Project 'cash In The Attic' - Sc Conversion
#341
Posted 22 February 2016 - 12:47 PM
#342
Posted 22 February 2016 - 12:59 PM
#344
Posted 22 February 2016 - 08:19 PM
#345
Posted 22 February 2016 - 08:21 PM
#346
Posted 22 February 2016 - 08:28 PM
#347
Posted 22 February 2016 - 08:31 PM
#349
Posted 22 February 2016 - 08:37 PM
After you have done the WOT mapping you can add ignition at lower pressures throughout the rev range followed by a final knock learn session across the rev and pressure ranges to pull out any excess knock under non WOT conditions
#350
Posted 22 February 2016 - 09:01 PM
Thanks Chris. I'll go and annoy the locals with several full throttle speed runs and report back!
#351
Posted 22 February 2016 - 09:06 PM
#352
Posted 22 February 2016 - 09:13 PM
Just to add that the power drop 200rpm before the limiter is consistent. If I raise the limit, the torque carries on. I'm convinced the power drop is either a measurement issue or a soft limiter. Either way, I'm happier leaving the limit at 6.8k and will optimise below that. I'll try a power run without hitting the limiter so hard or in 3rd gear to see if it goes away.
The 2 runs below are from the same day with a 6.7k and 7k limit.. both dip 200rpm rpm before the limit.
#353
Posted 03 March 2016 - 11:49 PM
[font="arial, sans-serif;"]Did a few more runs this evening and the strange drop off at the top was being caused by hitting the rev limiter and not getting off the throttle quick enough. [/font]
[font="arial, sans-serif;"]x2 different runs, the first trying to lift just before the limiter and the second bashing the limiter...[/font]
#354
Posted 04 March 2016 - 07:04 AM
#355
Posted 04 March 2016 - 09:53 AM
#356
Posted 04 March 2016 - 11:19 AM
Correct, although it's not just right at the top. I've tried repeating the measurements with hitting the limiter vs not and the readings are consistently different from 6k through to 6.8kSo the run where you haven't hit the limiteror predicted the limiter looks quite a bit better/smoother right up at the top ?
#357
Posted 04 March 2016 - 11:41 AM
#358
Posted 04 March 2016 - 12:11 PM
No. The 180 was logged on a 1 way run and must have been slightly down hill at the end, hence the strange wiggle. Plus all measurements yesterday looked a bit high compared to previous runs - I may have got temp/humidity values wrong.. Max power is around 250 ish...Is that hitting 280? Are you worried about your engine?
#359
Posted 04 March 2016 - 12:12 PM
Snapping it shut otherwise it'll hit the limiter.Are you releasing the throttle slightly Or snapping it shut
#360
Posted 04 March 2016 - 12:16 PM
Edited by CHILL Gone DUTCH, 04 March 2016 - 12:17 PM.
