I have just fitted 215/45/17 AD08R's to front on DTC's if anyone want's to test fit them before buying tyres they are welcome. Making a trip from Cov at weekend if all goes well and you live on route.ish.
Ats Dtc Wheels Now On Sale
#41
Posted 16 December 2013 - 11:11 PM
#42
Posted 17 December 2013 - 11:08 AM
On the German forum there was some good discussion some time ago.
General RSR: 215/45/17 will rub, 215/40/17 wont.
I have no idea though if this was on a lowered VX or not. I'm going for the 215/40/17 & 235/40/17 combo RSR's and an ABS switch.
#43
Posted 17 December 2013 - 11:26 AM
I would go for the 215/40/17 as it has an extra 1mm of tread , 7.5mm , its overall diam is 22mm smaller than the 45 profile
#44
Posted 17 December 2013 - 11:36 AM
As I've said before, when people talk about rubbing it is sometimes only the central rivet for the arch liner, and even then it's only when on full lock. It only happened on mine when reversing into my drive where I had to use full lock, but I was doing about 2 mph. If you can take someone up on an offer like mine above then I would certainly try them before deciding the 45's are no good.
#45
Posted 17 December 2013 - 12:06 PM
Ok this might be a good idea to fill up for future ref on 17" wheels specifically ATS DTC's. Feel free to add more tyres or amend.
Toyo R888
215/45 = 624mm x 216mm --- ( Will rub on arch liner rivets at rear of front wheel, only on full lock, may need a cut out.)
245/40 = 627mm x 250mm --- ( May limit how low you go on the rear of car due to wheel arch, which may lead to arch extensions)
Federal 595RS-R
215/45 = 625mm x 219mm --- (Based dimensions and above these are prob going to rub quite a bit and will require cutouts)
215/40 = 603mm x 222mm --- (Untested but dimensions look favorable, may run into ABS probs if appropriate rear is not used )
235/40 = 619mm x 238mm --- (Best option available in this tyre for rear based on dimensions)
235/45 = 643mm x 240mm --- (Dimensions tell me this is a no go, diameter too big, likely to rub at ride height under 135mm)
Yokohama AD08R
215/45 = ? x ? --- (Currently fitted but not driven yet, best match for 245/40 rear)
205/45 = ? x ? --- (Best match for 235/40 rear)
245/40 = ? x ? --- (Currently fitted but not driven yet, best match for 215/45 front)
235/40 = ? x ? --- (Best match for 205/45 front)
Edited by Crabash, 17 December 2013 - 12:27 PM.
#46
Posted 17 December 2013 - 12:29 PM
Some good information chaps.
Is the AD08R like the R1R, as R1R's really arent the best for trackdays if the sun comes out. Theyre a really great all rounder but you have to do far shorter sessions and they will still wear heavily. Even last week on a very cold day they suffered notably on track.
Can anyone add measurement for the Avon ZZR 215 40 17 and 235 40 17 (thiough I assume similar to the others) as in these sizes theyre only around £120 more than the Federals and almost certainly a more serious track tyre.
Martin s
ps I'm happy to cut away and will probably have to whatever I buy, and on that subjext wheres the best/chepest cut outs as I know some people wree using handle inserts and all sorts.
#47
Posted 17 December 2013 - 12:37 PM
go for the Avons , they will be my next option to try the 255/40/17 rear.
#48
Posted 17 December 2013 - 12:43 PM
I think the AD08R are a good all round tyre for occasional tracking and road use but suspect they will suffer on longer track sessions.
For cut outs see my pic on previous page. Although that did require cutting the arch liner as well.
I can make them wet laid in carbon. I'm not very fast though so don't expect to get them in a couple of days
I would not use the cheapo method and a after looking at mine again I am considering essentially properly building the recess/slight concave curve in to the sill and repainting, liner will then just pull back to that, negating the need to cut into the arch liner as well and will look a lot more OEM ish. It is also in an area that you could get away with a home can spray job.
Edited by Crabash, 17 December 2013 - 12:49 PM.
#49
Posted 17 December 2013 - 12:56 PM
Toyo R888
Federal 595RS-R
Yokohama AD08R
Avon ZZR
215/40 = 604mm x 218mm --- ( ? )
255/40 = 636mm x 260mm --- (Going to require rear arch extensions)
#50
Posted 17 December 2013 - 03:11 PM
They do 235 40 17 Avon ZZR's
Just had email saying wheels are on the way.
Edited by MartinS, 17 December 2013 - 03:11 PM.
#51
Posted 17 December 2013 - 03:47 PM
#52
Posted 17 December 2013 - 09:25 PM
Hopefully mine aren't far behind then Martin.
G
#53
Posted 17 December 2013 - 11:21 PM
How low is your car and do you have arch cut outs?
I do wonder whether I just bite the bullet buy the tyres and if they are too wide on the front deal with it.
I'll more than likely go 235 rears and arch extensions are a no go.
As for 215/40 (22mm difference)??? That seems a hell of a lot for even the 4 channel abs to cope with?
#54
Posted 17 December 2013 - 11:28 PM
I believe abs starts acting up once wheel + tyre difference is more then (or near) 5% from oem.
#55
Posted 18 December 2013 - 12:19 AM
Edited by Crabash, 18 December 2013 - 12:21 AM.
#56
Posted 18 December 2013 - 06:55 AM
#57
#58
Posted 18 December 2013 - 08:24 AM
My mistake. Would have to be 225 rear and 215 fr avon zzr's, guess not a good setup. So best options as defined earlier. I have 4 channel abs but problems with my 888's rubbing on track now but am now prepared that its going to be 215 fronts and some grief.
Toyo R888
Federal 595RS-R
Yokohama AD08R
#59
Posted 18 December 2013 - 11:58 AM
G
Just had an email from them, in German, which I assume says they are on their way.
G
#60
Posted 18 December 2013 - 03:50 PM
yes, me too. They were shipped today.
Also tagged with one or more of these keywords: and they have black., ats dtc, alloy wheels, wheels
The Market Place →
Car Parts For Sale →
Cheap Turbo Alloys On Ebay - Ideal If You Want SparesStarted by karmann , 26 Oct 2020 wheels |
The Market Place →
Team DynamicsStarted by Crufty , 14 May 2020 wheels |
The Market Place →
Na WheelsStarted by SteveB , 04 Nov 2019 wheels |
The Market Place →
18 Inch Td Silver Wheels.Started by Nev , 21 Aug 2019 wheels, td, 18 inch |
The Market Place →
Car Parts Wanted →
Team Dynamics Race Pro 1.2 Wheels WantedStarted by VXPilot , 16 Aug 2019 wheels, tream dynamics and 2 more... |
