Project 'once'
#701
Posted 07 July 2015 - 04:46 PM
#702
Posted 07 July 2015 - 04:52 PM
#703
Posted 07 July 2015 - 04:56 PM
Speaking to Vocky, with head work and valve springs, yes. They have sodium filled valves which can take much more than stock z22se ones. I doubt I'd continually rev it that high, might start at 7500 and see how I go. Easily changeable with the Dutch software.Can these saab engines (with mods) really rev to 8k safely and consistently? That's astonishing if so
Edited by ArticMonkey, 07 July 2015 - 04:56 PM.
#704
Posted 07 July 2015 - 05:04 PM
i rev mine to 7500 (2.2 saab ) without any issues i have reved it to 8000 but he gear change is awful so i have the limiter set to 7800 but dont rev it much past 7500
#705
Posted 07 July 2015 - 05:09 PM
The sodium filled valves don't really make a difference to the speed you can run an engine to, they're there to help with cooling so you don't need to run the engine as rich. This in turn helps with emissions (the reason they're in there) and gets a better fuel burn to generate more power.
The main benefit is moving to 2.0 L. So most people who have converted to 2.2 L have lost this. It's simple physics - the piston has to move faster the more you rev the engine. It gets to a point where the force at piston reversal is too great and will stretch the con rod. Moving to aftermarket con rods helps, but they add more mass, which adds more force at piston reversal. This just transfers the damage elsewhere.
Once you've got the piston speed controlled/managed, the next issue is valve bounce, dual springs help, but again add mass.
In theory dual springs should allow 8000 rpm, and uprated single springs top out about 7600 rpm. Personally, i'd set a limit 200 rpm under that.
#706
Posted 07 July 2015 - 05:18 PM
I doubt with a screaming harrop I'd need to see 7600, let alone 8000. I'd be happy that if ever entering that range it will still be ok on the engine. My main issue will be finding the sweat spot for power and risk with the stock internals. Some say 330, others say 350+. Both easily made with a harrop and pulley under 2.9".The sodium filled valves don't really make a difference to the speed you can run an engine to, they're there to help with cooling so you don't need to run the engine as rich. This in turn helps with emissions (the reason they're in there) and gets a better fuel burn to generate more power. The main benefit is moving to 2.0 L. So most people who have converted to 2.2 L have lost this. It's simple physics - the piston has to move faster the more you rev the engine. It gets to a point where the force at piston reversal is too great and will stretch the con rod. Moving to aftermarket con rods helps, but they add more mass, which adds more force at piston reversal. This just transfers the damage elsewhere. Once you've got the piston speed controlled/managed, the next issue is valve bounce, dual springs help, but again add mass. In theory dual springs should allow 8000 rpm, and uprated single springs top out about 7600 rpm. Personally, i'd set a limit 200 rpm under that.
#707
Posted 07 July 2015 - 05:40 PM
Edited by Nev, 07 July 2015 - 05:41 PM.
#708
Posted 07 July 2015 - 05:51 PM
I had an unusual big end
You're right highlighting oil viscosity. The OEMs are finding cavitation issues with 0W-20 fluids in standard tune. That said, they're using variable vain pumps so the ECU is changing the pump volume to a target oil pressure, so drop the oil viscosity and that target pressure needs a higher flow rate.
with the dumb pumps in these engines, it's a much less complicated story. I would say you would want to go the other way and thin the fluid, as too high a viscosity and you'll see too high a pressure, which will cause cavitation in the bearings.
#709
Posted 07 July 2015 - 05:53 PM
and the GM build book says 300, but that's without under piston oil jets, which take away about 30-40 % of the piston heat. Factor those in and i'm treating 350 bhp as the hard limit, but aiming to be around 280-300 with my build, might be slightly ambitious, but we'll see.
#710
Posted 07 July 2015 - 05:56 PM
#711
Posted 07 July 2015 - 06:02 PM
Hopefully, if events stop conspiring against me. after 12 months of faffing around with a house build, the cam belt tensioner in my vectra failed on the way back from collecting the exhaust.
Working cars = zero.
#712
Posted 07 July 2015 - 06:54 PM
Same boat. Spent 6 months last year on my new house and have a wedding in 4weeks. Time is few and far between at the moment. It didn't help me having to send a major part of my car build back for refund. Putting me 4 weeks behind and counting.Hopefully, if events stop conspiring against me. after 12 months of faffing around with a house build, the cam belt tensioner in my vectra failed on the way back from collecting the exhaust. Working cars = zero.
Edited by ArticMonkey, 07 July 2015 - 06:56 PM.
#713
Posted 07 July 2015 - 07:38 PM
4 weeks? PffftSame boat. Spent 6 months last year on my new house and have a wedding in 4weeks. Time is few and far between at the moment. It didn't help me having to send a major part of my car build back for refund. Putting me 4 weeks behind and counting.Hopefully, if events stop conspiring against me. after 12 months of faffing around with a house build, the cam belt tensioner in my vectra failed on the way back from collecting the exhaust. Working cars = zero.
#714
Posted 07 July 2015 - 07:47 PM
If you could spanner quicker, you would of saved 4 weeks.4 weeks? PffftSame boat. Spent 6 months last year on my new house and have a wedding in 4weeks. Time is few and far between at the moment. It didn't help me having to send a major part of my car build back for refund. Putting me 4 weeks behind and counting.Hopefully, if events stop conspiring against me. after 12 months of faffing around with a house build, the cam belt tensioner in my vectra failed on the way back from collecting the exhaust. Working cars = zero.
#715
#716
Posted 07 July 2015 - 08:29 PM
I won't bother disagreeing with that one. I will mention I haven't laid a spanner on it since August. 2014...If you could spanner quicker, you would of saved 4 weeks.4 weeks? PffftSame boat. Spent 6 months last year on my new house and have a wedding in 4weeks. Time is few and far between at the moment. It didn't help me having to send a major part of my car build back for refund. Putting me 4 weeks behind and counting.Hopefully, if events stop conspiring against me. after 12 months of faffing around with a house build, the cam belt tensioner in my vectra failed on the way back from collecting the exhaust. Working cars = zero.
#717
Posted 07 July 2015 - 08:31 PM
Ok, I still don't have my graphs or an idea what they revved it to but power at the crank was 325... So Vocky was right. No surprise there. I'm happy with that and excited about finally moving onto the next chapter of the build finally - bodyworkAnyway, power figures please. Graphs can come later.
#718
Posted 07 July 2015 - 08:34 PM
Nice one G, you must be well happy with that!!
GJ
#719
Posted 07 July 2015 - 08:43 PM
#720
Posted 07 July 2015 - 08:50 PM
Who by?Well I've been told it was more G
Also tagged with one or more of these keywords: saab, b207, supercharged, m62, ats dtc, composite worx, re-spray, coupe
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
Supercharged Exhaust AdviceStarted by Donmizzi , 28 Jan 2021 ![]() |
VX220 Discussion →
Looking To Join The Sc Club - Advice Please...Started by JamieShand , 06 Sep 2019 ![]() |
VX220 Discussion →
Ebay Coupe Rear KitStarted by gazbucko , 23 Apr 2019 ![]() |
The Market Place →
Car Parts Wanted →
Coupe Rear Kit Wanted!Started by gazbucko , 23 Apr 2019 ![]() |
Bing (1)
