure if that would work, but certainly possible to just replace the shims that way.
#36
Posted 07 January 2014 - 08:53 AM
I'll answer that question when it's back on the road
There is one captive nut which should locate the subframe with a degree of accuracy, although the weight of the subframe prevents precise alignment, I just located the bolts and tightened. It looks straight!
It's certainly a complete strip job, the clam, engine and bottom wishbone locate on both parts.
And thanks Vocky, but I used a Birmingham screwdriver on mine
#37
Posted 10 July 2014 - 04:19 PM
I bumped into one of the D-Type Jag mechanics at Le Mans Classic over the weekend and he happened to be a bit of a VX220 expert and said he had seen a few with this problem. He suggested sealing the seam you can see in the wheel arch with waxoyl or similar to stop water from getting in.
Has anyone done that?
#38
Posted 10 July 2014 - 04:30 PM
It's nothing to do with water, it's galvanic corrosion caused by the contact of the aluminium and a dissimilar metal
#39
Posted 10 July 2014 - 04:52 PM
#40
Posted 10 July 2014 - 05:06 PM
I may be well off here but was chatting to a mate who works on steel boats and he suggested sacrificial annodes , the idea being you attach a lump of more reactive metal to the steel parts (back face of the subframe??) and that encourages the galvanic corrosion to happen there rather than the chassis face.
apparently used on boats all the time when galvanic corrosion is an issue....
anybody know if this could work?
Also tagged with one or more of these keywords: subframe, corrosion
General Discussion →
VX220 Discussion →
Cleaning Aluminium Floors AdviceStarted by Bargi , 02 Aug 2015 corrosion |
The Market Place →
Car Parts Wanted →
Subframe Rear Frame For ChassisStarted by ThiloHarich , 25 May 2014 subframe |
