Comp Cams For Saab Conversion
b207 comp cams zzperformance zzp lsj
143 replies to this topic
#21 vocky
Posted 14 December 2013 - 10:14 AM
The compcams L61 (z22se) blower cams are;
intake 252, lift .423
exhaust 256, lift .419
So the ones you have are almost identical to the z22se blower cams
http://www.compcams....?csid=1080&sb=2
Edited by vocky, 14 December 2013 - 10:15 AM.
#22 Exmantaa
Posted 14 December 2013 - 10:48 AM
They are identical profiles as the Comp Blower cams, as the ZZP St2 duration @ .050" Lift is also 210* intake and 212* exhaust.
Have to check if the timing is maybe different.
#23 vocky
Posted 14 December 2013 - 11:46 AM
I have the spec sheets for some comp cams ....
LSJ Stage 2 = Ex - 114, In - 110
Blower = Ex - 114, In - 112
Stage 2 NA = Ex - 112, In - 110
Stage 3 NA = Ex - 114, In - 112
Edited by vocky, 14 December 2013 - 11:49 AM.
#24 CHILL Gone DUTCH
Posted 14 December 2013 - 11:52 AM
Imperial or metric
#25 smiley
Posted 14 December 2013 - 01:53 PM
My ZZP/Comp cam Stage 2 box says:
200-000-5I
Ecotech intake 8758 HR 108.0
(duration 251, lobe sep 108.0, lift .423)
200-000-5E
Ecotech exhaust 8759 HR 117.0
(duration 256, lobe sep 117.0, lift .419)
ZZP/Comp cam Stage 1 box says:
200-999-3I Ecotech intake 8756 HR 102.0 (duration 245, lobe sep 102.0, lift .423)
200-000-5E Ecotech exhaust 8755 HR 117.0 (duration 244, lobe sep 117.0, lift .419)
#26 vocky
Posted 14 December 2013 - 01:56 PM
Imperial or metric
my figuires are Degrees, the lift is measured in imperial
#27 2-20
2-20
  • 1,317 posts
Posted 14 December 2013 - 02:01 PM
Your link is for a stage1 not for the blower cams
#28 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 14 December 2013 - 02:07 PM
Martin, what tax did you have to pay in the end on the cams?
#29 2-20
2-20
  • 1,317 posts
Blower for the Z22se is 113250 not 113200
#30 vocky
Posted 14 December 2013 - 02:08 PM
they have linked the wrong data sheet to the blower cams
if you click on the link in red you get the na cam spec sheet  :glare:
http://www.compperfo...de=CHEV464CAM20
#31 vocky
Posted 14 December 2013 - 02:11 PM
found the correct data sheet on their website http://www.compcams....?csid=1081&sb=0
blower cams
exhaust 262, lift .436
Edited by vocky, 14 December 2013 - 02:12 PM.
#32 2-20
2-20
  • 1,317 posts
Posted 14 December 2013 - 02:13 PM
That's right .... but where are the blower cams spcs ...??
Oups  too slow !
Edited by 2-20, 14 December 2013 - 02:13 PM.
#33 vocky
Posted 14 December 2013 - 02:15 PM
LSJ Stage 2:
Intake 251, lift .423
Exhaust 256, lift .419
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;background-color:rgb(255,255,255);]L61 Blower cams[/color]
So blower cams are better  :ninja:
Edited by vocky, 14 December 2013 - 02:17 PM.
#34 smiley
Posted 14 December 2013 - 02:18 PM
ZZP was friendly to me to put my [font="Arial, 'sans-serif';font-size:10pt;"]$649 cams on the shipping bill for $125 value.[/font]
[font="Arial, 'sans-serif';font-size:10pt;"]My duties were about 10% of the true value. Very happy. :tt: [/font]
Edited by smiley, 14 December 2013 - 02:19 PM.
#35 CHILL Gone DUTCH
Are you sure the ones Martin have are the stage 2 zzp
#36 CHILL Gone DUTCH
Posted 14 December 2013 - 02:20 PM
I thought they should be 258 262
#37 CHILL Gone DUTCH
Posted 14 December 2013 - 02:27 PM
Design Nos 8760 and 8761
#38 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 14 December 2013 - 02:30 PM
ZZP was friendly to me to put my [font="Arial;"]$649 cams on the shipping bill for $125 value.[/font]
[font="Arial;"]My duties were about 10% of the true value. Very happy. :tt: [/font]
How did you get them to do that?
If I go on my zzp account it still says pending shipping?
#39 Exmantaa
Posted 14 December 2013 - 02:55 PM
LSJ Stage 2:
Define "better"...
Depends a lot on what engine you put these in... :happy:
But the Comp blower set (intake profile from their NA-St1 and exhaust from their NA-St2 cams) is more aggressive and this is maybe a bit too much for 2.0l displacement...
(I have a Comp NA 113200 set lying here too, which is basically a ZZP Stage 2 with short exh. cam.   Will compare the cam timing of these.)
I foresee lots of modding this winter. :rolleyes:
#40 vocky
Posted 14 December 2013 - 02:59 PM
Define "better"...
better for max bhp with a 2.2 Harrop   :P
However the LSJ cams are probably ideal for a smooth 2.0 GM sc with about 250/260 bhp  ;)
Also tagged with one or more of these keywords: b207, comp cams, zzperformance, zzp, lsj
