Project 'cash In The Attic' - Sc Conversion
stage2 supercharger
468 replies to this topic
#161 oakmere
oakmere
  • 2,143 posts
Posted 10 June 2014 - 05:29 PM
Make your own for about £25 the plugs are available.
#162 siztenboots
  • 26,613 posts
Posted 16 June 2014 - 02:14 PM
re:tyres mine wear the insides on the rear , with the left taking a lot of the load. Could be toe scrub , 2.5° not a lot of camber
#163 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 16 June 2014 - 11:50 PM
Well if mine scrubs the outside and yours scrubs the inside then there must be a track setting that will give even wear. Either that or we swap wheels every few months :-) Do you run high spring rates?
#164 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 24 June 2014 - 01:20 PM
Still looking for an alternator.
Will the z22yh alternator fit? It looks the same... http://www.ebay.co.u...=item43ca8cd20a
Happy to buy new from autovaux but from an earlier thread it looks like these are also re-manufactured and therefore not necessarily the smaller 100 amp casing?
#165 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 26 June 2014 - 10:55 PM
Brief update.
I got an adapter from  Oakmere to fit the LSJ 68mm TB on my otherwise standard (ish) NA. I wanted to do this for a couple of reasons:
- get the job of rewiring the TB out the way before the main SC conversion (check)
- Test that the TB actually works before the main SC conversion (check)
- Test the affect on the NA given that it's easy to do with the dutch software. Reading on here, in the past people have spent time porting the standard throttle body and adding the 65mm TB and I wanted to know if this could make a difference on an otherwise standard engine. (conclusions below...) . The result could have been to either destroy all driveability, lose mid range, gain top end power etc...
Note:- In adding the TB, it has meant that I used the SC intake pipe (but old K&N filter which was the right size for the enlarged pipework anyway) which may also affect the power by moving away from the standard 'cobra' intake pipework.
I fitted it yesterday evening. I was 'pottering' about and it was done in about 2 hours including a very nervous period of pulling the pins out of the TB connector and switching them round.
Fitted (coolant still over full - I know):-
Tonight I switched the TB over in the software (to the 65mm TB option) and did some power runs (no fuel learn yet). The run below shows the difference between the power run tonight with the 68mm TB vs the last run I did on the OEM TB:
In conclusion.. it made no difference to power what so ever anywhere in the rev range.
It's worth noting though that the throttle response feels a little 'softer' but then I haven't done a fuel learn session so there may be some benefits available but it seems like the restriction is elsewhere - probably the manifold or just the standard cams/head?
#166 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 26 June 2014 - 10:58 PM
While I was there, it was the first time I've looked at the air filter.
It's absolutely disgusting!
So - it's a filthy K&N. Given the previous comments on here about aftermarket air filters killing engines, there must be loads of crap in the intake.... NO - it's pristine in the intake!
#167 Captain Vimes
Captain Vimes
  • 2,755 posts
Finally - I still need an alternator.
Got almost everything else and going to start the conversion next week.
Anyone know if the z22yh alternator will fit?
Edited by Captain Vimes, 26 June 2014 - 11:00 PM.
#168 smiley
Posted 26 June 2014 - 10:59 PM
Manifold. You need the 2.4
#169 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 26 June 2014 - 11:05 PM
Agreed - I was expecting to find that was the result, but while it was all just sitting around it seemed a shame not to bolt it on and measure the result.
The LSJ manifold with m62 'intake pipe' should do the job  :lol:
#170 smiley
Posted 26 June 2014 - 11:09 PM
Stop mucking around NA and do what hundreds have done before you.
#171 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 26 June 2014 - 11:19 PM
:lol:  I will when I have a 100amp alternator....
On the plus side, a big box of bits from Courtenay is due to arrive on Friday  :D
#172 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 02 July 2014 - 08:37 AM
Important update.. the conversion has started! Queue more dumb questions from me!
I'm sure this has been covered but I'm on the train and struggling with search on my phone... so, what's the correct wire to use for extending the injector loom, throttle body wires etc.. Is there an obvious place to get a selection of blue, brown, black wires etc that are the right rating and type to extend the loom accordingly?
Anyone got a link to amazon/eBay etc?
Progress update..
Started on Monday evening and got the front clam off and the interior out. Another couple of hours last night and with help from my grinder, the read clam is off.
Massive Thanks to Stuwy for his help! There's no way I'd even have the front clam off without him!
Some pictures for now. .
Monday:
Tuesday:
I won't get anymore done now until the weekend as I'm away with work :-(
Edited by Captain Vimes, 02 July 2014 - 08:39 AM.
#173 siztenboots
  • 26,613 posts
Posted 02 July 2014 - 08:39 AM
give the car some decency and cover up the clunge
#174 fezzasus
Posted 02 July 2014 - 08:56 AM
0.5 mm multicore wire for the injectors, 1.0mm multicore for the MAP sensor and fuel vent. Colours vary, I would just get a selection of different coloured wire and match as best as possible, from memory the exact wire colours are hard to find (injector wires are yellow with different coloured stripe)
#175 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 02 July 2014 - 09:30 AM
How about this: http://pages.ebay.co...7114849&alt=web
#176 sworks
sworks
  • 1,566 posts
Posted 02 July 2014 - 09:33 AM
I bought a whole load of wire from Maplins. Then decided best bet would be to buy an old loom so as I can match the wiring exactly (ended up with a loom from an Astra for £20 delivered). Not the cheapest option, but at least it will all match up
#177 fezzasus
Posted 02 July 2014 - 10:02 AM
http://www.polevolt...._to_length.html
Get a meter of half the colours, from memory the injector wires are something like yellow/brown yellow/black, yellow/red and yellow/blue, so get black, brown, yellow, blue, add a few more meters of black as you'll use that for a few other things, and 3 meters of 1.0mm green for the MAP and fuel vent. will also need 2 m of red 1.0 mm and black for the CC pump.
Edited by fezzasus, 02 July 2014 - 10:04 AM.
#178 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 02 July 2014 - 12:12 PM
4 hours to get two clams off that have never been off before I think it pretty reasonable :tt:
#179 Steve.i.am
Steve.i.am
  • 990 posts
  • Interests:Bends
Posted 02 July 2014 - 02:00 PM
Great - glad its underway.
I hope you put your fuel cap back on
#180 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 03 July 2014 - 12:53 PM
arg, fuel filler surround is completely destroyed and gave us a massive headache
