Don't expect it to be a problem? Others run them? Plus all those VX's out there that pass mots with all sorts of dodgy bits lolThose spot calipers going to grip enoigh to pass an MOT?
not sure what you could possibly be insinuating
Posted 14 February 2015 - 09:20 PM
Posted 14 February 2015 - 09:43 PM
Posted 15 February 2015 - 08:07 AM
Posted 15 February 2015 - 08:30 AM
don't forget to blank off the oilways where the saab oil cooler used to go
Posted 15 February 2015 - 08:56 AM
Neil was going to make a plate have you any made for this and inlet cam end plate ?don't forget to blank off the oilways where the saab oil cooler used to go
Posted 15 February 2015 - 09:00 AM
Posted 15 February 2015 - 09:43 AM
Nope I think that was just there to stop stuff getting in there etc.Are you keeping standard ex manifold G Good to see everything moving quickly
Posted 15 February 2015 - 10:23 AM
Isn't it just a bolt? (Through the front hubs) I wouldn't have thought it actually does anything except prevent dirt getting in there?...
M16 bolt and a set of specifically designed washers. It's purpose is to put the wheel bearing under the same clamping load that it would experience when fitted on a driveshaft.
The OEM bearings do not require this per-se as they are double-row ball bearings and can not be taken apart like tapered roller bearings in other cars, but the bearing races can use a little support on the front wheels when running on track a lot with stickly tyres. Keeps them in good nick longer and delays play developing.
Installation is simple. Eg.
https://www.verboom....0421/index.html
Posted 15 February 2015 - 10:24 AM
I best stick them on my new jobs thenM16 bolt and a set of specifically designed washers. It's purpose is to put the wheel bearing under the same clamping load that it would experience when fitted on a driveshaft. The OEM bearings do not require this per-se as they are double-row ball bearings and can not be taken apart like tapered roller bearings in other cars, but the bearing races can use a little support on the front wheels when running on track a lot with stickly tyres. Keeps them in good nick longer and delays play developing. Installation is simple. Eg. https://www.verboom....0421/index.html Bye, Arno.Isn't it just a bolt? (Through the front hubs) I wouldn't have thought it actually does anything except prevent dirt getting in there?...
Posted 15 February 2015 - 11:02 AM
Posted 15 February 2015 - 11:21 AM
Posted 15 February 2015 - 02:02 PM
Posted 15 February 2015 - 03:45 PM
I thought Matt Bentley was doing the work on your car Graeme. That not the case any longer?
Matt still doing the ECU, mapping, and sorting the exhaust. He'll also be involved in the Geo when we get to that stage.
Posted 15 February 2015 - 05:17 PM
the inlet cam uses the original vx220 item, or from an astra / zafira z22se engine.
I don't have any oil blanks made up, but you only need some 10mm alloy plate
Posted 15 February 2015 - 05:22 PM
Thought he was doing all the engine work too. Why the change of plan?Matt still doing the ECU, mapping, and sorting the exhaust. He'll also be involved in the Geo when we get to that stage.I thought Matt Bentley was doing the work on your car Graeme. That not the case any longer?
Posted 15 February 2015 - 05:30 PM
He built the engine as well.
Posted 05 May 2015 - 02:25 PM
Page 3, more than two months on from last update too
Sometimes it's all to easy to get depressed about the glacial rate of progress on this project, and the dependance on others to finish their bits before moving to the next stage.
Then I look outside, realise it's a bank holiday weekend and that someone else is paying for all my fuel and think... fcuk it
Excuse the image quality - I only had my iphone with me, not proper camera and clearly I'm no GF Williams.
Anyway, ALL engines should rev like this...
In terms of real updates, well I'm retisecent to say what's happening or might hopefully be happening to the car at the moment for fear of disappointing you as much as I am with failed deadlines and broken promises. However, I genuinely believe the mechanical aspect of this project is finally nearing completion. Then hopefully we can crack on with the bodywork etc - assuming I can get a slot back into the workshop soon enough.
In the meantime I have of course bought a few more bits. and itemised the garage of bits currently in there - some of which will be fitted to the car, and some (duplicates normally) sold. I'll list these soon.
G
Posted 05 May 2015 - 02:40 PM
How much to'ing and fro'ing to get that wheel logo horizontal to the ground?
Posted 05 May 2015 - 02:50 PM
Believe it or not, that was a happy coincidence - it was taken at the same time as the main side on pic, and was just where I parked on the drive.
Less of a happy coincidence was the fact I'd left it in raised ride at the front (on account of getting on the in-law's drive) - hence the arch-gap
Posted 05 May 2015 - 02:52 PM
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
Supercharged Exhaust AdviceStarted by Donmizzi , 28 Jan 2021 ![]() |
VX220 Discussion →
Looking To Join The Sc Club - Advice Please...Started by JamieShand , 06 Sep 2019 ![]() |
VX220 Discussion →
Ebay Coupe Rear KitStarted by gazbucko , 23 Apr 2019 ![]() |
The Market Place →
Car Parts Wanted →
Coupe Rear Kit Wanted!Started by gazbucko , 23 Apr 2019 ![]() |
