Just Some Info/to Be Aware Of - Rear Subframe
subframe corrosion
176 replies to this topic
#81 vocky
Posted 10 October 2015 - 06:17 PM
and don't forget to drip some yellow Duralac onto Joe's your drive whilst fitting them :P
#82 The Batman
Posted 10 October 2015 - 07:13 PM
:beat:
#83 Baron Von Scubadaddy
  • 6,644 posts
Posted 10 October 2015 - 07:17 PM
How is the yellow shed ??? all sorted or sauteed
Little cooking joke there  :grouphug:
#84 vocky
Posted 10 October 2015 - 07:26 PM
very poorly :(
#85 ukcat
ukcat
  • 390 posts
Posted 13 October 2015 - 10:29 PM
Just for info oem shims are not zinc plated - Its geomet or dacromet
#86 fezzasus
Posted 14 October 2015 - 09:06 AM
[font="arial, helvetica, sans-serif;"]I said zinc coated, not plated.[/font]
[font="arial, helvetica, sans-serif;"]Both materials you describe are zinc deposition systems.[/font]
[font="arial, helvetica, sans-serif;"]Geomet - Passivated zinc and aluminium flakes in a binder, patented chemistry[/font]
[font="arial, helvetica, sans-serif;"]Dacromet - zinc and aluminum flake in an inorganic binder[/font]
[font="arial, helvetica, sans-serif;"]effectively, still zinc coated.[/font]
#87 ukcat
ukcat
  • 390 posts
Posted 14 October 2015 - 11:38 AM
Yes i agree - Thought people were thinking they were normal zinc electroplated - No probs cheers
#88 GeorgeBC
GeorgeBC
    Needs a cheaper hobby
  • 3,138 posts
Posted 15 October 2015 - 06:43 PM
Shims are on back order from Lotus :(
#89 Raptor
Raptor
  • 942 posts
Posted 30 March 2017 - 01:22 PM
Yep they are still on back order at Lotus :(  I am blasting my current ones.
#90 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 30 March 2017 - 02:18 PM
Blast and zinc rich primer spray � Sent from my SM-G903F using Tapatalk
#91 Raptor
Raptor
  • 942 posts
Posted 30 March 2017 - 02:24 PM
:thumbsup My wishbones, hub carriers and some brackets are away being blasted and zinc plated so these shims are being done at the same time
#92 ditonics
ditonics
    Turbos aren’t as good as NA’s
  • 939 posts
Posted 30 March 2017 - 03:57 PM
My winter project is plating the arms etc. Can you give me an idea of the cost to get them blasted and plated
#93 Raptor
Raptor
  • 942 posts
Posted 30 March 2017 - 04:15 PM
nearest place to me is charging £80 for the blasting and £60 for the zinc plating.  That's dearer than I've seen on some posts on here but I am getting a few more things done at the same time (21 items in total)
#94 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 31 March 2017 - 08:18 PM
So to make this right. Take it apart. Clean the surfaces on the subframe and the Alu chassi. Duralack both sides of the shim and only the shim not the subframe not the chassi. Bolt it together with som new M12×60 screws and before duralack is dried. Then try to seal it from the outside. Are the screws std Hex head and 8.8 quality? Any risk the duralack Will remove the friction? Br,Per
#95 ditonics
ditonics
  • 939 posts
Posted 31 March 2017 - 08:19 PM
Thanks
#96 Raptor
Raptor
  • 942 posts
Posted 31 March 2017 - 08:27 PM
What I've done so far:
cleaned the subframe mating surfaces
Cleaned the chassis mating surfaces and brass brushed the pits etc
Blasted and zinc plated the existing shims as they are not available from Lotus
ordered the lotus bolts (A075W2070Z - M12x60, qty = 4) and 2x nuts
What I am about to do:
duralac both sides of the shims
when duralac is tack dry, fix subframe to chassis
torque bolts/nuts to 45nm
have a beer.
Edited by Raptor, 31 March 2017 - 08:31 PM.
#97 ditonics
ditonics
  • 939 posts
Posted 31 March 2017 - 08:29 PM
Do the bolts have a strength stamped on them?
#98 Raptor
Raptor
  • 942 posts
Posted 31 March 2017 - 08:32 PM
yep just checked my new ones = 8.8 :thumbsup
#99 Raptor
Raptor
  • 942 posts
Posted 31 March 2017 - 08:36 PM
oh and i've sprayed the complete subframe in silver zinc galvanising spray.  It now looks fit to go to space.
#100 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 31 March 2017 - 08:39 PM
Ok sounds Good. Bit 45Nm is a bit low for M12!?
  What I've done so far:   cleaned the subframe mating surfaces Cleaned the chassis mating surfaces and brass brushed the pits etc Blasted and zinc plated the existing shims as they are not available from Lotus ordered the lotus bolts (A075W2070Z - M12x60, qty = 4) and 2x nuts    What I am about to do: duralac both sides of the shims when duralac is tack dry, fix subframe to chassis torque bolts/nuts to 45nm have a beer.
Also tagged with one or more of these keywords: subframe, corrosion
    Bing (1)
