Project 'cash In The Attic' - Sc Conversion
#201
Posted 13 July 2014 - 09:58 AM
#202
Posted 13 July 2014 - 10:17 AM
CC pump seemed to fit perfectly on that bracket. I have some rubber round the clamp but may add something else to shield noise.
Not sure if my description was very good on the manifold bracket - I fitted the manifold bracket to the block - not the manifold. The strange thing here was that I had bought the alignment bungs from courtenay on the understanding that the block would need M6 bolts - but mine took M8's so I have some spare bungs. Maybe I bolted it in completely the wrong place... Having come in yesterday and thought about it, I'm fairly certain that I'll have to take the alternator back off to get that bottom bolt into the manifold to bracket anyway so will soon find out.
#203
Posted 13 July 2014 - 10:24 AM
Edited by Steve.i.am, 13 July 2014 - 10:27 AM.
#204
Posted 13 July 2014 - 10:29 AM
That makes more sense!
#206
Posted 15 July 2014 - 06:36 PM
#207
Posted 15 July 2014 - 09:30 PM
Thanks Steve!
#209
Posted 15 July 2014 - 10:07 PM
#210
Posted 15 July 2014 - 10:19 PM
Very good.
Where is that bottom hose in the SC actuator plugged in?
#211
Posted 15 July 2014 - 10:34 PM
It's not attached, just tucked it out the way as it didn't want to come off easily. It's not supposed to be connected is it?Very good. Where is that bottom hose in the SC actuator plugged in?
Edited by Captain Vimes, 15 July 2014 - 10:35 PM.
#212
Posted 16 July 2014 - 05:32 AM
You could hook it up to one of these for optimal WOT pleasure
#213
Posted 16 July 2014 - 09:04 AM
That is a great moment when it starts first time - I was the same almost made me jump when it instantly fired up.
Good work,
#214
Posted 16 July 2014 - 02:30 PM
#215
Posted 17 July 2014 - 05:31 PM
Also, I've got some new Servo hose after chopping the ends off the old hose. I'm thinking that this explains the whistling sound on part throttle and hoping the brakes will feel a bit better now (the hoses were leaking badly!)
#216
Posted 18 July 2014 - 02:48 AM
#217
Posted 18 July 2014 - 08:26 AM
Nice work, read from start to finish!
Where did you order your ECU from? I'm struggling to see a 'buy' link anywhere. Is it still about £700? I might do the same as you and get it first before doing the charger conversion.
Thanks - it's been a long time since I first started this but I've enjoyed learning and understanding.
My overall budget is officially completely and utterly blown! I started with the intention of a budget build and have ended up with the dutch ECU , new pro-alloy main rad and pro-alloy CC rad, alloy header tank and replacement exhaust. None of which were really necessary but I figured that I plan to keep the car for a long time, so it's worth investing some extra £££ into it.
Total cost is currently £3,809.82 - I'm sure it can be done for at least £1k less but I wasn't happy with the compromises needed..
To get the ECU, you just need to e-mail Peter ( peter at munckhof.demon.nl) edited mail address to avoid spamming to his inbox...
#218
Posted 18 July 2014 - 08:40 AM
I think the approach you have taken is the correct one, as you would likely look to replace perceived weak points of the budget system going forward anyway.
#219
Posted 18 July 2014 - 12:09 PM
nope
#220
Posted 18 July 2014 - 08:47 PM
