Project 'once'
saab b207 supercharged m62 ats dtc composite worx re-spray coupe
1145 replies to this topic
#861 Nev
Posted 10 July 2015 - 05:15 AM
I ask my engine what it wants all the time. It's like talking to a brick wall most of the time though.. :lol:
It's cos you aren't talking to it in Japanese !
#862 CHILL Gone DUTCH
Posted 10 July 2015 - 05:17 AM
10s is rich but that would of been on base map After a fuel learn it will very close the 11.8 at WOT Which is not so rich ( default on Dutch software ) I've personally never moved away from 14.7 idle to 11.8 WoT with maybe a step in between towards lower pressure range Interesting reading and helps to explain what's going on, Any way back on to Graeme project
#863 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 10 July 2015 - 05:33 AM
Clearly some don't listen..........
Talk softly to it, but with a bigger stick this time please ;)
#864 Exmantaa
Posted 10 July 2015 - 09:24 AM
Who's "Bill"?
But for a Harrop that's a surprisingly lowish rpm where his makes the 398 max power.
(but from that number a similar build 2.0 should make 360-ish...)
#865 CHILL Gone DUTCH
Posted 10 July 2015 - 09:37 AM
Who's "Bill"?   But for a Harrop that's a surprisingly lowish rpm where his makes the 398 max power. (but from that number a similar build 2.0 should make 360-ish...)
Previously know as Westkenbiscuit on the Saab b207 thread
#866 CHILL Gone DUTCH
Posted 10 July 2015 - 09:48 AM
Westkenbrit not buiscuit
#867 siztenboots
Posted 10 July 2015 - 09:52 AM
yes, but power comes from the ignition timing
you could do three dyno runs , 11:1 , 12:1 , 13:1 and get the same result
but what will certainly change is the EGT dramatically increasing with lean ratios
then do the same but put in extra 3 to 4 degree ignition timing and you will see a more torque , more bhp
so staying rich is all about EGT and protecting components, call that safety if you want to.
since we can't control valve timing by the ecu on our engine, the next thing is try a vernier on the inlet cam and understand the zzp setup
tbh, Matt is giving you great , really usable torque
#868 Exmantaa
ps; max power AFR is somewhere around 12.6. (Google that),. But in our boosted hot engines you want safety and extra cooling, so 11.8 is an accepted safe mixture (rich best torque). You can lean it out a bit towards max power rpm, depending on how good your chargecooling is. But then how accurate is your wideband sensor... (Google that too.)
#869 siztenboots
Posted 10 July 2015 - 09:53 AM
very true about w/b sensors accuracy
#870 CHILL Gone DUTCH
Posted 10 July 2015 - 09:56 AM
So leaning the mixture helps to get more ignition in ? If the engine/setup can take the leaner mixture & extra heat
Edited by CHILL Gone DUTCH, 10 July 2015 - 09:57 AM.
#871 CHILL Gone DUTCH
Posted 10 July 2015 - 10:01 AM
I've seems bills ignition and he has got similar ignition settings to me maybe a a few degrees extra in certain places When I tried to get more ignition in I just got lots of knock so backed it off I'm not sure I want to lean my engine off as the power it's making is more than enough for my car and it's handling, Plus I need to learn to drive better and smoother with it
#872 siztenboots
Posted 10 July 2015 - 10:12 AM
richer mixture generally gives you more headroom for extra ignition timing
and cooler temp plugs
#873 CHILL Gone DUTCH
Posted 10 July 2015 - 10:30 AM
  richer mixture generally gives you more headroom for extra ignition timing   and cooler temp plugs
So bills car is coping really well with the leaner mixture and more ignition
#874 Bargi
Bargi
  • 4,483 posts
Posted 10 July 2015 - 10:55 AM
Just putting it out there, could we be noticing the top end lumps more because we're used to looking at CS graphs which don't cross over 5252rpm and is generally more stretched out?
#875 Matthew Bentley Racing Ltd
  • 774 posts
Posted 10 July 2015 - 11:50 AM
On most of the boost levels we are dealing with here you shouldn't need to go under 12 in my experience if you keep the charge temp reasonable. However if charge temps change significantly that is what a correction table is for, if the temp goes high for some reason it goes richer.
We are only talking about 0.8-0.9 bar of boost, not like a stg 4-5 turbo at 1.3-1.6bar boost.
#876 CHILL Gone DUTCH
Posted 10 July 2015 - 12:12 PM
What colour you Having graham
#877 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 10 July 2015 - 12:14 PM
Haha :lol:
#878 FLD
Posted 10 July 2015 - 12:21 PM
I heard he was having dysentry beige
#879 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 10 July 2015 - 12:33 PM
Brown went out the window a long time ago. It was on the consideration list though.
I'm having one of my usual colour wobbles... Problem with Sakhir is I think it looks mega in the sun, but when its raining or cloudy etc it loses some of it's lustre shall we say.
Plus there's another guy painting his Sakhir now. Will hopefully be able to use him as a guinea pig
#880 techieboy
Posted 10 July 2015 - 12:35 PM
Good idea, assuming his paintshop finishes it in the next 18 months. :P
Also tagged with one or more of these keywords: saab, b207, supercharged, m62, ats dtc, composite worx, re-spray, coupe
