Vx220 Seat Options?
127 replies to this topic
#41 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 26 November 2013 - 12:08 PM
Anyone got any pics of retrimmed VX220 seats with harness holes but without the damn universal plastic inserts?
Two that I can think of where ChazUwe's old NA and pretty sure RichyRoff's seats were done by Frogman as well.
Mine does however I have seen my car for 10 weeks so no pics I'm afraid :blush:
#42 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 26 November 2013 - 12:37 PM
The Roffmeister's car
Funnily enough Matt that was one of the first pics to come up on google.
Also quite taken by these ones
But deep down, what I really want is
#43 TazN
TazN
  • 2,931 posts
Posted 26 November 2013 - 12:50 PM
Those last 2 are the same seat but just different retrims...
I've been going over this decision in my head for best part of a year. The lotus motorsport ones don't come up for sale 2nd hand very often and still retain a high price. I personally cant justify nearly £1800 on seats when the originals can be made to look gorgeous for a third of the price. In fact those roffmeister seats have just sold it to me, retrimmed properly and not using those gashtastic plastic inserts the original seats look fine with harness holes if required.
#44 techieboy
Posted 26 November 2013 - 12:53 PM
No, they're different. The second one is obviously the factory Lotus seat. The other one looks like the Corbeau LE Pro seat by the look of it (which looks more like the factory VXR seat).
#45 chris_uk
Posted 26 November 2013 - 01:02 PM
Keep the standard seats and just use harnesses aswell without the holes.
Not safe to do that Chris.
Whys that?
#46 TazN
TazN
  • 2,931 posts
Actually you could be (and probably are! right) I've looked at those corbeau seats plenty of times and wondered how they'd turn out with a retrim.
Saving that roffmeister's pic though and will be speak with DtT and a local place to see what they can do. I know my original seats are comfy though the padding is obviously 10 years old and lost some of the comfort. They fit with the centre console, I have the rails, adjustable there really isn't anything wrong with them for me.
How do people find the alcantara parts on seats wear?Also anyone remind me what the hard wearing material people opt for on the bolsters is called?
#47 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 26 November 2013 - 01:14 PM
Whys that?
Unless they are bolt harnesses they can spread I think?
G
#48 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 26 November 2013 - 06:07 PM
Whys that?
G
Yes, bolt-ins are perfectly safe not through holes.  I use bolt-ons with no cut-outs.  They are great, but are slowly killing the edges of my seat
Wrap-around on the other hand.  No, just no.
Although if you do the physics they are fine, should you plan on only hitting things exactly head-on  :lol:
Edited by VXRed, 26 November 2013 - 06:09 PM.
#49 Kieran McC
Kieran McC
  • 3,416 posts
Posted 26 November 2013 - 06:53 PM
Be wary of those that are entirely composite with bolt through fittings.  There have been a number of breakages which is not ideal in a crash situation!  The good ones have metal load spreaders in the laminate (look at your OE ones, you'll see where they are) which are often sacrificed to save weight.  These are important!
Have you sorted out your GRP seat mounting set up ?
#50 chris_uk
Posted 26 November 2013 - 07:06 PM
Whys that?
G
i probably should of said bolt in ones, as thats what i use and what i pictured when saying it.
#51 JG
JG
  • 13,612 posts
Posted 26 November 2013 - 09:09 PM
those factory seats didn't fit in my vx. they wouldn't clear the headrest things
#52 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 26 November 2013 - 09:15 PM
The factory Exige ones James?
Aren't they just the same shells as those that DTT uses for the VX220 VXR-alike seats?
G
#53 techieboy
Posted 26 November 2013 - 09:22 PM
DtT / Exige carcasses are the same.
The standard VXR seats are not the same and are more like the blue upholstered version above (it may actually be the exact same carcass).
#54 techieboy
Posted 26 November 2013 - 09:28 PM
The CompositeWorx seats are a clone of that carcass too.
There's also the two types that Kieran's mate in Norfolk sells.
#55 JG
JG
  • 13,612 posts
Posted 26 November 2013 - 09:32 PM
G
Yep, they are, but we tried to get to the bottom of it with with part numbers and it appeared that some might have been slightly taller in the head rest.
#56 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 26 November 2013 - 10:13 PM
G
Best make sure I tell Lotus I want the short ones then :D
#57 Bumblebee
Bumblebee
  • 7,592 posts
Posted 26 November 2013 - 10:17 PM
Have you made your mind up then ;)
#58 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 26 November 2013 - 10:18 PM
I'm a Scotsman. Everything comes down to money.
And how sympathetic Lotus are to my broken neck... :D
G
#59 Bumblebee
Bumblebee
  • 7,592 posts
Posted 26 November 2013 - 10:23 PM
Sounds like your showing the Scotsmen how to do it when it comes to spending on the new Vx ;) :)
#60 Hark
Hark
  • 3,443 posts
Posted 26 November 2013 - 11:56 PM
Mine are oem exige probax with cutouts, exactly the same as those in the picture. It was tight on the passenger head rest but mine went in, so must be some difference. I had to modify the centre console slightly as the rails were slightly wider than the standard VX ones.
