As far as I can see on my 2 sets, the set without helpers were 7" springs and with helpers they put a shorter main spring on or it will foul as you have found. Still amazes me how different nitron dampers for same aplication can be, look at the diff between my randy spec rears and yours....
#21
Posted 02 December 2013 - 09:36 PM
#22
Posted 02 December 2013 - 09:46 PM
As far as JJJ's solution goes, yes it may work but I would not be happy, everyone else seems to have springs this way round so why should I have swap things around after spending all that cash. Just to make something fit that has clearly not been checked. If it was checked and found that the helper had to be below the main then they should assemble it so or include some form of guide.
#23
Posted 02 December 2013 - 09:57 PM
I would say the new springs and helper together are the same length as the old spring. Your picture with the red springs do seem to have very long bodies to them.
Maybe it is as Jimmy says - the helper springs are too wide a diameter.
On your picture of yours on your car, the top of your helper springs do appear lower down than mine is so is less likely to foul the body.
#24
Posted 02 December 2013 - 10:00 PM
Yes and I was going to add helpers to my old ones but was told I would need new main springs to make the correct length, one of the reasons I got the 46's.
#25
Posted 02 December 2013 - 10:05 PM
Just checked my front dampers too and yes the 46's with helpers have a 1" shorter spring than the NTR's with no helper.
The 46's have 5" plus helper on front and 6" plus helper on rear if that helps.
#26
Posted 02 December 2013 - 10:20 PM
I had similar problems when I fitted Crabash old NTR's with some helpers. It's a combination of a spring/helper combo higher up the subframe and the increased wishbone angle that comes with the new droop.
Solved mine "a la Scuffers" with a hammer and a piece of wood; reshaped the subframe slighly where it fouled the spring on the front. And I think I modded the top alloy bolt sleeves so I could move the shock a little more rearwards. (shorten top rearward sleeve and fit an extra washer to the front sleeve)
The joy of modding a VX....
#27
Posted 02 December 2013 - 10:27 PM
Glad you got mine working ok lol, they much better with the helpers then?
#28
Posted 02 December 2013 - 10:28 PM
#29
Posted 02 December 2013 - 10:32 PM
Too much things going on for a good comparison, but the ride is fine now. Next year we will do some serious testing on 2 vx's with those and also some 46's that came along...
#30
Posted 02 December 2013 - 10:59 PM
Does sending in for refurb with larger eyelids automatically include these helper springs?
#31
Posted 02 December 2013 - 11:11 PM
Seems not from Aimy's post.
#32
Posted 03 December 2013 - 08:41 AM
I've had mine done but not fitted them yet as I was waiting for some lock rings (yeah, I'm paranoid). Need to order some helpers too. Keep us posted as to how you get on please.
#33
Posted 03 December 2013 - 09:47 AM
#34
Posted 03 December 2013 - 11:00 AM
Pre refurb and post pictures if any use:
Looking at these pics its a longer bottom eye. This means the spring platform is moved up the body by the same amount (plus any thickness of the helper / platform assembly). Moving it up takes the platform closer to the subframe.
Might be the fix needs to be longer tubes rather than longer eyes? Aimy, you'll need to check yours if your on longer eyes. It might be that the helper length just pushes it over the tolerance threshold.
#35
Posted 03 December 2013 - 11:04 AM
#36
Posted 03 December 2013 - 11:11 AM
Did they replace the nitron stickers for you?
I need 4 new stickers for mine. I've mailed nitron a few times but they never respond...
#37
Posted 03 December 2013 - 11:17 AM
Yeah il check them (although I still need to order som helpers) I'm loosing patience with the whole suspension milarky tbh
If the helpers are causing the problem with a longer eye then it may not be the answer for you. Chin up, it'll come good.
Oh yes, when you send them for refurb they come back with new stickers and look like new shocks. They do an awesome job!
#38
Posted 03 December 2013 - 11:30 AM
tried to scale it as good s possible.
#39
Posted 03 December 2013 - 12:43 PM
I'd sure as hell not be putting the helper springs on the other end.... angled loads etc not nice blah blah
#40
Posted 03 December 2013 - 02:06 PM
How come my tubes are so much longer on both the NTR and the 46's.
Only way I can see to fix that is maybe a different helper thats not as wide and/or a shorter main spring, but even then that would move your adjuster ring right down to the bottom of the damper tube. Would there be enough compression in the spring to achieve full travel?
Is it a good idea to run with the helper seat not around the damper body?
Have you tried winding the adjuster down untill the helper is part compressed, then see if it goes on, if it does where does that leave you on ride height?
Saying all this but really it's nitrons prob as JJJ said, if I were not happy sure I would gather info and look into it but in the end I would be getting on to Nitron.
Edited by Crabash, 03 December 2013 - 02:09 PM.
Also tagged with one or more of these keywords: nitron, ntr40, refurb
