Comp Cams For Saab Conversion
b207 comp cams zzperformance zzp lsj
143 replies to this topic
#61 vocky
Posted 17 December 2013 - 01:39 PM
I have just checked Batman's compcam boxes, they are 8758 and 8759 - which were supposed to be stage 2 LSJ cams.
ZZP need to alter their website as these clearly state 210/212, not 216/218.
ps: Joe you need new cams, these are too mild for a Harrop  :glare:
#62 vocky
Posted 17 December 2013 - 01:42 PM
[color=#000000;][font="arial, sans-serif;"]Answers from zzp re the cams I have been sent. After I sent him the above notes and listd.[/color][/font]
[color=#000000;][font="arial, sans-serif;"]Ok, well I don't see any problems.  8758/8759 are our supercharged stage 2 lobes.  I don't see anything that would suggest otherwis[/color][/font]
[color=#000000;][font="arial, sans-serif;"]-Matt M[/color][/font]
[color=#000000;][font="arial, sans-serif;"][color=#000000;][font="arial, sans-serif;"]Martin- what specs are you comparing that lead you to believe that these are not the right cams?  Based on the numbers you sent in your email below, you have stage 2 supercharged LSJ[/color][/color][/font][/font]
[color=#000000;][font="arial, sans-serif;"]So is it now agreed I have the right stage 2 cams???[/color][/font]
[color=#000000;][font="arial, sans-serif;"]Martin S [/color][/font]
their website lists a cam spec, they have not supplied that spec
#63 CHILL Gone DUTCH
Posted 17 December 2013 - 01:45 PM
[color=#000000;][font="arial;"]Answers from zzp re the cams I have been sent. After I sent him the above notes and listd.[/color][/font]
[color=#000000;][font="arial;"]Ok, well I don't see any problems.  8758/8759 are our supercharged stage 2 lobes.  I don't see anything that would suggest otherwis[/color][/font]
[color=#000000;][font="arial;"]-Matt M[/color][/font]
[color=#000000;][font="arial;"][color=#000000;][font="arial;"]Martin- what specs are you comparing that lead you to believe that these are not the right cams?  Based on the numbers you sent in your email below, you have stage 2 supercharged LSJ[/color][/color][/font][/font]
[color=#000000;][font="arial;"]So is it now agreed I have the right stage 2 cams???[/color][/font]
[color=#000000;][font="arial;"]Martin S [/color][/font]
If mine don't come as advertised on there spec I will be kicking off very aggressively!!!!!!!!
#64 vocky
Posted 17 December 2013 - 01:46 PM
perhaps I'm being stupid, well my brain does feel totally fried, but they quote a spec and when you check that spec it doesn't match does it  :wacko:
It may well be that they changed the spec and didn't alter their website, either way something doesn't seem to add up  :mellow:
However, if they produce the bhp expected then they are fine  thumbsup
Edited by vocky, 17 December 2013 - 01:52 PM.
#65 Exmantaa
Posted 17 December 2013 - 02:10 PM
Did you check at what liftheight ZZP specs their cams??
#66 vocky
Posted 17 December 2013 - 03:12 PM
even that doesn't match Compcams spec sheet.
I think people need to run their engines on a rolling road and see what bhp they get, none of the numbers match and thus it's difficult to understand exactly what spec they really are.
#67 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 17 December 2013 - 03:19 PM
[color=#000000;][font="arial, sans-serif;"]Latest reply in answer to my email, but I really am the worst person top be having these conversations with him about this stuff.[/color][/font]
[color=#000000;][font="arial, sans-serif;"][color=#000000;][font="arial, sans-serif;"]Hi Matt[/color][/color][/font][/font]
[color=#000000;][font="arial, sans-serif;"][color=#000000;][font="arial, sans-serif;"]On your site it states that stage 2 for supercharged cars are -   ZZP S2 is 216/218 @ 1mm and 10.78mm/10.69mm lift, 111 LSA (216 is 8760, 218 is 8761) where as I have 8758 and 8759.[/color][/color][/font][/font]
[color=#000000;][font="arial, sans-serif;"]Oh, I see the confusion.  You are comparing different specs.  On our site, we have the duration listed at 1mm lift, which is the way that GM measures the stock cams.  Comp does not show duration at 1mm lift.  They show duration at .050".  Since 1mm is only .039", the duration is a few degrees higher when using this method.  If you look at the chart you posted, you will see they have duration specs at .006", .050", and .200".  If you added in another column showing duration at .039", you can see that the duration would be higher than it is at .050".  In this case, it is about 6 degrees more at .039"(1mm).[/color][/font]
[color=#000000;][font="arial, sans-serif;"]-Matt[/color][/font]
#68 vocky
Posted 17 December 2013 - 03:27 PM
well whatever was left of my brain just left the building  :mellow:  :lol:
I thought we were talking about duration not lift, but they may alter each other  :blink:
Edited by vocky, 17 December 2013 - 03:28 PM.
#69 CHILL Gone DUTCH
Posted 17 December 2013 - 05:02 PM
Imperial or metric ?? Lol
#70 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 17 December 2013 - 06:19 PM
[color=#000000;][font="arial;"]Latest reply in answer to my email, but I really am the worst person top be having these conversations with him about this stuff.[/color][/font]
[color=#000000;][font="arial;"][color=#000000;][font="arial;"]Hi Matt[/color][/color][/font][/font]
[color=#000000;][font="arial;"][color=#000000;][font="arial;"]On your site it states that stage 2 for supercharged cars are -   ZZP S2 is 216/218 @ 1mm and 10.78mm/10.69mm lift, 111 LSA (216 is 8760, 218 is 8761) where as I have 8758 and 8759.[/color][/color][/font][/font]
[color=#000000;][font="arial;"]Oh, I see the confusion.  You are comparing different specs.  On our site, we have the duration listed at 1mm lift, which is the way that GM measures the stock cams.  Comp does not show duration at 1mm lift.  They show duration at .050".  Since 1mm is only .039", the duration is a few degrees higher when using this method.  If you look at the chart you posted, you will see they have duration specs at .006", .050", and .200".  If you added in another column showing duration at .039", you can see that the duration would be higher than it is at .050".  In this case, it is about 6 degrees more at .039"(1mm).[/color][/font]
[color=#000000;][font="arial;"]-Matt[/color][/font]
 in English please?
Vocky, are the stage2 cams we're getting correct after the above information?
Edited by ArticMonkey, 17 December 2013 - 06:23 PM.
#71 CHILL Gone DUTCH
Posted 17 December 2013 - 06:48 PM
Lets leave batmans thread alone and post here
#72 CHILL Gone DUTCH
Posted 17 December 2013 - 07:03 PM
it looks like the stage 2 cams we have all bought are
inlet         @ 0.039 (1mm) = 216    and @ 0.5  =  163.8
exhaust    @ 0,039 (1mm)= 218 .  and @ 0,5 =  165.3
does anyone have the specs of standard z22se cams
thumbsdown
Edited by CHILL Gone DUTCH, 17 December 2013 - 07:07 PM.
#73 robin
robin
  • 3,810 posts
Posted 17 December 2013 - 07:18 PM
great this sounds like a expensive cock up if they are not right!
#74 CHILL Gone DUTCH
Posted 17 December 2013 - 07:21 PM
cant believe im comparing my new cams to standard z22se
#75 CHILL Gone DUTCH
Posted 17 December 2013 - 08:04 PM
thumbsdown
forget this its wrong
sorry
#76 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 17 December 2013 - 08:14 PM
Confused.com
#77 vocky
Posted 17 December 2013 - 08:15 PM
In English,
zzp are saying that their stage 2 LSJ cams have different specs than those posted on the compcams website, whether that means they are just as good as blower cams will be proven once someone puts their car on a rolling road.
So don't panic  thumbsup
Edited by vocky, 17 December 2013 - 08:16 PM.
#78 oakmere
oakmere
  • 2,143 posts
Posted 17 December 2013 - 08:27 PM
They have given the duration at 1mm 0.39" not at .50" so there site would seem to be correct and you have got there stage 2 cams. These may be milder than the comp blower cams but that is a separate discussion.
#79 CHILL Gone DUTCH
Posted 17 December 2013 - 08:29 PM
im just hoping there not as mild as my z22se cams
#80 vocky
Posted 17 December 2013 - 08:32 PM
which are 244 degree cams and really shite, which makes the stage 1 LSJ cams look brilliant  :P
Also tagged with one or more of these keywords: b207, comp cams, zzperformance, zzp, lsj
