Elise Track Car Build Thread - Have You Lot See This One?
793 replies to this topic
#781 chris_uk
Posted 16 September 2018 - 01:38 PM
the top bolt backed out, i have since changed the setup and added an additional nyloc to ensure it cant back out in the future.
The oil filter housing sits directly below the alternator, and everything has AN fittings and none had come out, just simply split , i dont use push lock fittings.
anyway car is alive, is lighter and makes more power than before
so let me get this right.. (assuming since you haven't suggested you run an aftermarket mounting system and commented on the top bolt points to a standard system..)
an alternator which is held on by 2 bolts and is tensioned by an integrated alternator tensioner system, somehow loosened the top bolt, tenstioner bolt came all the way out (which is about 30mm)  and rotated around the bottom bolt (which would have to be loose also) and cut an an8 (at a guess, maybe an6) braided hose..
what you are suggesting is that Nut A came loose, the bolt for that nut which is recessed in the mount, C came out enough to give no tension on the belt and then B came loose also and somehow the alternator dropped 3£ and cut through a braided hose..
fcuking please lol..
show us pics of the damaged parts..
#782 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 16 September 2018 - 02:33 PM
And it all happened so quickly that the belt didn't slip at all and put up a battery warning light therefore giving you a signal to stop the car.
#783 tommobot
tommobot
  • 1,008 posts
Posted 16 September 2018 - 04:54 PM
Not getting involved, but I was always strongly advised against nylocs in hot areas..
#784 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 16 September 2018 - 09:08 PM
Chris is on fire tonight! Lol @ pun. Anyway, got to admire your ongoing kicking of this horse. Has the car achieved any notable results in its running life? I’ve got to admit it’s been distracting following its disaster course, and I’m not sure how well it’s been lapping during its sober periods
#785 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 16 September 2018 - 09:11 PM
Yup, conelocks only in the engine bay (either that or proper torque spec)
#786 The Batman
its a drag car now isnt it?
#787 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 16 September 2018 - 09:13 PM
Based on the wing in the pics, I’d have said yeah, but I’ve lost track myself. Not exactly the chassis id pick for drag racing *shrugs*
#788 turbotoaster
turbotoaster
  • 311 posts
Posted 17 September 2018 - 10:13 PM
chris is just angry for some reason, must be because i blocked him on facebook after he asked me lots of private info on messenger last year pretending to be my friend, then posted it all on here, he thinks im lying about the alternator, even though the car did 5 track days with the current braided oil lines without issue.
23561309_10154948519901657_1120473794485
You can see the split in the pipe that sits directly under the alternator and notice the alternator is not mounted to the engine......but of course i could have secretly taken the alternator off and took an angle grinder to the braided hose i suppose....not really sure why but if it helps him sleep at night.
#789 NOSBandit
NOSBandit
  • 271 posts
Posted 17 September 2018 - 11:21 PM
Looks like the alternator shorted out on the braided line.
Sent from my SM-G935F using Tapatalk
#790 turbotoaster
turbotoaster
  • 311 posts
Posted 17 September 2018 - 11:49 PM
that might well have been the case, i hadnt thought about the live cable ontop of the alternator shorting on it and blowing a hole in it, as thinking about it, because it rotated around the lower bolt it would have brought the live cable from above the alternator to below it where the line was
#791 NOSBandit
NOSBandit
  • 271 posts
Posted 17 September 2018 - 11:58 PM
There looks to be a burnt part on the filter housing matching the braided line as well.
#792 The Batman
Posted 18 September 2018 - 04:49 AM
i dunno why you deleted me on facebook either
#793 turbotoaster
turbotoaster
  • 311 posts
Posted 18 September 2018 - 07:19 PM
i deleted 2300 people off my page to take me down to 350 as all i found was things i posted on facebook were then copied and posted onto forums. Basically anybody i didnt speak to within the last few months on there or didnt follow their builds got deleted, made a big difference to my feed as it just left all the cool car stuff as when you have that many people add you, your feed just ends up being full of their personal rubbish you dont care about
#794 chris_uk
Posted 18 September 2018 - 08:49 PM
is that stainless braid? looks like nylon braided hose..
