Elise Track Car Build Thread - Have You Lot See This One?
793 replies to this topic
#761 hairy
hairy
    Moonlander
  • 6,030 posts
Posted 11 November 2017 - 10:12 PM
Details?
#762 Mopeytitan
Mopeytitan
  • 1,908 posts
    My dogs (love my dogs).
    F1.
Posted 12 November 2017 - 09:59 AM
It is ashame to see so much work go down the drain! Have to learn from mistakes and sort that exhaust exit out to stop it catching fire. I’m assuming that’s what caused it? I’m putting so much heat shielding in mine to prevent any form of fire and a plumbed in fire extinguisher just to be safe :lol:
#763 turbotoaster
turbotoaster
  • 311 posts
Posted 12 November 2017 - 10:28 AM
oil line split, nothing to do with the exhaust and it had a fia 4.25ltr plumbed in fire extinguisher
#764 Mopeytitan
Mopeytitan
  • 1,908 posts
    F1.
Posted 12 November 2017 - 12:18 PM
I see! That does suck then! Take it was just the oil caught fire then?
#765 turbotoaster
turbotoaster
  • 311 posts
Posted 12 November 2017 - 02:30 PM
yes, steel braided outlet from the oil filter housing got cut and sprayed oil upwards onto the exhaust manifold
#766 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 12 November 2017 - 05:36 PM
So how come the extinguisher didnt work? Ive heard the nozzles melted? Doesnt seem worthy of FIA approval if thats the case.
#767 SteveA
SteveA
  • 9,156 posts
Posted 12 November 2017 - 06:18 PM
It will be a fire suppression system which is primarily there to slow the fire down to allow you to escape.
#768 turbotoaster
turbotoaster
  • 311 posts
Posted 12 November 2017 - 06:20 PM
thats what i thought, i assumed every part would be suitable for the heat of the fire, so i didnt understand why it wasnt working, it was only after talking to malcolm at MSAR about it that he confirmed it to me, makes the foam come out like toothpaste, which is exactly what i had recorded on my phone showing it
#769 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 12 November 2017 - 08:17 PM
#770 CHILL Gone DUTCH
Posted 12 November 2017 - 08:39 PM
Is this car dead yet
#771 hairy
hairy
    Moonlander
  • 6,030 posts
Posted 12 November 2017 - 08:54 PM
Ouch! any idea what cut the hose?
#772 turbotoaster
turbotoaster
  • 311 posts
Posted 15 September 2018 - 01:28 PM
The bolt holding the alternator backed out from heat/vibration and the alternator dropped cutting the pipe.
We live on still
41269155_10155623920661657_6302255673790
37642122_10155528133951657_2611100886289
#773 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 15 September 2018 - 01:32 PM
Yawn
#774 chris_uk
Posted 15 September 2018 - 01:35 PM
you trying to tell us that an alternator vibrating cut through a stainless steel braided hose?
#775 turbotoaster
turbotoaster
  • 311 posts
Posted 15 September 2018 - 02:03 PM
an alternator falling off the engine and landing on the oil line did it
#776 chris_uk
Posted 15 September 2018 - 04:04 PM
Quote:
""yes, steel braided outlet from the oil filter housing got cut and sprayed oil upwards onto the exhaust manifold""
have you changed the mounting of the alternator? as standard its held in place with 2 M10 shanked bolts with 15mm nuts...
the alternator is also right at the bottom of the engine, so you must of run the oil lines underneath it, but if your saying that the alternator "fell off" it points to 2 things, 1.. you didn't bolt the alternator on properly or 2, didn't fit the braided hoses correctly into the fittings and it pulled it out..and for the latter to happen you HAVE to of used the  cheap push fit fittings which should never be used.. ever!
#777 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 15 September 2018 - 05:15 PM
Alternators always cutting my hands on those devilishly sharp buggers!
#778 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Said absolutely nobody. Ever.
#779 turbotoaster
turbotoaster
  • 311 posts
Posted 15 September 2018 - 05:17 PM
the top bolt backed out, i have since changed the setup and added an additional nyloc to ensure it cant back out in the future.
The oil filter housing sits directly below the alternator, and everything has AN fittings and none had come out, just simply split , i dont use push lock fittings.
anyway car is alive, is lighter and makes more power than before
Edited by turbotoaster, 15 September 2018 - 05:18 PM.
#780 bigoldhillsroundhere
  • 53 posts
Posted 15 September 2018 - 06:13 PM
Ah it's good news you've have got the car up and running again, you have informed the local fire brigade right ?
Probably a good idea.
