Project 'once'
#801
Posted 08 July 2015 - 06:55 PM
#802
Posted 08 July 2015 - 07:08 PM
I fitted I didn't buy itI think you'll find you fitted it leeCome on G why would you fit a restrictive manifold on a 3" system
Well, either you or MBR
#803
Posted 08 July 2015 - 07:18 PM
Is bills graph at the wheels and Graham's at the crank ??
Graeme = RED
Bill = BLUE
Below is Graemes graph from 2 pages ago for reference:
#804
Posted 08 July 2015 - 08:10 PM
I know... Just trying to dodge the stupidity slurI fitted I didn't buy itI think you'll find you fitted it leeCome on G why would you fit a restrictive manifold on a 3" system
#805
Posted 08 July 2015 - 08:11 PM
Actual lolz Suppose it had to happen eventually. Actually slightly surprised it took this long...Ha ha, project once is dead, long live project once and a bitIf that's all it is Neil, then annoying though it is (someone could've told me months ago lol) then at least it's an easy if expensive solution. So, anyone want a tullet 2.5inch mani? Perfect for a stg2 or stg3 m62!you need a better exhaust manifold
#806
Posted 08 July 2015 - 08:30 PM
Not convinced it's the manifold personally, why would the power drop off? Surely if the manifold reached its maximum flow rate then the power would level out
#807
Posted 08 July 2015 - 09:00 PM
Well that certainly sounds logical. But then I don't really understand these things...
#808
Posted 08 July 2015 - 09:02 PM
or the manifld could of reached its limit then the build up in heat with further revs causes more power loss
#809
Posted 09 July 2015 - 09:19 AM
Would you expect such a sudden drop off for that though?
#810
Why would heat buildup in the manifold cause powerloss?
Heat build up (within material limits) is a good thing, it's why people wrap or ceramic coat exhaust systems. Hot exhausts keep the gasses hotter so they flow faster and reduce back pressure.
#811
Posted 09 July 2015 - 09:26 AM
Edited by CHILL Gone DUTCH, 09 July 2015 - 09:27 AM.
#812
Posted 09 July 2015 - 09:36 AM
#813
Posted 09 July 2015 - 10:00 AM
Is it now that I mention water injection?
#814
Posted 09 July 2015 - 10:15 AM
No. Not until we determine I have a heat problemIs it now that I mention water injection?
#815
Posted 09 July 2015 - 10:35 AM
T map ??No. Not until we determine I have a heat problemIs it now that I mention water injection?
#816
Posted 09 July 2015 - 11:28 AM
My first port of call would be belt slip, tyre traction and boost loss. Talking to the people who ran the RR might give you a better idea too.
Depends on how it's setup I no as soon as my inlet temps reach around 72-74 degrees my car seen to drop power like a stone Not just because of the heat but also because of the ecu retardation because of the heat = loss of power The restriction increases the heat dramatically Because your engine is 2.0 you will probably have more compression the the 2.2 so this also increases heat . With same pulleys etc etc Shame you can't do a power run on a cold dry night Makes a massive difference to my car But I am still wondering about my dip in power compared with yours Around similar revs, could it be coincidence
I assumed you were talking about the exhaust manifold, obviously an inlet manifold would have this problem, but as both yourself and others have reached higher power it's very unlikely that any manufacturing variance is causing Graeme's to flow much less.
#817
Posted 09 July 2015 - 11:36 AM
#818
Posted 09 July 2015 - 11:38 AM
#819
Posted 09 July 2015 - 11:40 AM
#820
Posted 09 July 2015 - 12:37 PM
But we already have 2-litres with harrops in Europe don't we?I think the proof will be when artic monkey gets his going As 2.0 with a 3" complete system I will try and convince him to run the same size pulley
Also tagged with one or more of these keywords: saab, b207, supercharged, m62, ats dtc, composite worx, re-spray, coupe
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
Supercharged Exhaust AdviceStarted by Donmizzi , 28 Jan 2021 ![]() |
VX220 Discussion →
Looking To Join The Sc Club - Advice Please...Started by JamieShand , 06 Sep 2019 ![]() |
VX220 Discussion →
Ebay Coupe Rear KitStarted by gazbucko , 23 Apr 2019 ![]() |
The Market Place →
Car Parts Wanted →
Coupe Rear Kit Wanted!Started by gazbucko , 23 Apr 2019 ![]() |
