Project 'cash In The Attic' - Sc Conversion
#221
Posted 19 July 2014 - 10:38 PM
#222
Posted 19 July 2014 - 11:15 PM
#223
Posted 20 July 2014 - 12:02 AM
Thanks for the info - will drop him a note. Interesting budget creep! I'm thinking of starting my own SC build, anything you would advise with heindsight? I'm set on Dutch software but the spec of the rest of the build is completely in the air. I've already got an alloy rad and a VSE which I hope could keep costs a little lower. If I'm dragging your thread off topic feel free to drop me a PM!
Happy to drag it off topic!
I've been trying to figure out how the costs got so high and decide to look in more detail at my spreadsheet. I now realise that I'd double counted on parts - DOH!. Final cost is actually £3.2k but that has included the exhaust, alloy main rad and some bits I didn't need. Without these you could come in closer to £2.5k. I'll add a full breakdown if anyone is interested but it's roughly:-
£760 - Dutch Software
£410 - SC Ancillaries (vxr injectors, pulley, belt, inlet pipe, filter etc.)
£635 - Charger, Inlet, TB etc. from the states - including import duty and dual pass mod
£980 - Charge cooler system including pro-alloy main rad, cc rad, pump etc.
£105 - Extras (coolant, alternator etc.)
£100 - Bits I didn't use (fuel pump, spare alternator, budget pre-rad)
£225 - Exhaust
In hindsight... it's quite a bit of work and takes a lot of time reading various threads on here to get all the info you need. I'll reserve judgement on whether it's a great idea until I've lived with it for a while but I'm happy at the moment! I like the fact that I've done it myself as I know that if it breaks, then I can fix it.
Let me know if you want the e-mail address of the guy I got my charger from in the states. He was really helpful and it was delivered pretty quickly - just ask him to package it better than he did mine as the inlet manifold was damaged on mine during transit and needed welding up (thanks Dave H!)
#224
Posted 20 July 2014 - 06:55 AM
told you
#225
Posted 20 July 2014 - 12:26 PM
#226
Posted 20 July 2014 - 06:15 PM
Edited by Captain Vimes, 20 July 2014 - 06:32 PM.
#227
Posted 20 July 2014 - 10:33 PM
#228
Posted 22 July 2014 - 12:30 PM
So I'm very happy with the conversion but have a few questions for final setup/checks..
Fuel pump/AFR's
I'm on a standard fuel pump but running the blue VXR/LEH injectors. My assumption is that if the fuel pump is struggling to maintain the flow at high rpm on full load and the pressure in the fuel rail drops, then this will be compensated for by the dutch closed loop fuel learn by increasing the injector duty cycle to maintain the correct AFR. So assuming that the duty cycle is below 100% AFTER a fuel learn then I shouldn't be running lean (This isn't an option for the courtenay map due to the LET injectors being at 100% duty cycle anyway - hence the need for upgraded fuel pumps in those cars).
Have I understood this correctly? Is there a way that I can check actual AFR in the logging section (I couldn't see the option). I've got an uprated pump if needed, just deciding whether I need it or not...
Rev Limit
It's set at 7000rpm but I'd rather be safe and lose some of the rev range if neccesary. I'm tempted to drop it to 6500-6800rpm range. AmI being overly cautious?
Thanks
#229
Posted 22 July 2014 - 12:34 PM
#230
Posted 22 July 2014 - 12:36 PM
#231
Posted 22 July 2014 - 12:56 PM
I'm using a OEM fuel pump and it's fine, I actually think the need to replace the fuel pump is actually a quirk with CS being unable to deconvolute max'ed injectors from a max'ed pump.
I brought my rev limit down to 6800 however I was using a smaller pulley.
#232
Posted 22 July 2014 - 01:15 PM
Sound like we've come to the same conclusion.
Any tips on what I should look at on the logs to check it's not lean at the top end?
#233
Posted 22 July 2014 - 01:32 PM
Glad its been worth it. Makes it into a proper wee car...
If you want to quieten the induction noise, look at getting an enclosed airbox like a Viper one that Techie uses or a BMC CDA one like I have. Makes the noise much easier to live with and I managed to pick mine up second hand for £30. A quick clean and its mint again
#234
Posted 22 July 2014 - 01:40 PM
Have you got a wideband ??I'm using a OEM fuel pump and it's fine, I actually think the need to replace the fuel pump is actually a quirk with CS being unable to deconvolute max'ed injectors from a max'ed pump. I brought my rev limit down to 6800 however I was using a smaller pulley.
Sound like we've come to the same conclusion. Any tips on what I should look at on the logs to check it's not lean at the top end?
#235
Posted 22 July 2014 - 01:46 PM
Which wideband is the most reliable one to go for, heard mixed reviews of em? Also, I take it they need to get a threaded mount welded into the exhaust, upstream of the CAT?
#236
Posted 22 July 2014 - 02:36 PM
Nope - is that the only way?
#237
Posted 22 July 2014 - 02:47 PM
You can put it on the dyno.
They will stick a wideback in the exhaust during the session.
#238
Posted 22 July 2014 - 02:55 PM
#239
Posted 22 July 2014 - 03:24 PM
Do a fuel learn. If the supplied map is running rich this will obviously put more demand on the injectors. Just to confirm the blue injectors are currently above 90% duty cycle?
Do you have to run a wideband to do a fuel learn?
#240
Posted 22 July 2014 - 03:52 PM
