Posted 13 December 2013 - 04:34 PM
Posted 13 December 2013 - 05:03 PM
Surely the damping rates is dependant on the springs you have, the corner weights of your car etc. Simply saying X-clicks would be talking pish.
Posted 13 December 2013 - 05:15 PM
Posted 13 December 2013 - 07:50 PM
Posted 13 December 2013 - 07:52 PM
Posted 13 December 2013 - 07:53 PM
You don't mean what number for track and road do you? Surely you mean how many for track and how many for road? Anyway as others have said it all depends...What is the best number of clicks to set Nitron NTR 40s at for track and road use ?
Posted 13 December 2013 - 07:57 PM
My spring rates are 350 front and 450 rear Only just had these fitted looking at what is the best stating point ,Ride height 125 rear ,115 front
Posted 13 December 2013 - 08:16 PM
Posted 13 December 2013 - 08:17 PM
Posted 13 December 2013 - 08:23 PM
Most importantly... How does it feel to YOU Kieron?
It will be nice to find out when the car is running wright LOL
Posted 14 December 2013 - 05:10 PM
That's the beauty of suspension setup, very hard to say what's right and what's wrong. I tried my very best to find some facts, but ended up with guidelines, all with a remark that these provide a starting point but from there you can go in any direction.
Guidelines:
- start with ride frequency, which determines spring rate. Track use you want a higher ride frequency than road use. So you go for a compromise. You're spring are in the compromise area. Track use you go higher rate, pure road lower
- ride frequency at the front should be about 10% lower than at the back to avoid pitch due to resonance. This is where things already go terribly wrong, as even for the standard springs this is not true. Everybody seems to go for about the same ratio as for the standard springs, so say rear 15-20% higher than front. I've no idea why Lotus did this however, so assuming that for higher spring rates you should use the same ratio is tricky. As everybody is seems to do this, very little evidence for the contrary
- next thing is roll stiffness, which is where ARB's come in
- distribution of roll stiffness front and rear
- damping ratio for single bump (compression damping)
- damping ratio for rebound
(this is the short version)
Your question is about the last two. In case you have one ways, the ratio between compression and rebound damping is fixed. Probably around 3 times as much rebound damping as compression damping. Don't know what the ratio is that you can select with the NTR's, I've never seen it published for any shock.
So in short: 6 from hard for track, 12 from hard for road
(just kidding!! right answer is above: whatever feels good for you. Start full soft and go from there is the practice that is most used. You will need to do some 'testing'. You're lucky to have one-ways: only 24 settings. Three ways take a little more time
(I've asked Nitron to send me the speed-force diagrams for my shocks that are being refurbished and they promised to send me some. So at some stage I might get a clue about what the setting are. Not that it helps in any sense, but I can do cool calculations if I have the data)
Also tagged with one or more of these keywords: nitron, ntr40, settings
The Market Place →
Group Buy Room →
Nitron Damper Group BuyStarted by Matthew Bentley Racing Ltd , 24 Apr 2018 ![]() |
General Discussion →
VX220 Discussion →
Nitron Ntr Advice. Na / Turbo Swap - Suspension.Started by dstarz7 , 26 Feb 2018 ![]() |
The Market Place →
Group Buy Room →
Nitron Street Series Group Buy - Until 20Th Nov 2016Started by Matthew Bentley Racing Ltd , 07 Nov 2016 ![]() |
VX220 Discussion →
Are Cup R Dampers Nitrons?Started by thejoaoserra , 30 Mar 2016 ![]() |
VX220 Discussion →
Damper Bearing O RingStarted by D-DAWG83 , 08 Feb 2016 ![]() |
