That's a bit different to the price at Courtenay 's - thanks. Think I'm probably back on track to get all parts including mapping, exhaust, charge cooler etc. sorted for under £2k now. I just need to make sure the bits arrive from America first before I buy too much other stuff.Dave H on here modded my end plate for dual pass for about £15 plus postage.
Project 'cash In The Attic' - Sc Conversion
#41
Posted 10 January 2014 - 10:29 AM
#42
Posted 10 January 2014 - 10:48 AM
#43
Posted 10 January 2014 - 11:15 AM
That header tank looks interesting.
Reservoir is GM number 22697069 (25$ and up) Cap is GM number 15076936 (10$ and up)
Difficult to find here, as it's an lsj part.
You may trie yanking Joe's or Lee's legg for one.
#44
Posted 10 January 2014 - 11:16 AM
you do not need the modified sc inlet end plate (double pass mod) for a basic stage 2 sc. Only required for stage 3 and above.
You also do not need any M8 - M6 studs, just use the washers from the bolts on an old cam cover.
If you are very careful you should easily be able to DIY for less than £2k, just don't buy stuff unless you really need it. Z20LET injectors will be fine, standard exhaust can cope, but reduces max bhp.
Just make sure you get the sc inlet manifold support and have a 100A alternator.
ps: and buy any bolts required from ebay, much cheaper
Edited by vocky, 10 January 2014 - 11:17 AM.
#45
Posted 10 January 2014 - 12:40 PM
The sc hasn't been posted from the states yet and I'm getting a few bits added to the box. So what should i add?
- manifold bracket (was inlcuded anyway but just hadn't been specified!)
- Charge cooler tank from cobalt (requested)
What about the cobalt injector harness. The LSJ injectors are EV1's so this should work shouldn't it?
Anything else?
Edited by Captain Vimes, 10 January 2014 - 12:43 PM.
#46
Posted 10 January 2014 - 12:57 PM
I think stock (green) lsj injectors are EV6, and you can't use them as CS has no mapping for them.
Keep your options in mind when choosing injectors:
CS only posts a basemap based on the black turbo injectors (EV1).
CS Will only map on the blue injectors when on-site.
Only the much more expensive obdtuner will give you all the freedom of injectors at wish.
Edited by smiley, 10 January 2014 - 01:03 PM.
#47
Posted 10 January 2014 - 01:02 PM
#48
Posted 10 January 2014 - 06:41 PM
will be keeping an eye on this thread, interesting to see how much it can be done for. good luck with the challenge!
#49
Posted 10 January 2014 - 08:52 PM
go to the breakers and get some plugs with wiring from a corsa engine loom
#50
Posted 10 January 2014 - 09:08 PM
#51
Posted 12 January 2014 - 11:19 AM
when I charge cooled my Elise( vag 1.8t 20v) I used this rad http://www.ebay.co.u...s=Car Make:Fiat|Model%3ASeicento&hash=item3f226de1fc I removed the plastic ends and replaced them with my own ali ones, I can get this done for you For the header tank I used this http://www.mkenginee.../apps/webstore/
It uses a ford cap http://www.ebay.co.u...=item4d1547338a.
If you phone Martin at MK for the header tank then just mention Daz with the Elise, he can sort the rad for you He's a top guy and has built some awsome projects over the years. ( was the man behing the MK Indy before selling tghe business on)
#52
Posted 12 January 2014 - 06:54 PM
Thanks. Not getting many bids on eBay at the moment so it's going to be tough...
I think I did my SC conversion for less than 2.5k with Dutch software
Chill - didn't you go for the pro-alloy CC rad? If you did it for less than £2.5k with that and Dutch software then I must be missing something.
Thought I'd add a quick update on the breakdown of costs for those interested. The big bits aren't too bad in terms of cost but they're fairly tough to get any cheaper. So far I've got:
- Charger, manifold, TB, shipping, import duty, bolts, bracket etc. -£570
- Base Map, final map, fuel to/from Courtenays - £500
- Exhaust - Second Hand - £225
It's the little bits that add up where I'm trying to be smarter with the sourcing:
- SC Ancillaries (belt tensioner, injectors, breather hose and filter, 100A alternator, fuel pump etc.)- £550
- CC & Ancillaries - £250
That little lot is around £2100 and I think I can shave another £100 to hit the magic £2k mark. l'll add a full breakdown of all parts costs at the end as I'm sure there'll be some bit's I've forgotten
#53
Posted 12 January 2014 - 06:56 PM
Thanks Dazz - do you have a picture of the Siecento rad fitted? Also, does anyone know if the Elise crash box (MK1 / MK2?) is the same size as the VX?
#54
Posted 12 January 2014 - 07:13 PM
Injector update... I've ordered some standard z20let injectors and the guy in the US that I bought the charger from has chucked in an LSJ loom at no extra charge so when they both get here I'll have a look and see where we are.
Edited by Captain Vimes, 12 January 2014 - 07:13 PM.
#55
Posted 12 January 2014 - 07:15 PM
I didn't need a exhaust Already had 2.5 tullet and standard manifold I think it came to £2800 but that included a pro alloy rad for car as well as CC radThanks. Not getting many bids on eBay at the moment so it's going to be tough...will be keeping an eye on this thread, interesting to see how much it can be done for. good luck with the challenge!
Chill - didn't you go for the pro-alloy CC rad? If you did it for less than £2.5k with that and Dutch software then I must be missing something. Thought I'd add a quick update on the breakdown of costs for those interested. The big bits aren't too bad in terms of cost but they're fairly tough to get any cheaper. So far I've got: - Charger, manifold, TB, shipping, import duty, bolts, bracket etc. -£570 - Base Map, final map, fuel to/from Courtenays - £500 - Exhaust - Second Hand - £225 It's the little bits that add up where I'm trying to be smarter with the sourcing: - SC Ancillaries (belt tensioner, injectors, breather hose and filter, 100A alternator, fuel pump etc.)- £550 - CC & Ancillaries - £250 That little lot is around £2100 and I think I can shave another £100 to hit the magic £2k mark. l'll add a full breakdown of all parts costs at the end as I'm sure there'll be some bit's I've forgottenI think I did my SC conversion for less than 2.5k with Dutch software
#56
Posted 12 January 2014 - 08:35 PM
#57
Posted 12 January 2014 - 08:42 PM
#58
Posted 12 January 2014 - 09:45 PM
#59
Posted 12 January 2014 - 09:55 PM
I suggest ditching the chargecooler in favour of dutch ecu. Then you can always do stage 2 in the future if you feel like.
#60
Posted 12 January 2014 - 11:29 PM
I like the idea of obd software but I'm not sold on having to map the car myself and possibly screwing it up. On the plus side it would be interesting to fit the exhaust while NA and see what difference the software makes on a fairly standard NA while acquiring the SC bits...
It's really very difficult to screw it up. You're not doing anything unique, it's a well trodden path and there are simple measures to ensure the map is correct, the main one being checking that the fuel is being trimmed down from the base map, this means the base map is running rich and therefore protecting the engine.
It's a very powerful bit of software. You can download the software and play with maps available on the OBD forum before even paying for the ECU flash, so why not have a play before you decide to go for it?
