Comp Cams For Saab Conversion
b207 comp cams zzperformance zzp lsj
143 replies to this topic
#101 CHILL Gone DUTCH
Posted 19 December 2013 - 11:04 AM
The cams in our b207 are simply sh*t for SC Our z22se cams are better It remains to be seen how much better the stage 2 lsj cams are compared with z22se which will also depend on 2.0 or 2.2 remember these ZZP cams are developed for 2.4 So I'm guessing they will be better on 2.2 rather than 2.0 Unsure where the standard lsj cams fit in to the list if there better than z22se we will be all happy if there worse I'm guessing we might be happy But not as happy as we thought we were going to be. If the standard lsj cams are better than z22se we will all be very happy as we were before this mid understanding came up
Edited by CHILL Gone DUTCH, 19 December 2013 - 11:07 AM.
#102 vocky
Posted 19 December 2013 - 11:06 AM
So in otherwords these will be slightly better rather than massively better than the Z22se cams?
No idea what the specs are for standard Z22SE cams or for that matter B207R cams and B207whateverthefcuk cams you've already got in your new engine.
b207r = stage less
z22se = stage standard
blower = stage +30bhp
zzp stage 2 = similar/same/slightly better/slightly worse than blower cams
#103 CHILL Gone DUTCH
Posted 19 December 2013 - 11:08 AM
b207r = stage less z22se = stage standard blower = stage +30bhp zzp stage 2 = similar/same/slightly better/slightly worse than blower cams
Where do standard lsj fit in to list
#104 vocky
Posted 19 December 2013 - 11:10 AM
standard LSJ = similar/same/slightly better/slightly worse than std z22se cams
#105 CHILL Gone DUTCH
Posted 19 December 2013 - 11:12 AM
standard LSJ = [color=rgb(40,40,40);][font="helvetica;"]similar/same/slightly better/slightly worse than std z22se cams[/color][/font]
Lol
#106 CHILL Gone DUTCH
Posted 19 December 2013 - 11:14 AM
I think we should all remember cams are only a small part of our builds but still affective
#107 vocky
Posted 19 December 2013 - 11:16 AM
I don't think anyone will be disappointed with the bhp gained from their compcams  :)
#108 CHILL Gone DUTCH
Posted 19 December 2013 - 11:23 AM
  As said here, the difference (or suitability for your particular engine/driving) between ZZP LSJ St2 or the Comp Blower cam set is a different discussion altogether (and a bit late after ordering all the cams... :wacko:)
Can't wait for this discussion
#109 techieboy
Posted 19 December 2013 - 11:26 AM
What I do know is, in a Z22SE, the standard Z22SE cam's worked reasonably well the B207R cams did nothing more the CompCams blower cams gave 30bhp the minute they went in Whether the B207R cams could have been timed differently to produce something in the Z22SE is a matter of speculation. Whether any of the above applies directly to using the B207 engine, I've no idea.
#110 Exmantaa
Posted 19 December 2013 - 11:53 AM
It very much depends how you want to drive your car and how your engine is configured.
Doesn't really help to buy a hot race cam that delivers top power around 8000rpm if your rev limit is @7200 and you lost your low end grunt for road driving... :unsure:
#111 techieboy
Posted 19 December 2013 - 12:10 PM
:yeahthat:
Oh to have an engine dyno with a fully operational B207/LSJ/Z22SEhybrid engine hooked up to it to test all of these things. :wacko:
#112 vocky
Posted 19 December 2013 - 12:15 PM
The 2.0 engine should be good to rev to 8500, but the 2.2 has a max of 7800rpm.
#113 techieboy
Posted 19 December 2013 - 12:16 PM
Ouch. I hope it sounds slightly more willing than the strangled asthmatic cat noise that the Z22SE makes after 7,000rpm.
#114 oakmere
oakmere
  • 2,143 posts
Posted 19 December 2013 - 12:49 PM
These cams are still mild so unlikely to have a big effect on low down power. Can the SC run up to 8000 rpm? I thought they would be well out of there efficiency range by then especially with a smaller pulley. Still yet to see a dyno of a 2.2 of any type making more power above 7400 rpm!
#115 Exmantaa
Posted 19 December 2013 - 01:12 PM
Yeah, the SC is another factor in the equation. :happy:
And then the fact that a particular cam behaves different in a 2.0 application than with 2.2 (or 2.4) displacement...
(did I mention camshaft timing already?? :wacko: )
#116 CHILL Gone DUTCH
Posted 19 December 2013 - 08:03 PM
[font="Arial;font-size:small;"]Stock LSJ is 196.5/191.7 duration @ 1mm(.039") valve lift and 10.04mm/10.04mm total valve lift. LSA is 107.5[/font]
:tt:
please note duration @ 1mm
lol
#117 Exmantaa
Posted 19 December 2013 - 10:46 PM
Someone read the GM specs... :happy: thumbsup
#118 ufods
ufods
  • 235 posts
Posted 20 December 2013 - 02:15 PM
today i get my black friday present: lsj stage 1 cams.
Try to attach the pictures but the System just told me: "no file was selected for upload"
Sorry.
103€ for Customs
#119 techieboy
Posted 20 December 2013 - 02:25 PM
Upload/gallery function is broken (and sh*t even when it works). Host pictures on a proper photo hosting service like Photobucket and use the img tags to embed a picture on here.
#120 ufods
ufods
  • 235 posts
Posted 20 December 2013 - 02:39 PM
Thanks...here it is :wub:
Also tagged with one or more of these keywords: b207, comp cams, zzperformance, zzp, lsj
