Project 'once'
saab b207 supercharged m62 ats dtc composite worx re-spray coupe
1145 replies to this topic
#501 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 08 July 2014 - 09:57 PM
Can't you fit rear subframe and get on with getting it back on its wheels ? Fuel pipes to fit swirl pot to fit ? Try Ironing the gold sheet might get a flatter finish ;-)
I did originally suggest this to MB but he seems to think this is the easiest/best way? And no ironing...
#502 Graeme Lambert
Graeme Lambert
  • 5,543 posts
No removable panel in the bulkhead for ease of supercharger removal/refitting? :o
Project Once Matt. Once... :lol:
#503 Gedi
Gedi
    404 Not Found
  • 5,547 posts
  • Interests:Nothing
Posted 08 July 2014 - 09:58 PM
Ahh, the inspection panel. I like the one that Simon put into his for access to the turbo. I hope to recreate that at some point.
#504 The Batman
Posted 08 July 2014 - 09:59 PM
I'm intrigued what is it you are talking about easiest/best way to fit with subframe off?
#505 techieboy
You wont be saying that the first time you want to remove the inlet manifold to check the Laminova's,  :wacko:
#506 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 09 July 2014 - 05:43 AM
The engine...
#507 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 09 July 2014 - 05:44 AM
New bulkhead = loads of room? I hope... :o
#508 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 09 July 2014 - 06:08 AM
Yes loades you don't need a panel with the standered bulkhead removed :-)
#509 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 09 July 2014 - 09:54 AM
thumbsup
#510 fezzasus
Posted 09 July 2014 - 10:24 AM
I'll bow to Matt's superior knowledge but if I were doing it I would certainly want the subframe on before the engine, the chassis was unstable enough just fitting the heater. I wouldn't want to offer a engine up to the chassis as it is.
#511 The Batman
Posted 09 July 2014 - 01:22 PM
The engine...
I guess it saves hoisting it up in there air :lol: But slows you down for the suspension / subframe rebuild or have you taken the joe approach and just can't be arsed now? :lol If it was me I would bolt subframe on, like what fez says
Edited by The Batman, 09 July 2014 - 01:24 PM.
#512 vocky
Posted 09 July 2014 - 03:50 PM
might be fine to fit a Lotus engine with the subframe removed but the vx220 needs the side mounts removed to bolt up the subframe, so a stupid idea  :ffs:
#513 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 09 July 2014 - 09:49 PM
Hmmmm, guess I know what I'm doing when I get back from Scotland after the weekend then. At least subframe is ready, new shims and bolts ready for mounting point and all the suspension wishbones and hubs are built up waiting...
#514 vocky
Posted 10 July 2014 - 07:54 AM
I tried it once, never again  :beat:
#515 Gedi
Gedi
    404 Not Found
  • 5,547 posts
  • Interests:Nothing
Posted 10 July 2014 - 09:59 AM
I don't understand what the benefit of fitting without the subframe would be, other than not having to lift the crane quite as high??
#516 Nev
Posted 11 July 2014 - 05:57 AM
Me too.
Edited by Nev, 11 July 2014 - 05:58 AM.
#517 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 11 July 2014 - 09:00 AM
So it's to allow better/easier access for me to work out where to run fuel lines etc, rather than reaching and bending over the subframe I can just lean over the engine itself.
G
#518 fezzasus
Posted 11 July 2014 - 09:22 AM
Speaking to Vocky about this, as I will be removing my subframe to reshim it when I replace my engine, he went into a bit more detail:
You can only attach the front engine mount to the engine, the side mounts cannot be attached as the subframe bolts need to be added before.
Because of this, you need to find a way to offer up the subframe with the engine crane still supporting the engine.
In short, it's much more difficult to fit an engine without the subframe attached. Most fuel lines can be run prior to offering up the engine anyway, so there's little gain to be had.
#519 Mopeytitan
Mopeytitan
  • 1,908 posts
    My dogs (love my dogs).
    F1.
Posted 19 August 2014 - 03:58 PM
How's the car coming G? Any updates?
#520 CocoPops
CocoPops
  • 17,182 posts
Posted 19 August 2014 - 04:00 PM
He's on holiday... Getting engaged.
Also tagged with one or more of these keywords: saab, b207, supercharged, m62, ats dtc, composite worx, re-spray, coupe
