forgive me if im wrong martin (oakmere) but wouldent the duration be higher at 0,05 rather than 0,039
Comp Cams For Saab Conversion
#81
Posted 17 December 2013 - 08:32 PM
#82
Posted 17 December 2013 - 08:35 PM
#83
Posted 17 December 2013 - 08:39 PM
#84
Posted 17 December 2013 - 09:25 PM
Makes no odds to me at the moment, mine still show as being somewhere around the Chicago sorting facility...
Status hasn't changed since 11th Dec :S
#85
Posted 17 December 2013 - 09:42 PM
what if I get Stage 3 cams?
will my engine lose power?
edit: sorry I'll get my coat
Edited by Bargi, 17 December 2013 - 09:48 PM.
#86
Posted 18 December 2013 - 08:38 AM
LOL The confusion...
#87
Posted 19 December 2013 - 10:06 AM
So do I continue the conversation with zz or are we happy these are stage 2. Has no one else recievd theres yet?
Martin s
#88
Posted 19 December 2013 - 10:15 AM
#89
Posted 19 December 2013 - 10:19 AM
They are what they advertise on site Mine have been in uk for nearly a week and still not delivered ??
Whereas mine are still showing as in chicago. ZZP told me that they often take 2 weeks to show as being in the UK due to the USPS tracking system so I'm not unduly worried yet. Weird yours show as being in the uk though.
G
#90
You guys ordered ZZP stage 2 cams and received ZZP stage 2 cams, so what's the fuzz about?
Confusion comes from comparing the ZZP spec sheet (@1mm lift) with the durations listed in the Comp Cam grind sheets (@0.050" lift).
As said here, the difference (or suitability for your particular engine/driving) between ZZP LSJ St2 or the Comp Blower cam set is a different discussion altogether (and a bit late after ordering all the cams... )
#91
Posted 19 December 2013 - 10:42 AM
Yup ZZP say:
"-The Stage 2 cams are the next step, they will raise your powerband about 700-1000rpm, they will make peak power around 7500-7800rpm! They will require an ATI balancer to help reduce engine vibrations at the new high RPMs."
How high are people planning to rev their engines? I'm certainly expecting to stay below 8,000rpm.
G
#92
Posted 19 December 2013 - 10:43 AM
#93
Posted 19 December 2013 - 10:44 AM
I'm still more worried about the base circle diameter problem you mentioned elsewhere. Given the fact my cams have been sat in the garage in their boxes for the last 13 months.
#94
Posted 19 December 2013 - 10:46 AM
That will be against the standard cams not the z22seYup ZZP say: "-The Stage 2 cams are the next step, they will raise your powerband about 700-1000rpm, they will make peak power around 7500-7800rpm! They will require an ATI balancer to help reduce engine vibrations at the new high RPMs." How high are people planning to rev their engines? I'm certainly expecting to stay below 8,000rpm. G
#95
Errrr i may have missed that. whatnow?
#96
Posted 19 December 2013 - 10:48 AM
A few of us bought some comp cams a while ago and may suffer from a duff batch that were made. The duff batch have a larger diameter base circle so hold the valve open a touch all the time. This causes rubbish running. Base circle should be 30mm IIRC (see Joes adventure no 2 project thread)
#97
Posted 19 December 2013 - 10:49 AM
Shouldn't affect you, as you've got (presumably) cams from the latest production run. Exmantaa was saying (in Joe's thread) that 12-18 months ago, CompCams manufactured a batch of incorrectly sized cams that prevented the valves fully closing.Errrr i may have missed that. whatnow?
#98
Posted 19 December 2013 - 10:54 AM
So in otherwords these will be slightly better rather than massively better than the Z22se cams?
Ok, thanks for clarifying guys.
#99
Posted 19 December 2013 - 10:56 AM
No idea what the specs are for standard Z22SE cams or for that matter B207R cams and B207whateverthefcuk cams you've already got in your new engine.So in otherwords these will be slightly better rather than massively better than the Z22se cams?
#100
Posted 19 December 2013 - 11:03 AM
fcuk it, they're shiny and new, and cost a lot of money. Job's a good 'un!
Also tagged with one or more of these keywords: b207, comp cams, zzperformance, zzp, lsj
The Market Place →
Group Buy Room →
Baffled Sump - Guaging InterestStarted by Matthew Bentley Racing Ltd , 14 Dec 2016 ![]() |
The Market Place →
Car Parts For Sale →
B207 Lightweight FlywheelsStarted by Matthew Bentley Racing Ltd , 09 Dec 2014 ![]() |
The Market Place →
Group Buy Room →
Flywheels - B207 And Z22 - InterestStarted by Matthew Bentley Racing Ltd , 04 Feb 2014 ![]() |
General Discussion →
Tuning & Modifications →
Projects →
Project 'once'Started by Graeme Lambert , 24 Jan 2014 ![]() |
b207
B207 Vs Gen Ii & Iii Ecotec QuestionsStarted by stupidyank , 05 Jan 2014 ![]() |
