Tin snips and pliers not up to the job? If not, my engineering skills are exhausted.
Saab Z22Se External Trigger Wheel
#41
Posted 27 January 2014 - 04:57 PM
#42
Posted 27 January 2014 - 07:04 PM
I have fitted one to a new Saab crank pulley, the face has to be machined for the spacers (which are fitted but not visible in the picture below)
#43
Posted 27 January 2014 - 07:28 PM
Just need to find another supplier for the crank sensor bracket
http://www.webcon.co...xd.asp?id=10095
#44
Posted 27 January 2014 - 07:46 PM
Does that also apply to the LSJ 6-rib pulley?
#45
Posted 28 January 2014 - 05:36 PM
most likely, but it is a five minute job on a lathe
#46
Posted 28 January 2014 - 05:37 PM
I really like the way the crank sensor position is exactly centred on the oil pump TDC mark
What you cannot see is that the z22se crank is in the exact same position to the z22se crank sensor location as this trigger wheel and new crank sensor position
Edited by vocky, 28 January 2014 - 05:39 PM.
#47
Posted 01 April 2014 - 04:44 PM
I have all the trigger wheels here, but currently still trying to source the crank sensor brackets. Plus an extended loom required for the crank sensor (this will just be a male - female style extension lead).
The group buy price will probably have to go up, but that really depends on the final cost of the outsourced bracket manufacture, there is nothing I can do about this
I will update sometime soon
1. Techieboy
2. Tony H
3. Martin S
4. Stig_1911
5. evocarlos
6. Graeme Lambert
7. robin
8. ArcticMonkey
9. NickB777
10. [color=rgb(34,34,34);font-family:'Helvetica Neue', Arial, Verdana, sans-serif;font-size:14px;]sutol[/color]
11. alanoo
12. Co220
list editted, Rossco has sold his car, so guess he doesn't need one anymore.
#48
Posted 01 April 2014 - 05:39 PM
I'll take his place
#49
Posted 04 April 2014 - 09:07 AM
Wouldn't it be easier to mount the crank position sensor off between the two bolts here?
Production would be quicker/cheaper as well as being less susceptible to being bent. Spacing it out for a 6 rib crank would be a case of using a few washers too.
#50
Posted 04 April 2014 - 09:28 AM
because of the alternator belt
#51
Posted 04 April 2014 - 09:34 AM
ah. That's what I get for looking at it without the belt on.
#52
Posted 04 April 2014 - 09:39 AM
and the problem with mounting at the bottom is the wishbone gets rather close to the sensor, before you ask
#53
Posted 04 April 2014 - 09:42 AM
I've worked that one out (slowly )
I guess I should concentrate on getting new cams rather than worrying about this. And if I should be getting springs too.
#54
Posted 04 April 2014 - 09:44 AM
dbilas springs are easier to fit than the supertech double valve springs, not really sure which is better or if both do exactly the same job
#55
Posted 04 April 2014 - 09:49 AM
The dual spring Supertech are theoretically better, but i'm not sure it makes a difference in practice. I understand the Supertech need the roller followers to be ground?
(key bit might be the price - £130 vs. £260)
Edited by fezzasus, 04 April 2014 - 09:50 AM.
#56
Posted 04 April 2014 - 09:54 AM
the Saab has cast roller rockers and these seem to be okay, this is where I think supertech altered the kit. The earlier kit was for the steel roller rockers and the latest kit is for the cast roller rockers, well thats how it seems, but I could be talking total rubbish
Edited by vocky, 04 April 2014 - 09:54 AM.
#57
Posted 04 April 2014 - 10:58 AM
Correct
#58
Posted 04 April 2014 - 12:35 PM
Ask Jon at CS about the problems with mounting the trigger wheel LOL
#59
Posted 04 April 2014 - 02:08 PM
With Neil acting as the gatekeeper between the trigger wheels and myself, I expect it to be a lot easier (at least for me!)
#60
Posted 04 April 2014 - 06:59 PM
We will mount the sensor on the bolt 180* opposite where you've drawn that bracket, but that's not possible on these wheels as they're already clocked on the pulley.
Also tagged with one or more of these keywords: b207, trigger wheel, saab, z22se
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
The Market Place →
Car Parts Wanted →
2.4L Intake Manifold (Gm12587878) For Z22SeStarted by HydroMike , 11 May 2020 ![]() |
General Discussion →
VX220 Discussion →
Dbilas Turbo Kit - Z22SeStarted by Franke , 24 Feb 2020 ![]() |
The Market Place →
Car Parts Wanted →
*urgent* Coil Pack For Z22SeStarted by MattMacc123 , 29 Jul 2019 ![]() |
Tuning & Modifications →
Lighter Z22Se Heatshield And Exhaust WrapStarted by blackoctagon , 17 Jul 2019 ![]() |
