Project 'cash In The Attic' - Sc Conversion
stage2 supercharger
468 replies to this topic
#321 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 25 October 2015 - 10:49 PM
Vocky + chains = well worth it :)
#322 smiley
Posted 25 October 2015 - 10:58 PM
This is not that type of forum buddy :sleep:
#323 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 25 October 2015 - 11:03 PM
:D we don't have you Dutch delights so need to make our own fun!
#324 CHILL Gone DUTCH
Posted 26 October 2015 - 09:27 AM
Captain I've also suffered very badly with vibration since putting the RS14 on my car Which has deffo got worse and worse going to put new discs on the car this winter I did wonder if it was because there the same discs with different make of pads Did you change your discs when you put the RS 14 on ??
#325 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 26 October 2015 - 08:28 PM
- Handling:
     Sort out the understeer that the 1" ARB has introduced:- Stiffer springs and maybe some EP steering arms should start to move it in the right direction.
I had bad understeer at the national I put the ep steering arms on went from 1deg to 2deg front camber and took it back to Snetterton today, it is way better now.
my car rover elise s2
1" arb
gaz mono 475f/650r
camber 2 deg front 3 deg rear
castor 4.2 deg
#326 Rosssco
Rosssco
  • 4,185 posts
Posted 26 October 2015 - 09:01 PM
Discs are pretty cheap anyway, but you can always swap front / rear if you CBA to see if that makes any difference to the judder..
#327 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 26 October 2015 - 09:20 PM
Mine were fine before I changed the discs. I went for brembo discs and the braking is strong but the judder is pretty horrible. Hopefully it's just discs. What discs are you running?
#328 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 26 October 2015 - 09:22 PM
- Handling:      Sort out the understeer that the 1" ARB has introduced:- Stiffer springs and maybe some EP steering arms should start to move it in the right direction.
  I had bad understeer at the national I put the ep steering arms on went from 1deg to 2deg front camber and took it back to Snetterton today, it is way better now.   my car rover elise s2 1" arb gaz mono 475f/650r camber 2 deg front 3 deg rear castor 4.2 deg
Good to hear. I think my issue is also caused by springs that are too soft for the arb (350/450). Any video from your car before and after the steering arms?
#329 CHILL Gone DUTCH
Posted 26 October 2015 - 09:29 PM
Nothing special Just standard discs.
#330 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 29 November 2015 - 09:38 PM
So some shiny bits added to the car today:
- New drive belt pulley after the last one stopped tensioning after only 12 months (cheap eBay job - replaced with OE quality) and new belt while I was there.
- But more exciting is the new discs (sorry about the blurry picture - it was cold..). Hopefully this will help with the rumbling brake pedal..
And just to add a picture of my efforts to force the air through the rad rather than round it - seems to be working well:
#331 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 31 January 2016 - 12:06 AM
Quick update...
The battery died over Christmas as I didn't drive it for 3 weeks but after fitting a new battery the alternator was dead (possibly why the battery was knackered).
Managed to find a seller on eBay who promised he would send me a 100amp alternator and then panicked when a refurbished unit turned up without any markings indicating that it was the right part.
Fitted it today and it's perfect. Very pleased I manged to find a refurbished unit although it took much longer to fit than I expected. The supercharger is completely in the way so getting the bolts out and then actually removing it from the engine bay was a pain.
After removing the aux belt and tensioner 3 times in the last few months I hope I don't have to touch it for a while now!
It was good to drive it for the first time in a month rather than just look at it!
#332 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 31 January 2016 - 12:50 AM
Glad it all fitted Kev, really hope to see you on track this year. What days you got planned?
#333 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 31 January 2016 - 08:59 AM
Nothing planned yet although I'll do my best to be at the national. Once the family holiday is booked I'll get a few dates in. Only did 3 days last year so I'll try and get a few more in this time. I hope your back allows you on track this year.
Edited by Captain Vimes, 31 January 2016 - 09:03 AM.
#334 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 21 February 2016 - 11:31 PM
I had a couple of hours spare today so decided to hook up my new windows tablet to OBD tuner and go one step beyond the very basic fuel learn...
Started with an ignition and knock measurement. Not sure what this achieved apart from me driving everywhere in 2nd gear at 5k+ rpm trying to get the engine light to turn off at every conceivable load. Looks like I have no knock anywhere. When I processed the output it told me no changes had been made.
With no knock evident it was time to added some advance to see if I could find some more power.
First up, I ran a quick base power run and then added +1.77 degrees as recommended by the OBD manual. I managed to find an extra 5NM of torque between 3.5k-6k rpm but the improvement fell away at the top so peak power is still 250pk @ 6.5k rpm (limiter set at 6.8k)
Then I tried another +1.77 but it didn't seem to make much difference and there was some knock starting to show on some of the runs (although not consistently or very high).
End result is that I left it at +1.77.
For the OBD experts; is there anything else I should do or is that it for now? I don't want to stress the engine (hence the relatively low rev limit)  but if there's anything obvious I can do, happy to give it a try...
#335 CHILL Gone DUTCH
Posted 22 February 2016 - 08:10 AM
Reduce the ignition at the top end and see if it makes any difference Probably by half of what you put in
#336 CHILL Gone DUTCH
Posted 22 February 2016 - 08:11 AM
Are you measuring the knock on the power runs ?? At the bottom of the page purple line
#337 CHILL Gone DUTCH
Posted 22 February 2016 - 08:40 AM
The other thing I would be looking at is why your power is dropping of at 6400-6500 and not the Rev limit of 6800 by looks of it
#338 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 22 February 2016 - 12:39 PM
Thanks Chris. As the resident obd expert I was hoping you'd add some comments :)
Will do.
Yes. There's some noise below 3k rpm but it seems different every run so not sure if it's anything to worry about. There's nothing at all at high rpm. I'll post a graph later.
I spotted that too but when I look back to previous runs when I had the limiter at 7k the torque was fine to 6.8k and then dropped so I assumed it was some kind of soft limiter or a measurement issue as i was hitting the limiter pretty hard.
I'm not too worried about it as I rarely rev above 6.5k anyway as I don't want to stress the engine and that last few hundred rpm doesn't make much difference even on track.
#339 CHILL Gone DUTCH
Posted 22 February 2016 - 12:43 PM
Get your self a log done with some full throttle from low down the rpm range it reviles a lot
#340 CHILL Gone DUTCH
Posted 22 February 2016 - 12:44 PM
If you had a wideband it would be easier to if the car was going lean or rich at them revs to what is causing it I reved my standard 2.2 to 7200 rpm without any issues and had power to the limiter
    Bing (1)
