#61
Posted 24 December 2013 - 07:02 AM
#62
Posted 24 December 2013 - 07:55 AM
#63
Posted 24 December 2013 - 08:05 AM
#65
Posted 24 December 2013 - 10:41 AM
When I first saw this thread yesterday I knew it was going to be good so waited till lunch and enjoyed every second of it.
Top job to all those involved.
#66
Posted 24 December 2013 - 02:05 PM
I thought it would be more interesting with a bit of history as to why I went down the routes I did, I'm sure lots of people had a similar experience when modding and it may help others looking at modding, even if not the VAG engine conversion.
There should be more photos and updates to come. Just busy sorting out OP-COM, VAG-COM and Revo SPS software. Need to log things and see how it's doing. Went out thinking of doing brakes but the wind drove me back indoors, must get the garage sorted.
So glad it's home and really pleased with the positive attitude from everyone, thanks.
#67
Posted 24 December 2013 - 02:08 PM
siztenboots, on 23 Dec 2013 - 08:56 AM, said:
Nice to see you have stayed with motronic, albeit the 7 series. All the tuning software and tools I have will work perfectly with this too , when you want to get a bit more involved with adjustments.
Missed this yesterday, sorry.
Would be nice to learn a little more, always up for that.
#68
Posted 24 December 2013 - 02:11 PM
Crabash, on 24 Dec 2013 - 2:08 PM, said:
May not be so straightforward now it's got Revo software on there.siztenboots, on 23 Dec 2013 - 08:56 AM, said:
Missed this yesterday, sorry. Would be nice to learn a little more, always up for that.Nice to see you have stayed with motronic, albeit the 7 series. All the tuning software and tools I have will work perfectly with this too , when you want to get a bit more involved with adjustments.
#69
Posted 24 December 2013 - 02:24 PM
Just been looking at the SPS and reading about what it can do, I have boost, timing and fuel parameters, on 3 performance presets and 1 stock preset along with an anti theft mode on or off. Boost and timing seems pretty straight forward, just log with VAG-COM and make small changes to find the optimum, the ecu will not let you do damage and will just back things off if you push too far, but this backing off will lose performance obviously. Fueling is more vague, says you can ask for a target AFR but it will still only deliver what it can without damage, same deal as boost and timing but it says leave alone unless you have a good understanding of AFR and it's effects.
#70
Posted 31 December 2013 - 01:21 PM
Starting list for you Steve
K04 tfsi engine - cleaned sump and pickup prior to install (common issue that can block when ran on long life service schedule)
ITG filter / revo intake pipe / custom silicon reducer with recirc connection and turbo high flow adaptor on turbo (same as the ones made for the VX220 turbo)
DG custom machined alloy billet mounts and uprated vibratecnic mounts all round
DG custom downpipe and exhaust (Dave Hardwick backbox) im a dog person and no cats here lol all 3" with no reduction and all mandral bends
DG custom Intake bracket on rubber mounts
DG custom mounting for coolant tank again on rubber mounts
DG custom fuel line install
DG spec custom S155 steel one piece shafts (audi inner / Vaux outer)
HPFP autotech
DG spec Pro alloy charge cooler with uprated core
Revo stg2+ ecu work with extra work requested (including linear map addition)
Triple pass pro alloy radiatior
2-11 gear selector and 2-11 motorsport cables modded to fit
DG rose joint conversion on gearbox
Chris@EFI custom wiring install of oem management / mod VX220
DG custom boost and coolant hose install - upgrade 70mm from CC > 70mm TB
Usual full service from fuel filter to oil / uprated plugs etc etc
Larger baffled pro alloy tank
Uprated pickup fuel pump
DG custom gearshift cable mounts
Air con deletion and short belt mod
Most of the other work was nut / bolt rebuild with well everything replaced / upgraded its a looooooonnnnngggg list but sure Steve can go through it when he has time some bits already covered
DG
#71
Posted 31 December 2013 - 03:10 PM
Will get round to it shortly. List for transplant and list for everything else we did that was not needed for transplant.
#72
Posted 31 December 2013 - 06:03 PM
#73
Posted 31 December 2013 - 06:20 PM
#74
Posted 31 December 2013 - 06:28 PM
There seems to be stopping power but having to push really hard like there was no servo, wishing the festive period was over so I can get on. Only time I have at the min is when everything is closed and family expect certain things, rest of the time I'm working.
#75
Posted 31 December 2013 - 07:45 PM
#76
Posted 01 January 2014 - 12:58 AM
Don't think it will ever be as fast as yours mate. Wish we had time and conditions to stretch it's legs a bit, next time.
Edited by Crabash, 01 January 2014 - 01:04 AM.
#77
Posted 01 January 2014 - 01:19 AM
#78
Posted 01 January 2014 - 09:51 AM
#79
Posted 01 January 2014 - 04:20 PM
ciderbooze, on 31 Dec 2013 - 7:45 PM, said:
Ssssh, don't intimidate the SC kidsHappy to help steve and first glimpse of the work ,albeit in fading light , looked very nice indeed. I know the car had so much more to give on our short run out as you where barely tickling the throttle but it still pulled like a train I think the wide rubber on the back helped to stop it spinning up . Looking forward to a dry run. It may be nearly as fast as mine now
Top work Duncan
#80
Posted 01 January 2014 - 05:14 PM
Also tagged with one or more of these keywords: engine swap, audi, tfsi
General Discussion →
Other Models & Brands →
The New Daily :)Started by MattMacc123 , 04 Apr 2019 ![]() |
Audi A8Started by Beano , 31 May 2015 ![]() |
The Market Place →
Cars For Sale →
Audi A4 Avant Quattro 2.0Tdi 170Bhp 2006 56Started by lilpidge , 21 Feb 2015 ![]() |
Tuning & Modifications →
The Big Saab B207 Conversion TopicStarted by smiley , 29 Dec 2013 ![]() |
b207
B207 Saab ConversionsStarted by CHILL Gone DUTCH , 17 Oct 2013 ![]() |
Bing (1)
