Looks like I'm turning into Matt, accumulating enough VX bits to build one in kit form.
Bear in mind I already have a fully working car elsewhere, equipped with Compos, Nitrons, M62 charger, turbo ears, turbo spoiler etc.
And a slightly better angle for seeing what is actually there;
ATS DTC wheels
Lotus ABS
Alu Rad
Vauxhall V
Bonnet louvres
Four balljoints (another four to be bought obv)
Ertacetal wishbone bushes
Carbon instrument binnacle (probably going to sell)
Sparco steering wheel with EP quick release kit
APR Carbon mirrors
Scroth harnesses X2
Jon Betts Harness bar
Single Composite Worx seat (until a decision is made to purchase another or set of Probax)
Poly front and rear engine mounts
Tullet 2.5inch Manifold
lightweight header tank bracket
ZZP Phenolic spacer
ZZP comp Cams stage 2 SC
ZZP Supertech valve springs
6 Rib crank pulley
6 rib alternator underdrive pulley
Coupe kit (not all panels pictured)
Also worth noting that not in shot, and not coming to the house, are the
Saab B207 engine
Quantum single ways
1inch ARB
Reduced bump steer kit
Bosch water pump
PA Chargecooler rad
PA Chargecooler header tank
PA gearbox breather
Try and rob me an I'll break your legs.
Plus, most of this is on its way to other locations as of this week anyway.
Oh, and project thread to come ASAP.
G
